Results 1 to 37 of 37
    Reputation: mrgto's Avatar
    First Look at Knolly w a few questions
    i have been looking for a new bike lately. I am on a Morewood Shova St. i was looking for something with a little more travel. I just happened across a few threads about the Chilcontin and it looks very interesting. I would generaly would ride this bike xc/allmtn (whatever that is), but the terrain that i ride is very rough east coast with fast rough downhills, but nothing huge like out west. i guess my question is would this be too much of a bike for what i am riding? Now granted, Windrock downhill trails (youtube has a few vids of the place) is about 15min away from my house, but at this point my Morewood is just not enough to get around up there.
    Just testing the waters, thanks for any input or advice.
    Btw, all kitted up im about 250lbs How does this bike handle big guys suspension wise. does it blow thru travel or is it hard to tune shox to ride correct?
    RideDirt
    Reputation: aedubber's Avatar
    It will handle it without a doubt...
    Biking Like Crazy!
    Reputation: blcman's Avatar
    mrgto, if you used a coil rear shock on the Chilcotin then it will rule for you. I don't think any air shock works well for big guys.
    The 4x4 suspension works well with either air or coil and the frame is very stiff and well built.
    2017 Niner Rip 9 RDO Pushed Version!
    2015 Ibis HD3 w/ Push ASC3
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    I am not worried about the frame not being burly enough for my weight, I just wondered if the anybody heavy had any luck running air shocks. I want to try and keep the weight down. I have had good luck with the manitou ISX 6 air shock on my Shova so just curious.
    Reputation: Calhoun's Avatar
    Nov 2008
    Have you read this thread:
    Chilcotin compared to Enduro
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Thanks for the heads up Calhoun! i didnt think that thread would be of any use, but further in there it answerd a few questions.
    Also, how does the bike go on slow tech climbs?
    coil
    Nice KOM, sorry about your penis.
    Nov 2012
    Quote Originally Posted by mrgto View Post
    My Chili's HA is almost a degree below stock in slack mode (my preferred choice) and it still climbs steep tech extraordinarily well.
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    The Four X 4 linkage makes going up tech great (less tire slip and more front end control) and down tech even better. You'll clean things that you never could before.
    "sounds like you need to find a better mechanic..." -- Calhoun
    Nov 2008
    the Chil will climb anything you have the legs for.
    -cabra cadabra
    Perpetual Hack
    Reputation: mykel's Avatar
    and the neat thing is so will the Delirium.
    Its climbing ability only runs out when the rider runs out of legs.
    ...pretty much a standard Four x 4 trait.
    michael
    Hatched in 1964
    A Dirtbag since 1969
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    Looks like a Chili is in my future! Now to convince the wife! Just wish i could size one.....
    I was considering the Ibis Mojo HD because of the adjustable setup, but i am not carbon friendly. I have more than one ding in my down tube of my Morewood so i am trying to stay away from carbon. Looks like the Chili is what i need to do it all.
    Quote Originally Posted by Mrwhlr View Post
    coil
    I think the ccdb-a will do me just fine.
    I would love a coil, but with my weight it would weigh a ton! I am not springing for a Ti coil either.... I would rather spend the money on brakes or a avy cart for the fork.
    Reputation: bubba13's Avatar
    At least that weight is at the center of the bike. You won't even notice the difference when you are riding the bike. My Chilcotin is over 36 pounds now because it eats chunk for dinner.
    I have tried the DBair and now have an Avalanche Woody on my Chilcotin. The DBair worked ok, but it was a compromise on the Chilcotin for me. Chilli+big rider+chunky terrain=COIL. I still have the DBair, and I would recommend it if you were building an Endorphin.
    Portland Off Road Navagators
    Quote Originally Posted by bubba13 View Post
    Well if I went coil I would look into a vanilla RC from avalanche. What's the word on that setup?
    RideDirt
    mrtgo the word is that it works ! Ill take that CCDB air shock off your hands if you dont want it ? I got a fresh Van RC with only about 3 rides on it if you want to do a swap . All you got to do is send it to Craig at AVY and hell custom tune it all to your personal specs.
    Get a coil. Seriously - air cannisters present a catch-22 for bigger riders.
    Good small bump compliance, bad bottom out problems.
    Good bottom-out resistance, shitty small bump compliance.
    You are just being stubborn sticking to the air can. You are doing yourself no favors here.
    Trust me, I've weighed in at as much as 240 (currently 210) and have tried air on several designs.
    Yeah, I am just worried about weight, but truly I could loose a few pounds and that would make up for it.
    Is there any comparisons between the CCDB and avy'd vanilla on this bike? I like the idea of having all the knobs to fiddle with on the CC.
    Delirious Tuck
    Reputation: thefriar's Avatar
    I'm same weight range, on Chili with CCDB-A. No issues on east coast riding including a day at Highland, two or three days at Mt creek, 4 days at whistler and one on the North Shore... plus plenty of long techy New England rides around CT and MA.
