    Oct 2012
    Leveling the saddle of a 2009 Endorphin?
    Hello all:
    I have recently bought a used 2009 Endorphin in large. I'm having an issue with the super slack seat angle and my Thompson straight post: I cannot seem to get the saddle level. The nose is still pointed up too much for my liking, even when the seatpost rocker is maxed down towards the front. It makes for very uncomfortable riding when grinding uphill.
    Do I need a special seatpost in order to get the nose pointed down a degree or two?
    Leveling the saddle of a 2009 Endorphin?-3t63la3s75l15e55f6d6i92bfa3fa6e51143f-1-.jpg
    Thanks.
    Reputation: qbert2000's Avatar
    i have an older thomson seat post that i could never get to level correctly on my knolly. swapping it for a newer version solved the problem. it was the actual post not the post hardware as i swapped that out with some newer hardware and it still didnt work
    Oct 2012
    i did rotate the seatpost 180 degrees. basically install the seatpost in reverse and it should give you extra degrees lower
    Oct 2012
    Thanks. I'll try rotating it before getting a new one.
  1. Replies: 9
    Last Post: 02-27-2013, 10:19 AM
  2. Replies: 0
    Last Post: 02-06-2013, 01:50 PM
  3. Saddle leveling
    By aperture in forum Beginner's Corner
    Last Post: 04-20-2011, 07:01 PM
