Results 1 to 9 of 9
    Heaviest Chili Contest
    Finally weighed mine last night. Piss on lycra.
    36 lbs 14 oz
    Edit to please CharacterZero: my build updates
    Large ano black
    Rear Shock: Cane Creek Double Barrel, steel coil
    Fork: Marz 66 RCV, straight 1 1/8" steerer, steel coil, Avalanche cartridge
    Headset: CC 40 Inset
    Rims: Mavic 819
    Hubs: King
    Tires: Conti Trail King 2.4 UST front and Mtn King UST rear
    Stem: Renthal Duo 50
    Handlebar: Chromag OSX with lizard skins grips
    Seatpost: Specialized Command Post BL
    Cranks: XT w/ 34t Salsa ring & E13 bash
    Pedals: X-Roc for AM and 26 Prerunner for FR
    Cassette: used 11-32 something
    Rear Derailleur: Sram x9 short cage
    Shifter: Sram x9
    Chainguide: E13 DH
    Brakes: Hope V2 with organic, free range, cross dressed, slotted, tapped, and dyed 203mm rotors
    Quote Originally Posted by B Gillespie View Post
    36 lbs 14 oz
    Ha! Mines prob around 35. Doesnt matter to me one bit though
    Pivoteer
    Reputation: tiSS'er's Avatar
    Only about 34lbs. The Chilli does carry it's weight well though.
    Employed by Pivot Cycles - www.pivotcycles.com
    Reputation: Buzz's Avatar
    Wow.....my Delirium weighs less than that, and with no stupid light parts on it either....
    I think there should be a disclaimer: forced fork admittance.
    Haven't seen much mention of that 66 here, Gillespie!
    34.5 lbs with BOS Idylle SC (coil) and DB air. Soon to be fitted with my old Stoy coil shock, so the weight will go up to around 35 lbs. The longer term plan is to fit XX1 which should shave off about 1.5 lbs, although this is not the main reason for going 11 speed.
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    Currently 35.5 lbs when I have my Avy'd Marz 66 on it.
    I have 2008 Preston FR at about the same weight. Both are great going down hill, but the Chili is hands-down easier to pedal uphill.
    "sounds like you need to find a better mechanic..." -- Calhoun
    Reputation: wilks's Avatar
    Mines heavy when I'm on it. But lightish without. 32 lbs but its 1x10 and no gravity retarder post.
    Around 37
    66, 823s, Minion DHF, etc.
    Nick
