Results 1 to 7 of 7
    Reputation: bionicman's Avatar
    Enduro Chilcotin build: STOKED!
    Giving some time before I trim the steerer tube & lines for ergonomic adjustments - you can take length off but not add after THE cut...
    Frame : M Chilcotin
    Shock : CCDB air
    Fork: Fox 34 Talas 120/160 27.5 (good luck getting one now)
    Wheels: Hadley/Crest 27.5 front 26 rear
    Tires: Kenda Nevegal
    Drivetrain: XX1 1x11 ceramicBB
    Brakes: Avid X0 Trail 160mm rotors
    Seatpost: KS Lev 125mm
    Stem: Thomson 70mm
    Bars: Boobar 30"
    Weight: ? 30lbs? +\-
    The best handling mountain bike I have ever ridden.
    Thank You Noel!
    Somewhat surprised that a manufacture does not offer 27.5/26 specific geometry? You can control a two wheeled vehicle with rear wheel traction is compromised but not front. Has nothing to do with roll ability it's traction management.
    I will not bore you with geometry numbers but short story is geometry is very close with the 5 or so mm of additional trail that the fork offers over 26" 160mm Float.
    Pm me for development engineering employment inquires... ;-)
    sorry for blurry image..
    Interesting with the 27.5 front. Haven't seen that before. Love the xx1 though
    Nov 2008
    bionicman, are you riding in steep or slack mode?
    Quote Originally Posted by ibasso001 View Post
    I actually use both quite often, depending on where I ride. That was one of the reasons I used the C frame vs the Endorphin frame, the adjustability. Even thou its a 1lbs heavier option.
    It's a subtle difference but its almost like having 4 bikes in one with the Talas.
    I am becoming somewhat frustrated with the talas thou. For the $ fox gets for these I expect high/low speed compression/rebound adjustment instead of an idiot 3 trail switch. The CCDB shocks coil/air are awesome.
    Shinobi-Wan Kenobi Moderator
    Reputation: kristian's Avatar
    I'm intrigued... I want to do two forks on my chili and I'm struggling to figure out how I want to do it. I'm not too stoked about the idea of adding another tire size though since I've already got 26 and 29ers. I wonder how crazy the idea of a 69er Chilcotin would be.... A Totem is 565mm and a 150 mm 29" Pike is 561mm. Hmmm...
    I just caution to keep geometry very near Noel's design intent
    a 29r front is too much of a mismatch of rotational mass - don't waste your time or $
    When have you ever bought two same size tires for a dirt bike?
    FYi- 29r tubes work just fine in 27.5 wheels
    More to the point, it would be too tall and slack with the extra tire/wheel height. Still, I'm trying to think out of the box...
  1. Chilcotin compared to Enduro
    By Cycle64 in forum Knolly
    Last Post: 05-26-2014, 10:24 PM
  2. Knolly Chilcotin or Specialized S-Works Enduro?
    By Fadl in forum All Mountain
    Last Post: 02-19-2013, 05:28 AM
  3. Chilcotin build weights
    By fatwheeled in forum Knolly
    Last Post: 10-02-2012, 11:15 PM
  4. Replies: 8
    Last Post: 09-30-2012, 08:54 AM
  5. Chilcotin Build up 'PIC OF THE DAY'
    By rdhfreethought in forum Knolly
    Last Post: 04-06-2012, 09:52 AM
