Results 1 to 8 of 8
    Endorphin G2 Crank Length?
    I bought a 180mm XT crankset from CRC for my Endorphin Gen2, then noticed that my original 3x9 set had 175mm cranks.
    Is 5mm going to make a huge difference? Should I send it back and exchange them for the 175mm?
    Reputation: F.N.G's Avatar
    I would. Less pedal strikes.
    Depends on terrain, but I barely get away with 175mm where I am. ..the ends of them are hammered from strikes.
    Dec 2012
    anyone on 165 or 170s?
    I just put 170's on my Warden. Only one ride so far, but so far I like them.
    Reputation: rdhfreethought's Avatar
    Yes, it will be a huge difference.
    I run 165 on my Podium (like everyone else) and have plenty of rock strikes.
    170mm on my DJ bike
    and 170 and 175 on my Chilcotin. I run my Chilcotin in slack mode now due to the 180mm fork and am fine with either 175 or 170 cranks. I like 170 better though.
    Not sure what I would want for an Endo. I have never even heard of someone running 180mm cranks, I figured they were for 6'6" and taller folks.
    I would return them and get 170, unless you think you need 175
    Regional Race Manager, Knolly Bikes
    Washington, Montana, Idaho, South Africa
    FWIW, I would say the difference going from 175's to 170's is similar to my first ride on a 27.5 bike. At first you notice something is a bit off, but not necessarily better or worse, just different. Then 15 minutes later your used to it and it's no big deal.
    I rode about 17 miles and about 3k worth of climbing my first (and only) day on the 170's, and I paid really close attention to see if I could tell a difference. Honestly the only thing I noticed was they seem to spin better. I'll probably stick with 170's from now on.
    BC
    BC is offline
    Reputation: BC's Avatar
    I run 170 on the Chilcotin to reduce pedal strikes.
  1. Crank arm length.
    By Noyac in forum Enduro Racing
    Last Post: 08-02-2014, 05:20 PM
  2. BB shell length / crank spindle length for HiFi 29?
    By bisicklay in forum Gary Fisher
    Last Post: 01-11-2014, 04:41 PM
  3. Endorphin - length of your steerer tubes?
    By sinfony78 in forum Knolly
    Last Post: 02-12-2013, 03:48 PM
  4. Crank arm length
    By maleonardphi in forum Families and Riding with Kids
    Last Post: 08-02-2012, 02:56 PM
  5. Small Endorphin brake line length
    By Couloirman in forum Knolly
    Last Post: 03-27-2011, 06:05 PM
