Page 1 of 2 12 LastLast
Results 1 to 100 of 120
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    Knolly Mechanic Tips & Tricks
    Throughout different threads I see a lot of good information on tune-ups, repairs and other bike mechanic stuff. Unfortunately, when I need the info itís often difficult/impossible to find. My guess is that Iím not the only one with this problem, so Iím starting this thread as a place to collect any useful tips & tricks on being a Knolly DIY Bike Mechanic.
    "sounds like you need to find a better mechanic..." -- Calhoun
    TSC
    TSC is offline
    Buehliever
    Bearing Maintenance
    -- How much crunch....
    Reputation: Calhoun's Avatar
    Nov 2008
    Good idea TSC. The only tip I can think of right now is to have plenty of cold beer and patience (or Root Beer if you are KRob.) And if you have been fighting the same issue for too long, leave it alone and come back to it.
    Also find a good wrench at the LBS and figure out what beer they like. Nothing like bringing in a wheel and a six pack the night before a road trip.
    "Mi amor Nuevo Miťrcoles!"
    -cabra cadabra
    Reputation: woodyak's Avatar
    I've got one for the Chilcotin. You know the upper linkage that has the bushings? You might want to check the torque on those bolts. When I removed my shock to send it in I noticed my suspension was barely moving. I figured I blew out a bearing so I went through each set of linkage until I came to the elbow with the bushings. As soon as I loosened the bolts the whole linkage dropped. After tightening all the linkage and giving a fresh squirt of WD-40 I confirmed that this was the problem.
    Fast-forward a week later when I got my shock back before installing I torqued down the linkage and I noticed that it still had a good bit of binding. I greased the crap out of the bushings and that helped but I still found it lacking. So I reduced the torque and used loc-tite on the bolts and it was look a whole new bike. It was so much plusher that I had to adjust the shock to deal with it. Be careful with these bolts though as the 1st time I didn't use loc-tite and the bolts came out.
    I was going to post a pic of the linkage but I don't know how with the new forum. Can anyone tell me how you can reply and add a photo?
    Cheers!
    Biking Like Crazy!
    Reputation: blcman's Avatar
    ... and if we just ...
    Quote Originally Posted by woodyak View Post
    Cheers!
    Yeah, and how do you make letters BOLD and use the "smiley" face!
    2017 Niner Rip 9 RDO Pushed Version!
    2015 Ibis HD3 w/ Push ASC3
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    Reputation: bubba13's Avatar
    More Bearing maintenence
    I posted this a while back. Bearing maintenence
    If you want to add photo's with a reply, use the Go advanced reply button and scroll down to the picture section.
    Use reply or reply with quote. A new box will open. The Go advanced button is at the bottom of that box.
    Edit: Thanks for the info on the bushing linkages Woodyak. I agree these bolts should require a thread locker. These are the only bolts in the linkage that have required attention from loosening.
    Portland Off Road Navagators
    Just roll it......
    Reputation: ebxtreme's Avatar
    On this note, what's a decent (quality and price) torque wrench that folks are using?
    Biking Like Crazy!
    Quote Originally Posted by bubba13 View Post
    Thanks bubba13!
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    Reputation: cerebroside's Avatar
    I have a question: Is it possible to tell if the pivots need maintenance without tearing them down? I bought a 2011 Delirium second hand late last season and only got in about ten (very dry) rides in.
    Linkage operated freely from what I could tell when I built it up, but I have no idea what the previous owner did in terms of service intervals.
    Quote Originally Posted by cerebroside View Post
    The only bearings I would be concerned about are the lower main bearings near the BB. Two seasons of riding and the rest of the bearings on the Delirium looked great. The main's were rusty and crunchy at the 6 month point... I finally replaced the main's after a year + 6 months. The linked post #6 bearing maint. above is fairly easy to do. Just pay attention to the washers and their locations.
    Quote Originally Posted by ebxtreme View Post
    Norbar and Teng are good options.
    TSC
    TSC is offline
    Buehliever
    My inspiration for this thread.
    Yesterday I was performing some annual maintenance on my Chiliótaking it apart and checking/lubing the bearingsówhen I came to a bolt I couldn't loosen. The bolt was attached to the shaft that goes through the center part of the linkage (to which the red arrow in the following picture is pointing).
