Results 1 to 11 of 11
    Hope ProII - rear hub conversion
    I'm contemplating switching from a 2010 to a 2012/13 Endorphin and trying to work out what parts I could swap over.
    I know the new frame requires a 142x12 hub and my current Hope PROII is 135/QR but
    http://www.chainreactioncycles.com/M...?ModelID=68578 shows two different product IDs for "12mm Bolt Thro" v "X12 Thro"
    I'm not anticipating using a Maxle rear end, in case this is relevant so which one would I need to order?
    Reputation: qbert2000's Avatar
    you want x12 that is for 142mm rear ends. there is a standard 12mmx135mm axle too.
    Reputation: Calhoun's Avatar
    Nov 2008
    Here is the one you need:
    BTI | Hope Pro2 R hub convert kit, 12x142mm T-A
    The conversion is pretty easy and you might look at replacing bearings while you have the hub apart.
    Bandoleros Crew, NM
    Quote Originally Posted by Calhoun View Post
    yes, it is called the x12 conversion in that description from bti as well. same part from crc
    Hope Conversion Kits Pro 2 X12 Rear | Buy Online | ChainReactionCycles.com
    the "x12" designation refers to syntace's name for the 142mm system.
    Syntace
    Reputation: wilks's Avatar
    What qbert said and takes all of 5 minutes to do the swap.
    Reputation: Bullit_cn's Avatar
    I been into the same questions before,
    ProII will takes a lot of things to change not only the axle if you wish to convert it into 142x12
    Only the ProII Evo is convertible with a simple axle or adaptor change,
    When trails gets tougher, Just stand up and deliver.
    Yeah, should have been a bit clearer...it is an Evo...
    Qbert & Calhoun part mentioned below are correct then
    Nov 2008
    If it is a Pro II EVO than this is what you need:
    https://www.bti-usa.com/public/item/HT5863
    at least that is how I understand it from reading this thread:
    Hope Pro 2 Evo conversion 12mm
    Bandoleros Crew, NM
    That link above is only the adaptor for 12x135 converting to 142,
    The link of Qbert below is the axle conversion from 9/10x135QR into 12x142
    at least that is how I understand it too
Hot Deals
Contests
Latest Mountain Bike Articles
