Results 1 to 15 of 15
    Mar 2011
    Looking for some guidance on 1x11 drivetrains
    Hello!
    So I am a new proud owner of a chilcotin, and I have a 2x10 XT drivetrain on the bike now. Im wanting to shed some weight from the bike (it is clocking in around 34 lb) and the most obvious way is by losing the front derailleur. Can anybody tell me of their experience with switching from XT 2x10 to X01 1x11? I live in Denver, and we have some steep, sustained climbs around here that I use the granny for on the regular. Also, I plan to ride the chili on extended rides in the 20-25 mile range in high alpine environments like Crested Butte and Kenosha Pass. Would I suffer tremendously by switching to the 1x11?
    Thanks in advance!
    Reputation: Buzz's Avatar
    Why not get a 42T cog for the rear of your 10spd and try going narrow wide single ring up front? About 1/10th the price of going 1x11. If it doesnt work out, or you cant live with the gearing, you are only out about $150 rather than somewhere around $1500 for xx1 or xo1.
    Just my .02
    One other thing that I saw in an article on nsmb was people using narrow wide front ring and still keeping their granny for "emergencies" Presumably you can drop the chain to the granny manually if you really need that low gear then move it back up for the 90% of your riding that doesn't require the granny. You still get to ditch the front mech and shifter. For me personally, there is too much altitude gain in to short of a distance where I ride to drop the granny. I tried staying in the "middle" ring (32T) and never lasted very long before having to bail out. Maybe give this a try first, assuming you already have the shifters and front mech? If you can get through a couple rides without shifting to granny, get a narrow wide and toss your extra parts.
    BL
    "Lightweight , durable , inexpensive
    Pick 2."
    Delirious Tuck
    Reputation: thefriar's Avatar
    Just ordered the 42t Wolf tooth rear cog, $90. Comes in Red, Black, and Silver. 2-3 week delay.
    Would assume if you did 10 speed XT rear with the big Wolf Tooth, and a 30t up front you'd be fine in the long spinny stuff. Maybe even need a 32 upfront if the 42t is just too easy to spin.
    Hope also just came out with a 40t at FrostBike, no idea when that will hit. Shifting should be better I'm told.
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    28X42 feels about the same as 24X36 (ignoring the weight savings)
    30X42 feels about the same as 24X34 (ignoring the weight savings)
    26X42 feels about the same as 22X36 (ignoring the weight savings)
    28X42 feels slightly easier than 22X32 and slightly harder than 22X34 (ignoring the weight savings)
    30X42 feels slightly easier than 22X30 and slightly harder than 22X32 (ignoring the weight savings)
    "sounds like you need to find a better mechanic..." -- Calhoun
    Reputation: Calhoun's Avatar
    Nov 2008
    Although there is some weight to be lost by going 1x, a lot more can be lost at the wheels and tires. What is your build?
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    How are you doing 28x42 and 26x42? Not with a 104 BCD crank I take it?
    Quote Originally Posted by TSC View Post
    Pick 2."
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by BikeLust View Post
    Direct Mount for SRAM GXP Cranks by wolftoothcomponents.com
    I think other manufacturers make something similar.
    Reputation: KRob's Avatar
    Yeah but, what does 32x42 feel like?
    Isaiah 58:14
    www.stuckinthespokes.com
    Mar 2011
    Quote Originally Posted by Calhoun View Post
    Shes a little piggie all over to be honest...
    CCDBAcs
    170 Lyrik rc2dh
    Hope E4 brakes
    XT 2x10
    Hadley hubs with Flow Rims
    Minion DHF 2.5
    High Roller2 2.4
    KS Lev
    like I said shes a fat piggie, but I love the build! I plan to post some pics tomorrow...
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by KRob View Post
    32x42 feels the EXACT same as a 22X28.92, a 24X31.53, a 26X34.15, a 28X36.75, or a 30X39.41 (ignoring the weight savings)
    NOTE: Values are rounded off to the nearest 100th because I didn't want to be absurd.
    FYI: I have a buddy or three that are looking at new mountain bikes. I'm trying to get as many as possible to the Knolly (and Ibis) demo at OTE. Hopefully, I will see you there.
    Nov 2008
    Quote Originally Posted by getupgetdown View Post
    CCDBAcs
    170 Lyrik rc2dh
    Hope E4 brakes
    XT 2x10
    Minion DHF 2.5
    High Roller2 2.4
    KS Lev
    Sounds like a solid build, I wouldn't want to mess with that set up too much. Maybe drivetrain is the key.
    I would start with the suggestions to stay in your large ring for at least a week. Maybe even disable the front D (turn the limit adjust) and force yourself to stay on that big ring.
    If you stay with the XT cranks the lowest you can go is the Race Face N/W 30t. The move to 11 speed will cost you, converting the hub will be close to $200. Hadley Freehub XD Driver XX1 for SDH hubs at Balle Racing and Hadley XX1 142mm X 12mm Thru Axle Conversion Kit at Balle Racing
    -cabra cadabra
    Mar 2011
    Thanks Calhoun! I may end up keeping the Chili as is since shes sort of a heavy girl (so I can get up the long steep climbs still), and converting my Ripley to 1x11...or selling the Ripley and getting an Endo and going 1x11 on it...who knows, maybe Ill find a way to keep the Ripley and get an Endo! Such terrible problems to have
    Thanks for the input folks!
    LOL. Thanks for the "rough estimates", Tyson. I appreciate your exactness. I had looked up those gear inch equivalents at one time before I ordered my 42t cog but that was like two months ago and I'd forgotten. Running 24 x 32 on most all my steepest climbing sections now with a rare drop down into 24x36 so I think I'll be fine.
    I'm seriously thinking about coming down to the OTE demo at the end of this month. Is that also the OTE festival thing?
    Isaiah 58:14
    TSC
    TSC is offline
    Buehliever
    That's the one. I haven't been on a bike in a long time, so look for the fat pasty guy if you go.
  1. Ebay OEM drivetrains
    By KevinGT in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-26-2013, 01:47 AM
  2. New shimano drivetrains.
    By Pock in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-23-2011, 08:21 AM
  3. Fatback Drivetrains
    By apbtlvr in forum Fat bikes
    Last Post: 10-23-2011, 02:26 PM
  4. 3 X 10 and 2 X 10 Drivetrains. What say you?
    By Stumpjumper61 in forum Specialized
    Last Post: 06-20-2011, 12:09 PM
  5. Rotating Mass of Drivetrains?
    By GPRider08 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-11-2011, 02:00 PM