    Name:  Knolly Mechanic Tips & Tricks Shaft Location.jpg
    This is my attempt at an exploded view so you get an idea of how it all goes together.
    Name:  Knolly Mechanic Tips & Tricks Exploded View.jpg
    The shaft had a bolt in each side, so getting the bolt out of one side was no problem; but once one bolt is out you have nothing to stop the shaft from spinning. I tried lots of things but nothing would free the bolt. I didnít want to hook vice-grips or anything to the shaft that would damage it so I decided to use the old standbyóDUCT TAPE!
    Name:  Knolly Mechanic Tips & Tricks.jpg
    Notice that the duct tape is tore. The bolt was so tight that it wouldnít budge when holding the shaft with pliers. (Even after all my precautions and care I still put a small nick in shaft. SOB! I used some 600 grit wet/dry sandpaper to buff the nick out.)
    To get the bolt loose I had to put the shaft in a vice. NOTE: The vice was only touching the duct tape and I didnít tighten the vice down hard on the shaft. (The shaft has to be very smooth and round to function properly.) I only used the vice to create a larger friction area.
    Anyway, thatís my tip/trick to get the second bolt out of the shaft if the bolt feels like it was smothered with red Loctite and then cross-threaded for good measure.
    Iím sure that some of you have a better method so please let everyone know because it could save a lot of people a lot of time.
    I just replaced the end bolts on the same push link pivot TSC mentions above. And as careful as I was I nicked up my pivot axle as well trying to get the second bolt out. Wrapped a few pieces of thick rubber around the axle and clamped the hell out of it with a vice grip. And it still barely broke loose. But when it did, I'd put a few scrapes and nicks in it.
    I hit the pivot with a few light strokes of a file, and just thew it back in. Hope it will be ok, but who knows. Going riding tomorrow and I don't have much option.
    So if you try to mess with this axle, just be careful. Maybe soft jaws in a bench vise would work, but I don't have one of those....
    Reputation: mayha's Avatar
    Mar 2012
    TSC or anyone else that may know...See that washer on the left in your picture? Is there another one on the opposite side of that axle? When I removed mine I only noticed that washer on one side.
    Thanks! And nice job with the thread.
    fat & decripit old guy
    Mar 2011
    To take that shaft off I put it in a drill presses jaws then just use your allen key to remove the bolt. I held the drills head still with channel locks.
    Mayha, there should be a washer on both sides, to go between the bearing and the pivot shaft.
    Mar 2012
    Quote Originally Posted by rscecil007 View Post
    Damn, I must have dropped the other washer when I removed the axle!
    TSC
    TSC is offline
    Buehliever
    I just ... Wrapped a few pieces of thick rubber around the axle...
    I don't have a vice with soft jaws. I'm pretty sure rscecil007 is talk about rubber jaws on a vice. (Sometimes when you are working with aluminum you can use aluminum jaw inserts but I wouldn't try that here.) I would make sure to only use rubber or tape.
    My first choice was to use one (or two) jelly-type sticky pads instead of duct tape but I couldn't find the one I have (and I live in the sticks so going to Walgreens/Home Depot wasn't an option); so I used duct tape. It works well but requires a bit of cleanup afterwards.
    TSC
    TSC is offline
    Buehliever
    Adding on to what rscecil007 said: you will notice that the inner, metal part of the bearing is raised above the dust seal. This is because you don't want any moving parts touching your dust seal. Rotating/moving parts touching your dust seal will destroy it (or, at a minimum, pop it out of place); making it useless. To protect against this, Knolly's bearing inserts have a small raised ridge (I tried to highlight it in red to make it more visible) to make sure the insert only touches the metal part of the bearing. The washers do the same thing on the other side. Note: in other areas of the bike's suspension there is no need for washers as it is aluminum that will be butted up against the bearing. Since aluminum doesn't deform it won't hit your dust seal, making washers unnecessarily.
    Hope this helps!
    Name:  Knolly Mechanic Tips & Tricks Seal Guards.jpg
    BTW, if the bearing insert pictured looks too big for the hole; it is. I used the bigger one to make the raised ridge easier to see.
    TSC
    TSC is offline
    Buehliever
    This is a good article for the DIY bike mechanic; although I wouldn't follow their "pack your bearing full of grease" advice on anything other than suspension bearings, which are very limited in their rotation speed. Too much grease in a bearing will slow it down and will cause heat buildup in high-RPM bearings.
