Results 1 to 30 of 30
Thread: Listen to Dusty
    Reputation: Calhoun's Avatar
    Nov 2008
    Listen to Dusty
    When asking Kevin about sizing, listen to what he has to say. He isn't that punk kid from the LBS trying to sell you Racing Ralphs for your DH bike. Dude knows his sh!t, and knows how his product fits.
    Kevin told me a couple of times that a large would be best for me, but I wouldn't hear it and bought the medium instead. I am now on a large
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Dusty knows the product fo sho.
    The new rig looks nice, Calhoun. Glad you are all straightened out.
    Yebo Numzaan
    Reputation: Muttonchops's Avatar
    Nice to see both hands on the bar in the second pic!
    I support EMBA
    dog's best friend
    Are those Racing Ralphs on your Chili?
    Pivoteer
    Reputation: tiSS'er's Avatar
    Quote Originally Posted by Muttonchops View Post
    ^^^^ This
    Employed by Pivot Cycles - www.pivotcycles.com
    Reputation: Deerhill's Avatar
    Dec 2009
    The Vengeance looks good how you like?
    Nov 2008
    That's a new trick I've been working on
    -cabra cadabra
    Nov 2008
    Quote Originally Posted by Deerhill View Post
    Best fork EVAR!
    -cabra cadabra
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    Quote Originally Posted by Calhoun View Post
    What are your measurements?
    "sounds like you need to find a better mechanic..." -- Calhoun
    Quote Originally Posted by TSC View Post
    he is 32B but he rides like a solid C.
    sapienti sat est
    Reputation: BikeBert's Avatar
    I'm 5'11" [180cm] and I was ready to order Medium Chili, since my old Large Endorphin felt a little bit too big for me on some sketchy trails. However, I decided I'll ask Kevin before ordering. He suggested I go with Large. Now I'm glad I did! Large is perfect, it also sits lower than my old Endo. So yes, listen to Kevin
    ____________________
    | Picasa | YouTube | Pinkbike |
    Reputation: KRob's Avatar
    Glad Kevin got you sorted, Rory. Good looking bike. Fun looking ride. Does it still look all dry and warm there in NM? Jealous.
    More snow yesterday and clear and zero this morning.
    Also interested in your height/inseam measurements.
    5'11.5" and also went large with my chili
    Isaiah 58:14
    www.stuckinthespokes.com
    Quote Originally Posted by KRob View Post
    +1 same/same.
    Reputation: woodyak's Avatar
    You riding with gloves now?
    Knomer
    Reputation: Dusty Bottoms's Avatar
    OBEY.
    Director of Sales: Knolly Bikes
    OK, he's totally out of control now. World domination has gone to his head and we must put a stop to this!
    Quote Originally Posted by Dusty Bottoms View Post
    OBEY.
    Nov 2008
    6' with a 34" cycling inseam
    Quote Originally Posted by woodyak View Post
    It's winter man!
    -cabra cadabra
    Reputation: wilks's Avatar
    I've had a hard time understanding the top tube measurements on the new Knolly's for a long time. The bikes just don't feel as big as the top tubes suggest. Same with Santa Cruz and Ibis. In my opinion. I had a large DW Spot prior to the Chilcotin with a 23.6 ETT. I went with the medium chilcotin with 23.5 ETT and the Chilcotin feels waaaay smaller. Reach and stack and axis and who knows what #s don't compensate for riding a bike first but demos are sometimes hard to come by. On paper the large Chilcotin is pretty big but in reality it isn't.
    Nov 2008
    Exactly. My previous bike was a Banshee Scythe. As a large the geo numbers match the medium Chilcotin. But the way the Knolly rides you don't need a smaller bike for that lively easy to move around feel.
    -cabra cadabra
    Quote Originally Posted by wilks View Post
    I've had a hard time understanding the top tube measurements on the new Knolly's for a long time. The bikes just don't feel as big as the top tubes suggest..
    Here's Noel's explanation from a previous thread:
    Quote Originally Posted by knollybikes.com View Post
    ETT is Effective Top Tube Length
    TT is (actual) Top Tube Length
    There is a difference:
    TT length is a horizontal line measured from the axis of the real seat tube, to the axis of the headtube, at the top of the head tube. This works well for road bikes and frames with conventional double diamond design (i.e. most hard tails and many shorter travel full suspension bikes).
