    Endorphin/ high volume air shock
    So what kind of performance characteristics are going to come from running a standard RP23 as opposed to a high volume rp23 on an endorphin? The shock will be more progressive?
    I have 2 endorphins in the family...should I put the standard size can on the medium frame w/ 150lb rider and the high volume can on the small frame with 115lb rider? Or ditch the standard can completely for a second high volume can?
    Reputation: nybike1971's Avatar
    Quote Originally Posted by LaXCarp View Post
    Yes, put the high-volume can on the Endo for the lighter rider. The way you ride, you most likely will prefer the more responsive ride of the small can.
    Bigger volume canister has a less progressive air spring with a more pronounced hammock effect in the mid-stroke, while the small volume canister gives an air spring that ramps up faster. If you find that with a reasonable amount of sag you just can't get anywhere close to full travel, you may want to consider the large can (and perhaps shim it to achieve a happy medium).
    Awesome, thanks for the insight...you are a great resource when it comes to suspension! You are right, I might benefit from the increased progressivity of the low volume sleeve on my set up. The rear end of my bike has felt a bit lagging when I have gone to pop off a lip or over a set of rocks/roots...I was attributing this to slowing my rebound down a couple clicks this year but maybe it is just the shock not ramping up enough when I push into it?
  1. low volume conversion for monarch rt high volume.
    By RobinGB in forum Shocks and Suspension
    Last Post: 11-28-2012, 02:26 PM
  2. Replies: 20
    Last Post: 08-24-2012, 03:41 PM
  3. High volume 26?
    By spadmike in forum 27.5
    Last Post: 08-21-2012, 02:16 PM
  4. standard volume or high volume ?
    By smaxor in forum Turner
    Last Post: 09-20-2011, 10:51 AM
  5. Which is higher volume: AVA or new RP2 (high volume canister)?
    By kapusta in forum Shocks and Suspension
    Last Post: 05-31-2011, 02:56 PM