    Workshop: Caring For Mountain Bike Suspension Pivots - BikeRadar
    on this topic, heres something really cool that intense are putting on for their customers on pinkbike later
    April 2nd, Intense Cycles Live in The Lounge by CaneCreekCyclingComponents - Pinkbike
    thats a cool way of nailing 000's of queries in one go. Knolly, you up for something like this?
    The tool recommended to to me by Knolly for removing the second bolt from the "shaft" was heat. I had the rusty bolt issue and this was the only one I could not get to break free. The issue is the loctite thats used. I used a heat gun on high and it did the trick.
    Quote Originally Posted by TSC View Post
    Yup, that's what I was talking about. Thanks for the correction. I need to go buy a vice and a set of those.
    Quote Originally Posted by AndyD View Post
    Good to know for anyone reading. Wish I had known that though and not eff'd my pivot axle up. Oh well. I used blue loctite on all my bolts when I re-installed them. No idea what Knolly recommends.
    EXCELLENT GUIDANCE! I found the same thing two weeks back.
    What torque value did you settle on - just short of spec?
    Mar 2012
    Hope this helps!
    Big thanks for the pics TSC!! That confirms that I'm missing one for sure. Do you think the hardware store holds washers of that type or is this bike industry specific?
    TSC
    TSC is offline
    Buehliever
    I was thinking of that but I was afraid to use heat on aluminum as it's pretty low. Metals - Melting Temperatures
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by mayha View Post
    I'm guessing you can buy it from a hardware store. From the Knolly website:
    FASTENERS:
    We use only high end name brand fasteners ensuring that our fastener products are consistent and reliable. All Fasteners are stainless steel and where required, super hard grade 12.9 plated steel. We do this to ensure that the fasteners don't corrode and don't bend.
    We use M8 bolts for all of our shock mounting hardware on our heavier duty frames, again from a strength perspective. And, wherever possible, we use commonly available metric fasteners so that they are easily replaced if damaged or lost.
    Email Knolly support for the details (e.g. is it stainless steel); and take the one you have to your hardware store so you can make sure to get the same one.
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by CharacterZero View Post
    The article I posted in post #20 talks about lubing your bushings. It's worth the read.
    TSC
    TSC is offline
    Buehliever
    Another thing:
    I hope everyone noticed that the "nut" with a long, smooth shaft that attaches the chainstay to the bike goes in from the drive side, and the bolt that attaches to it goes in from the non-drive side. When I put it in the opposite way, it looked like it almost fit but there was a little lip showing. When I reversed it to the direction described above, it fit flush on both sides.
    Name:  Bolt thingy.jpg
    If you don't have access to a heat gun, try a hair dryer on high. Alternatively, if the part is clean of any combustibles, throw it in the oven.
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by BryanS. View Post
    I especially like your oven idea, although with the attached pivot arm that's a lot to bake. In the oven you could take it up to a really high temperature without worrying about overheating any particular part of it. Wish I had thought of this. All I thought was "torch"; then added in my bad luck and thought "melted shaft"; so I backed away.
    The one thing I did do was put the shaft in the freezer overnight before putting it through the bushings. I thought I would give it a try because of the tight tolerances; but I really can't say if it did any good.
    Reputation: graypaw's Avatar
    Mar 2012
    Hello.
    I have a frame with less than a year old and I got rust in the linkage screws.
    Do you know if it is possible to buy identical but titanium made?
    I think a frame with this price should sold with betters screws.
    Nov 2012
    Knolly acknowledged this is a problem for some frames. Get in contact with them and they will replace all the affected hardware.
    Quote Originally Posted by graypaw View Post
    Hello.
    Mar 2012
    Quote Originally Posted by easygonow View Post
    OK, thanks
    Exactly. Just a hair short of spec.
    Replacing the bolts.
    I finally got around to replacing the rusty bolts on my early release Chilcotin. The new bolts have a black coating vs. the standard bolt finish from the originals.
    Everything went well and I wanted to share how I got the bolt off of the shaft that TSC has mentioned in earlier posts. I also wanted to mention to check the bearings. The only bearings that were in bad shape were the ones at the rocker arms. Both bearings were frozen with rust. To fix them I popped off the bearing cover, with the rockers off the bike, and soaked them in with Tri Flow. Worked the bearing back and forth until they broke free and did a clean and re-grease.
