Results 1 to 9 of 9
    Reputation: bionicman's Avatar
    Fox RP23 vs CCDB air
    Can anyone expand on the ride quality differences?
    si vis pacem...
    Reputation: Parabellum's Avatar
    Oct 2011
    CCDB is infinitely more tuneable, and offers a plusher ride - closer to the feel of a coil shock. If you're a "set it and forget it" kind of rider there is nothing wrong with the RP23, and it's lighter. You will find the ride to be harsher and probably more difficult to dial in to that "perfect" feeling.
    ccdb has a wide range of adjustment, if you need it
    wrt the rp23 the 17mm sag setting in the 57mm travel (~30%) will be slightly too soft for really heavy hits, but will climb amazingly and will have great small bump compliance.
    when you stiffen the rp23 to a bit less than 30% sag, you will lose a tiny bit of the activity in the rear end but the bike will still climb great as always. Pump it up too much and have too little sag and youll start to notice a loss in performance and it will skip over small stuff.
    with the ccdb (AIR OR COIL) you will be able to have more sag and not go through as much travel on big hits, and still manage to get the small bump compliance...BUT...you have to spend a fair bit time dialling this in, its not a 2 minute job and if you get it wrong it wont be as good as the rp23.
    i think that the sweet spot for the rp23 is strictly 27% to 28% sag (aim for 15.5mm). check the rp23 pressure after every outing to keep it dialled in.
    anyone else got anything on this?
    Reputation: Calhoun's Avatar
    Nov 2008
    sounds about right.
    No time on a RP23 on my Knolly. But I will say the base settings outlined at the Cane Creek website and the dialogue provided by Knolly take a lot of the mystery out of tuning the DB. And you can "set and forget" the DB Air, but you will be rewarded by making small adjustments.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Reputation: beefmagic's Avatar
    What others have said is pretty accurate. I would add that the CCDBair has more mid-stroke support and is a generally more active feeling shock. High speed performance through rocky terrain is much more controlled and composed than the Fox.
    Thank you for the input. So I guess the question boils down to is the extra weight of the ccdb air over the rp23 worth it for a enduro race bike? Basically offering a slightly more controlled ride.
    As my experience with the rp23 shock has me leaving the shock active on the climbing & turning the pro pedal switch on for the downhills for some g out or low speed compression so it is not blowing throu it's travel.
    Nov 2008
    the performance gain is worth the negligible weight gain.
    -cabra cadabra
    Quote Originally Posted by bionicman View Post
    BOS Vipr would be another option.
    Quote Originally Posted by loamranger View Post
    Its simpler than the CCDB and very very good.
    Back to the CCDB Air, the question is 'cost', sure if youve got the money, bag the performance gain, if on a budget, then the RP23 is a light and capable solution.
  1. Replies: 7
    Last Post: 08-13-2012, 05:54 PM
  2. Push my RP23 or wait for the CCDB air
    By bashtee in forum Shocks and Suspension
    Last Post: 10-28-2011, 02:17 PM
  3. Fox RP23 kashima vs. standard coating RP23
    By ban in forum Shocks and Suspension
    Last Post: 08-31-2011, 10:34 PM
  4. 2012 Fox RP23. Match '09 RP23 OEM Rebound/Compression settings...
    By Scottyman in forum Shocks and Suspension
    Last Post: 06-24-2011, 04:47 PM
  5. Endo - ccdb or just rp23
    By zod in forum Knolly
    Last Post: 02-28-2011, 11:52 AM