    However, for any frame that does not have a conventional seat tube (i.e. a seat tube which intersects with the down tube in front of the BB like ours do, or it has a bent seat tube, which a TON of frames do to ensure adequate room for the rear wheel / rear linkage under full compression), then the standard TT Length measurement does not adequately represent the frame geometry as it does not NOT indicate where the saddle will be when pedalling.
    The Effective Top Tube lengths (used with the effective seat tube angle) are what are listed for our frames on the website geometry: if you measure the actual Top Tube length, it will be shorter than what is listed for the ETT length.
    The reason that we build our bikes this way is so that when the saddle is up and you're pedaling, you have proper torso extension (i.e. "room" in the cockpit). When the saddle is down, it effectively moves forwards, and out of the way, giving the rider more room to get behind the seat. Additionally, by not bending the seat tube (bending the seat tube is a much less expensive way to make a frame than what we do), we ensure a full length seat tube, giving a very low seated stand over height and lots of range of seat post adjustment.
    The drawing below is not to scale and does not represent any particular Knolly model, but was done to illustrate the idea of the engineering design behind the frame geometry.
    Cheers,
    But the diagram helps me understand the best.
    Attached Thumbnails Attached Thumbnails Listen to Dusty-knolly-tt-explanation.jpg
    Isaiah 58:14
    RideDirt
    Reputation: aedubber's Avatar
    Bike is looking good man .. Im 5'9'' and i ride a medium. I think i fit it well ? lol .. What i noticed about the Knolly is that i am like sitting on the bike rather then in it i guess if you know what im saying ? My enduro was a medium and i felt like i was in the bike while riding .. No complaints , just a different style thats all .
    Haha..bike looks good man!
    I was a bit worried about being b/w the medium and large (5' 11'', 32 inseam). Went with the large and it feels spot on.
    Nick
    Dec 2009
    Best fork EVAR!
    My next big purchase.. gotta be ready for 650b chilcotin : )
    TSC
    TSC is offline
    Buehliever
    I've been saying, "Listen to Dusty" ever since he told that really hot girl to overlook my ugliness and submit to my advances.
    Best fork EVAR!
    I didn't know Avalanche had a cartridge for that one out yet.
    Nice KOM, sorry about your penis.
    Reputation: vikb's Avatar
    Good thread. I'm definitely conflicted between going for a Med or Lrg Chilcotin. I'm 5'11" 33" inseam and long arms. I live in BC and ride tight trails in the forest 90% of the time. So I'm keen on the smaller bike if it fits. Sat on a Med Chili and it seemed ok, but sitting isn't the same as a long ride.
    The long effective TT numbers are messing with my head. Typically I'd say I would fit on a Lrg, but the TT for the Med is long - on paper at least.
    I've got some time to figure this out while I wait for a 650B Chili to come down the pipe.
    Thanks for posting all the sizing info. It's helpful when you can't get a test ride....
    Safe riding,
    Vik
    www.vikapproved.com
    I'm the same measurements, and my Chili sees alot of pedalling. Dusty recommended a large. On my other bikes with 19" seat tubes, I run almost 8 inch (7 3/4 or so) of exposed post when in fully extended pedalling position. With a medium that would put me at nearly 10" of exposed post, way too much IMHO.
    With the type of riding you do the most.....you may be ok on a medium. I spent a good three or four hours on both sizes in north van and Squamish and could be happy with either in those conditions. I'm a bit taller than you, prefer a bit more stretched out cockpit, and ride more open desert terrain so opted for the large.
    It would be great to get some time one if you can.
    Isaiah 58:14
    EMR
    EMR is offline
    Sep 2012
    I went with a medium chilcotin, 5'11" 32" inseam. I want to try a large every time I read people's comments in hear that are my size, but on the trail I'm never wishing or thinking I need a large (just got back from a 2hr ride, never thought large, but did think 650b endorphin). I came from a transition covert which has a shorter ett. The only thing I don't like is the amount of exposed seat post, but again, when riding I don't notice at all (love me some dropper post). I run a 65mm stem with 740mm bars. No issue with stability and still easy to throw around. With that said, I know I feel more comfortable on smaller frames and live with the occasional knee/bar smash.
    Reputation: cheezwhip's Avatar
    Listen to Dusty
    5'11"/32" inseam - I have a medium (70mm stem/762mm bars). Cockpit/TT length is fine and so is seatpost height. Given the choice to order again, I'd choose a medium again - that said, try both if you can before you purchase.
    Caveat: I do like my bikes smaller
    ¡Geaux Tigers! - ¡Visca el Barça!
    "Finer than frog hair!" - Lumberjack