    When I got to the bolts that thread into the axle at the horse shoe link, the left side came loose with out issue. As stated in TSC's posts, the right side bolt would not budge after removing the assembly from the frame. Luckily, I remembered I have a Dewalt 1/4 hex driver/impact cordless tool. I also had a 1/4" bit with the correct allen tip. So, I wrapped the axle in old inner tube, clamped it in a vise, and used the impact to remove the bolt. The impact wrench made the job very easy to do. Hope this helps.
    Attached Thumbnails Attached Thumbnails Knolly Mechanic Tips & Tricks-001.jpg
    TSC
    TSC is offline
    Buehliever
    Nice bit of info. I like the use of the tube and the impact driver. One not of caution for those using the impact driver: be sure to have it going in the unloosen direction as these are "flat head" bolts (i.e. angled so they fit flush) which you can drive into the axle/shaft and flare its ends.
    Also, the bearings are cheap enough to replace on your own; but be sure to let Knolly know of any bad parts as they can show a problem with the manufacturer that needs to addressed.
    Greystoke
    Reputation: geo025's Avatar
    Dec 2010
    Not sure if anyone has mentioned but another way of holding any shaft without damage
    (its what I've used in the past on stanchions).
    Take a suitable size block of wood(pine 4X2) drill it to the size of said shaft or slightly smaller , then cut it in half down the centre of the hole.
    You can clamp that shaft between the two halves in a vice.
    With this method you get a larger surface area to clamp & no damage.
    TSC
    TSC is offline
    Buehliever
    Plug your water bottle cage holes!
    Most Knolly bikes do not come with bolts in the bottle cage holes. If water enters your frame then it will collect near the bottom bracket.
    In another thread mayha suggested using silicone or bolts; to which G-AIR added that disk rotor screws or screws from your front derailleur will work.
    Personally, I like the idea of extra hardware in case of an emergency but you should definitely consider at minimum using silicone.
    TSC
    TSC is offline
    Buehliever
    Protect your Paint/Frame
    There are lots of good tapes or stickers to protect your paint. I've found that a blow dryer is hot enough to make the thick tapes and stickers conform to the curves on my Knolly.
    If you're trying to protect against dents then you will need something thicker and/or stiffer.
    Obviously, adding protection sooner, rather than later, is the wise choice.
    This thread lists many of the options available: What is that thick/foamy frame protection?
    Anyone know what the 'breakaway torque' is for the loctite Knolly use on the Chilcotin linkage bolts?
    Hey guys I don't know anything about these linkages. How often should these be serviced? And what are the consequences if you don't?
    After the first ride on my chilcotin I noticed play in the upper seat stay pivot. I can move the pivot that has the bushing side to side by hand, and no amount of torquing things down seems to help. By the looks of that pivot the only thing holding it snug would be the bushing width. I'm hoping my frame isn't out of spec, for such an expensive frame I really don't want to be dealing with problems after one mild ride. Any ideas? I emailed knolly but haven't heard back yet. Are they all at Sea Otter?
    Quote Originally Posted by finch6013 View Post
    Do you mean the push link pivot axle?
    Kevin got in touch with me today and he says that the axle is just slightly too long, and that the fix is to grind .2mm off. Essentially the bolts bottom out on the axle before the frame tightens down on the bushings.
    Looks like I got it all fixed now.
    TSC
    TSC is offline
    Buehliever
    qbert2000 posted how to fix it:
    So, the bottom of the horseshoe connects into the top of the seatstay. There is an axle in there that is slightly too long. (approx 73mm and should be 72.70-72.75mm) Take 2 allen keys to that pivot (fig. E)and one of the bolts will break loose. Back it out half way, because then you will hit it with a mallet AFTER you detach the linkage (fig C) on the opposite side of the bike, that attaches the seatstay directly to the seattube. If you don't detach that linkage from the seattube, you will not be able to punch the axle thru.
    Just drag the axle across a flat file about 20 times.
    i used a caliper to make sure i just took off the prescribed length. you dont want to take off too much. i used a lathe to shorten mine, but a file would make quick work of it as well.
    His pictures are gone but I have a previous post on this thread showing the part. (I labeled the axle "shaft", cause I'm up on all the tech jargon .) Knolly Mechanic Tips & Tricks
    Edit: I'm too late; DOH! Hopefully it will help someone else.
