    Help!!! knolly endorphin direct mount fd bolt size
    I got a shimano fd m675 e2 for my endorphin but it came without screws! I tried to fit some leftover rotor bolts. One did fit although a bit tight, but the other won't go in. Do you guys know the size of these bolts? Are they available in bike shops or do I have to go to a screw hardware? Thanks
    Reputation: G-AIR's Avatar
    Is your frame painted or raw? There could be some paint on the threads. If not rotor bolts should fit. Rotor bolts, water bottle bosses and the FD all use the same size screws.
    Hi g-air! Thanks for the info. I got mine in day glo yellow. Im scared to mess up the threads so I dont wanna force it in. But yeah, the hole on the left went in ok with the rotor bolt. But the right hole wont go. I'll try to remove some paint. Thanks.
    Jan 2009
    had the same issues with my blue endo,,, defo the m5 rotor bolts mate,,,, just turn the bolt slowly to face off any paint in the holes, once its gone in once it will go in and out very smoothly,,,
  1. Replies: 75
    Last Post: 04-13-2015, 02:44 PM
  2. Shock mount bolt size on 06 RFX?
    By Tidybeard in forum Turner
    Last Post: 05-26-2013, 04:15 PM
  3. Direct mount front derailleur and chainring size
    By nounours in forum Cannondale
    Last Post: 12-10-2012, 07:11 PM
  4. direct mount chain guide??? to replace direct mount der
    By TwoNin9r in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-14-2012, 05:36 AM
  5. Replies: 4
    Last Post: 08-22-2011, 04:46 PM