    As others have said, your legs are the determining factoring in bikes climbing ability. Its a technical mountain goat.
    If you're not doing lift serve DH... the Endorphin might be more than enough bike for you...
    Well I like the idea of the chili because we have some good DH trails right in my back yard @ Windrock Mt. Everybody shuttles it plus they do some grassroots racing there. I think the chili would be perfect there. My wife wants to move back out west so I would be hitting North Star up if we moved.
    If I can swing it I might try and spec the bike with a ccdb-a and see if I could snag a coil off somebody and give the a head to head to compare for myself. Lot of guys running ccdb here because of cc being so close.
    What is everybody thoughts on running 160 vs 170 up front, esp with regards to front end lift for climbing steep tech stuff?
    Answer to above
    170mm or 160mm fork for my chilcotin??
    Delirious Tuck
    Then the Chili is your bike. Adjustable BB makes a huge difference between flowy DH trail ripper (low) and comfy in the tech (high).
    Difference between the 160 and 170 external lower cup is very minor for climbing. Noticeable improvement on DH for me. Went from 160 RLC to 170 RC2 and the cartridge alone could be the difference.
    If you are a Fox guy, you could save some weight up front with 160 RC2 vs the shortened 180. The difference is about 1/2 pound between the two. Flip a coin...
    Do a search, you'll find plenty of good things to day an not a single bad one.
    FWIW, my Avy'd Van RC with ti spring is less than 100g heavier than my DB Air was.
    Quote Originally Posted by thefriar View Post
    Agreed. Loved this feature on the Delirium, love it still on the Chilcotin.
    I'd love to make it up to Windrock at some point. I grew up in TN and have family in both Nashville and N. Ga.
    Thanks for all the advice! I'll keep you guys posted on the progress. With baby #2 otw ill be on a budget.
    Is there any major changes between 2012 and 13 frames?
    Nov 2008
    I think one colour was added for '13
    -cabra cadabra
    Knomer
    Reputation: Dusty Bottoms's Avatar
    Technically, we don't do 'model years', and any revisions are made 'on the fly' between production runs.
    Next production run colors will be: raw, ano black, day glo yellow, and limited edition orange(one run only). These will be shipping in about 90 days.
    Director of Sales: Knolly Bikes
    Biking Like Crazy!
    What, no 3-D rockers! Was that only a rumor.
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    Thanks for the answers.
    What is the deal with this elusive rocker arms I have been hearing about.
    Now to try and size one and find a good deal!
    Nov 2008
    Looking for similar help as I'm almost ready to pull the trigger on a Chilcotin. I live in South Florida, therefore, there are no Knolly dealers close to where I live. I'm only aware of two authorized online dealers (Bike Bling and DropnZone). Can someone recommend any of these or maybe other ways I can order one. Thanks!
    Nov 2008
    Quote Originally Posted by ibasso001 View Post
    ohh by the way, I'm looking for a medium black ano with Fox CTD
    Call Chad at Red Barn Cycles in Hamilton, MT. I would also upgrade the rear shock to a Cane Creek (coil or air).
    my waight is about 95 kg and im with db air
    the bike handls everything that exicst out there i never felt out of trevel due to the amaizing mid support
    mine is about 14.6 kg size L
    not an xc bike.....
    Donkey Puncher
    Reputation: VanGor44's Avatar
    Ive had no isssues with the Air set up at all... check out this post I did back when I was 240# kitted up.. All the parts came off a mojo HD...I evolved to a chili!!
    2012 Chilcotin vs Mojo HD
    PS: Nice GTO...I happen to own one as well...cant shuttle bikes in it (mind you, it probably could fit about 25 of them in the trunk)
    Quote Originally Posted by VanGor44 View Post
    Thanks! It was my first car i ever owned. I bought it when i was a Junior in high school for 3k! Still have it
    I just found out i am having baby #2, so i am going to have to just drool at this point. I dont think the wife will spring for a new bike this year.....
    Thanks for all the info, ill def keep and eye on what Knolly is up to. My next bike purchase will def be from them!
    Reputation: EnduroBob's Avatar
    Mar 2013
    Also check out Wrench Science: Custom Bicycle Builder Online - Road, Mountain, Cyclocross, Track Parts, they got a nice custom configuration tool. The sales guy Brian is also very helpful in making sure you get what you need.
  1. Replies: 75
    Last Post: 04-13-2015, 02:44 PM
  2. db air out from the knolly box
    By loolilon in forum Knolly
    Last Post: 01-05-2013, 09:47 PM
  3. Knolly Chilcotin Questions?
    By mayha in forum Knolly
    Last Post: 06-08-2012, 05:53 PM
  4. What is going on at Knolly?
    By telebiker in forum Knolly
    Last Post: 09-20-2011, 05:30 PM
  5. Knolly dog
    By Muttonchops in forum Knolly
    Last Post: 08-22-2011, 06:19 AM