    Reputation: Big B's Avatar
    I had the same issue, same fix.
    Reputation: bionicman's Avatar
    for those with hard to remove bolts a nice trick is to install the proper sized t-handle into the bolt then take a ball peen hammer & tap the t-handle - the shock transfered to the bolt will usually allow it to be removed without hassle
    TSC
    TSC is offline
    Buehliever
    I've heard that if your push link pivot axle gets hung up half way out of the horseshoe pivot that a 3/8" drill bit slides easily into the horseshoe yet fits snugly in the end of the push link pivot axle. You put the base of the drill bit into the end of the pivot axle and tap lightly on the pointy end of the drill bit. The drill bit provides enough length to tap out the pivot axle, while providing enough surface area so you don't bugger your threads or axle.
    YMMV, but that's what I heard.
    Reputation: alfredo's Avatar
    hi
    i would like to change my shock setting (ccdba) from steep to slack. what do i need to comply with to avoid any damage etc? i think i need to release the air from the shock first, right?
    Reputation: KRob's Avatar
    Quote Originally Posted by alfredo View Post
    hi
    Ooo, ooo, even I know this one!(Raising hand)
    Just remove the lower shock bolt and move it to the other hole. Done. (No Root Beer required)
    Isaiah 58:14
    www.stuckinthespokes.com
    that's all? really? not even release air etc? that's easier than i thought. thanks krob
    Nov 2008
    Quote Originally Posted by KRob View Post
    But Root Beer would make it more exciting!
    -cabra cadabra
    TSC
    TSC is offline
    Buehliever
    KRob's right; it's that easy. Only possible hangup I can think of is if you have a MRP 2x style chain guide snugged up close to your chainstay. The change of shock setting might make it catch. (This is pure speculation on my part.)
    Reputation: Bizarro's Avatar
    Hope this helps!
    this helps a lot. Recently in the last big ride I noticed a big "clunk...snap..pop" of some kind coming down off a jump or just pushing down on the seat moving the shock...that sound would happen. Thought my frame was cracked somewhere...turned out to be what your picture is...bearing are bad inside on the one rocker arm connecting to shock....bearings look like they're not spaced out evenly... cleaned them a bit...re-greased..put seal on and washer..tightened everything down...rode today...no noise til the end of the ride... again...same sound.. didn't work.. dust seal I believe also is damaged..crushed it looks like on one side.....need a new one...dang...need new bearings I think.. Wonder where I can find a new seal like that..bearings..hummmm???
    k n o ll y r o c k s
    Reputation: monty797's Avatar
    Hey guys,
    Quick question! I've recently picked up a used 2012 Chilcotin that I'm absolutely in love with. I've ran across a small issue that I've never really have had happen.
    When tightening down the rear axle, if the axle is too tight it seems to pinch the stays together so much that it binds up the wheels a bit and creates a ton of drag in the drivetrain. Loosening the rear axle a bit takes care of this instantaneously, so what my question is, is there a published torque measurement for the rear axle? I've looked a bit but haven't been able to find anything.
    Currently I just tighten it up until the wheels binds up a bit and slowly loosen it up until everything spins nice and free.
    The only other culprit is possibly the wheels. They are a brand new set of Industry Nine Enduro hubs laced to I9 rims, but I'm not sure that it could be them as they spin perfectly on my other bike.
    Thanks for the help!
    Quote Originally Posted by monty797 View Post
    Hey guys,
    Measure your rear hub width. I suspect you have a 135mm x 12mm hub, rather than 142mm x 12mm. You should be able to bottom out the frame axle, and it should lock the chainstay to the hub axle.
    That's a great idea. They were supposed to be 142x12 from I9 but that would explain it.
    TSC
    TSC is offline
    Buehliever
    Quote Originally Posted by Bizarro View Post
    The following PDF lists the bearing numbers in the description column. I just replaced the suspension bearings on my Giant Glory and my Transition Preston FR with Enduro bearings. I've heard good things about them. But I think these are common bearing sizes and you can find them almost anyplace.
    http://knollybikes.com/uploads/bike/...0Chilcotin.PDF
    TSC
    TSC is offline
    Buehliever
    I think BryanS is on to something.
    The following link shows torque specs you want. See the bottom diagram on the left side. The torques you requested are K and possibly J.
    Does anybody know if there is a .PDF like this for the new Endorphin frames?
    ouch...well..that's where that sound was coming from...hummm..
    hum...now where's that grinder???
    I thought I could get away with just cleaning out the bearings or replacing them..along with seal... guess not.
    Any suggestions?
Size:  9.7 KBName:  bearing 3.jpg
Size:  9.7 KBName:  bearing 2.jpg
Size:  9.8 KBName:  seal.jpg
    Another very common source of clicks/creak on mountain bikes in general is the Bottom Bracket, sometimes the sound travels through the frame and makes it hard to identify the sounds origins until the time comes when it manifests on every pedal stroke (long after youve gone demented with it )
    Sheldon browns guide to Creaks, Clicks and Clunks gives a great heads up to most of the sources of irritating noises on bikes in general, ive found it very handy in the past:
    Creaks, Clicks & Clunks
    His analysis is very good i like his point where he says "sometimes a noise that appears to be coming from the bottom bracket is actually coming from the saddle" ...so true, creaks have a tendency to trick us into thinking the problem originates from another part of the bike, like it doesnt want to be found!
    Mar 2012
    Hello.
    I have a Cane Creek 40 Headset installed in my Chilco. I have also an 1/8 fork and i will move to a 1/5 tapered fork. I guess only have to change the bottom cup. what is the right model?
    Thanks. Regards
  67. #67
    Hello.
    Cane Creek actually have an online tool for that: Cane Creek Headset Fit Finder
  68. #68
    Hello.
    Thanks. Regards
    Hey Graypaw,
    I just happen to have a new Crane Creek 40 HS for the Chilcotin. The lower cup is for a tapered steer tube. The bottom cup is an External Cup EC49, upper is a Zero stack ZS49. The only part of the headset that has been used is the lower race for the fork. Needed it as a temporary solution for a fork swap between the Chilco and Delirium. Running a Chris King on the Chilco and don't need this one.
    If you are interested, PM me.
    Cheers,
    Lee
  69. #69
    Hello.
    Thanks. Regards
    wrt chilco and cc headsets: the external bottom cup for 1/(1/8)th and 1.5 is the same (its the races that are different). internal bottom cup is for 1/(1/8)th only.
  70. #70
    Reputation: vikb's Avatar
    Curious what is the cost of a 4x4 suspension overhaul kit - complete set of bearings/bushings and any wear parts?
    Safe riding,
    Vik
    www.vikapproved.com
  71. #71
    Quote Originally Posted by vikb View Post
    they last for a long time, they're extremely well made, never heard a single peep out of anyone wrt durability...don't know Canadian price, UK is £120.
  72. #72
    Mar 2012
    Hello.
    Thanks for your answers.
    Regards
    Enviado desde mi GT-P7500 usando Tapatalk 4
  73. #73
    Neighborhood of 200$ us
  74. #74
    Mar 2012
    Hello.
    I still searching my best solution. I think first solution is:
    Cane Creek 40.EC49/40.Bottom Assembly
    And the second, zero stack like my current for the 1/8, this:
    Cane Creek 40.ZS56/40.Bottom Assembly
    Now I have a RS 170 and I will move to a MZ 55, 170 too. I think the best solution is the second one. Thanks
    Regards
  75. #75
    Mar 2012
    Other question, Anyone knows if the 4x4 lightweight is available for the chilco 2012 model? What's his price?
    Hello.
    Regards
    The second one is for a different HT diameter to the first one (1.5" 49mm vs Tapered 56mm standard), so one of those is not going to fit.
    I'm running the 40.EC49/40 in my Delirium so I'm pretty sure that's the one you want.
  77. #77
    Mar 2012
    Thanks man, I did a mistake.
    Also I keep a doubt.
    With a new fork that I should cut down the tube, what is better zero stack or the other?
  78. #78
    I run zero stack on the top, but unless you run your bars completely slammed I don't think it matters?
    If you mean the bottom, external cup will increase your front end height and slacken the bike a tiny bit. Doesn't look like Cane Creek do a '40.ZS49/40' though.
  79. #79
    Mar 2012
    Thanks.
    Me neither found a CC headset bottom cup with zero stack
    Regards
  80. #80
    Reputation: tweasol's Avatar
    Hi guys, I have a noobie question about my Endo...
    1. How do I remove the rear axle? I would guess pinch bolts first, then the axle itself? Anyone know the torque? On the following diagram, it shows the axle, but not the pinch bolts:
  81. #81
    Quote Originally Posted by tweasol View Post
    no worries: to remove, pinch bolts then axle, to re-install, axle then pinch bolts, hand tight / and common sense is fine, no need to over do it, or to spend 90 bucks on a torque wrench.
  82. #82
    I currently have my 2011 Delirium apart to service the bearings, and I'm having some trouble getting the main pivot apart.
    I've removed the 8mm bolt on the other side, but the sleeve that it bolts into will not move. I can rotate it, but it's pretty stiff. I'm assuming it's meant to just slide out.
    I'm also looking to replace the main pivot and chainstay pivot (rearmost) bearings, does anyone know the part numbers?
  83. #83
    Reputation: honns's Avatar
    Yes, if its the same as the old endorphin, the bolt threads into body of the piece that you see there with the allen face. I would find a socket that just fits inside the bearing race and just hammer it loose. You may just want to use a penetrant like PB Blaster to help loosen things up before you start swinging.
  84. #84
    The main pivot axle slides out the drive side and it may need some persuasion. The Delirium design tends to hold water in the frame at that location and the bearings rust to the aluminum pivot. There should be a couple of washers in that assembly also.
    If the bearings don't have any play in them, you should be able to clean and re grease them via steps mentioned previously in this thread. Not sure of the part numbers. Knolly may still have Delirium bearings available.
    Bubba
  85. #85
    Thanks. I'll feel a lot betting about wailing on it with a hammer now, haha. I've had PB blaster on it over night; gave it a good wack and it seems to turn a lot more freely now, even though there isn't any visible movement.
    I'm pretty confident that the main pivot bearings are toast, but I'll have a go at repacking them. The chainstay bearings were no good, all the others seem fine after a clean and repack.
    Going to try and source bearings locally first, but if not I will get on to Knolly.
    In other news, about half of the 6 dropout bolts were rounded (?), hopefully I can find some replacements.
  86. #86
    Reputation: Buzz's Avatar
    The main pivot bearings that you show in the picture are 3903 2RS. You can get them from enduro (enduroforkseals or universal cycles). The originally specced Knolly bearings are INA bearings and cost about $40-$50ea. The ones from enduro are about $16ea. I talked it over with Knolly, and they said they will be fine but might not last as long? I installed the same ones on my wife's endorphin and they are holding up fine for the past year.
    You can try and clean and re-pack the main pivot bearings, but be warned they are a double row ball bearing with a plastic cage separating the two rows of bearings. It took me a long time to clean them out, regrease, re-align that little cage and re-install only to find that they were still crunchy. Your best bet is to order a set from the sources I have listed. Let me know if you have any other questions!
  87. #87
    Ive found soaking the bearings in a degreaser/solvent bath cleans out the old grease and grit real well. But to do that you have to pull the bearing, which can be a lot of trouble. I never had so much trouble pulling bearings before my endo, it must be the tight tolerances or something. Once that is done, regreasing them is a breeze.
  88. #88
    Do you have a blind bearing puller? I got one just for this reason, makes getting the bearings out a snap and I dont worry about damaging them! Tapping them out with a socket works well too, but you have to be very careful. The bearing puller is quick and easy.
  89. #89
    Yea, I have two blind pullers (slide hammer and regular) and its just hard to anchor the parts/frame in a way that doesn't mark and maim them while pulling/hammering. The good news is, I've always managed to get them out and I've yet to need to replace a bearing. The INA bearings seem to be quite durable.
    What puller do you use? Maybe there's a better tool out there than my inventory.
  90. #90
    A bit off topic, but what is the best you guys have found to remove bolts with stripped head (that are pretty stuck). I bought a used Delirium a while back that had several stripped out bolts (like the ones that hold the dropouts in place. They are nice and snug, but I'm going to strip my bike and get it powdercoated, and need these out!
  91. #91
    Penetrating oil and an EZ out? Failing that, you might have to resort to the drill...
  92. #92
    Apr 2005
    Quote Originally Posted by arkon11 View Post
    I rounded out one of these on my D-T. I used a nail puller, gripped it into the bolt head and turned, it worked surprisingly easy!!! I tried to drill it out first, but those bolts are very hard.
    Here is an image of a nail puller so you know what I'm talking about: http://thumbs4.ebaystatic.com/d/l225...xPl_u3p9Qg.jpg
    Finding spare bolts was easy, my local specialty fastners shop had them in 12.9 grade and they were cheap so I bought enough to replace the lot if needed down the track.
  93. #93
    Quote Originally Posted by Boyd and fiends View Post
    Good to hear, mine aren't so far gone that I can't get them out but I'm going to replace them before I torque to spec.
    I'm thinking maybe the reason they are stripped is that the torque sheet on the Knolly website is for the DT, and lists 17 Nm, but the Delirium torque specs listed here give 9 Nm.
  94. #94
    How did you manage to get the nail puller around the bolt if it's recessed? (Like the knolly bolts are)
  95. #95
    formerly shabadu
    Nov 2006
    Quote Originally Posted by Buzz View Post
    Before resorting to EZ out I like to try jamming a closely sized standard size hex wrench in there if possible, sometimes tapping it in a bit. If that doesn't work, I try something similar with a Torx wrench. If those fail, then it's EZ out time.
  96. #96
    Apr 2005
    The bolt I had rounded out, was one of the drop out bolts for adjusting the chainstay length (as I mentioned I have the older D-T model). This bolt isn't recessed.
    ...sorry I just looked at the newer Delirium and realised it uses completely different bolts!
  97. #97
    Yebo Numzaan
    Reputation: Muttonchops's Avatar
    Its been a three year love affair and still going strong
    Time to give something back..full bearing replacement. I have never dabbled with bearings in the past..but after reading other posts and then seeing my lbs tap out the bearings I decided to do it myself. it is super easy...i used a solid piece of steel with a flat head and tapped gently in a circle all the way around the inside rim of the bearings. Popped out. To put the new ones in...i found that if i seated them by tapping lightly with a small hammer...i could then use my improvised bearing press (M6 bolt + piece of cut off handlebar + various washers) and they popped in perfectly. LBS charged me $50 a while back for the two main bearings on the Endo...this is so easy. To remove the bearings on the linkages - i used my vice, a bolt with a big head and piece of old steer tube (1.5?) to push the bearing out through the steer tube.
    Earlier in this post there was mention of using a 'soft jaw' vice to clamp the rear axle when the bolt gets stuck. I made a quick soft jaw for my vice with some rubber flooring i had. Drilled some different size holes in it. I had tried for a day to work out how to get that sucker out.
    <a href="https://www.flickr.com/photos/davemutton/15377542474" title="Knollyfest by Dave H, on Flickr"><img src="https://farm8.staticflickr.com/7582/15377542474_a21044d406_z.jpg" width="480" height="640" alt="Knollyfest"></a>
    the soft jaw
    <a href="https://www.flickr.com/photos/davemutton/15999139102" title="Untitled by Dave H, on Flickr"><img src="https://farm9.staticflickr.com/8571/15999139102_5c9d3dba68_z.jpg" width="480" height="640" alt="Untitled"></a>
    I support EMBA
  98. #98
    May 2014
    Awesome. Great description and great pics. Way to get it done!
  99. #99
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    Well done!
    What are you using as your soft jaws? Looks messy.
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
  100. #100
    heaven help me
    The other trick is to drill a hole in a block of wood the same size o.d. as the axel, cut the block in half and place the 2 pieces of the block in the vice with the axel. You won't scratch the surface and it gives you a really good purchase.
  1. Tips and Tricks for setting up tubeless
    By 007 in forum Wheels and Tires
    Last Post: 09-13-2014, 12:07 PM
  2. Etrex 30 - your tips and tricks please
    By iggs in forum GPS, HRM and Bike Computer
    Last Post: 07-29-2012, 05:09 PM
  3. Black Magic; Tips and Tricks
    By leshaghal in forum All Mountain
    Last Post: 07-20-2011, 01:21 PM
  4. Angleset Tips & Tricks for a V10?
    By IntenseMack10 in forum Santa Cruz
    Last Post: 04-27-2011, 02:23 PM
  5. Frequent gear changes tips or tricks
    By WW1022 in forum Singlespeed
    Last Post: 02-17-2011, 05:42 PM
Members who have read this thread: 10
