Endorphin Fox CTD
I finally built the Endorphin up. No trail time yet. However, I have been riding it around the neighborhood dialing it in. I am finding that I need to add a lot more air pressure such that is doesn't blow through its travel.
With the correct sag, if I bunny hop , it blows through the travel and is harsh. With a lot more air pressure and a lot less sag, it rides much better.
This seems to be opposite to what others are stating with their FOX CTD. Most seem to keep it in D mode.
""This seems to be opposite to what others are stating with their FOX CTD. Most seem to keep it in D mode.
 Originally Posted by nhodge
yep, that is my question
It doesn't seem to have much mid-stroke support.
did ya experiment w/ the 3 settings?
Were the CTD shocks suppose to remedy this situation? It seems like this is a common theme the Fox Float rear shocks.
With that being said I find actual trail time is the only to get a true feel for the shock. Maybe the shock will perform better once on the trail and up to speed. It seems I can always blow through travel in the driveway with single big hits.
Hope you have better luck on the trail. Looking forward to hearing your impressions.
TG
Dude,
Deflate the shock and open up the air can(only a couple inches, do not pull it all the way off) and make sure there is a volume spacer installed. The spacer will look like an oversized white lifesaver sitting at the bottom of the can. Let me know.
 Originally Posted by Dusty Bottoms
Dude,
Thanks - I will check.
I tinkered with the Fox CTD with different settings and it has the progressive donut in the canister. I wasn't able to get it to work the way I wanted to on this frame. I agree with others that you mostly run it in "D" mode. It works well in the rough stuff so long as you keep the wheels close to the ground. I hit one little drop (ie 1 foot) or less and clank.
The T mode works but it bit harsher. C is basically lock out. For me to use the shock such that I didn't bottom out, I was running 20% sag. This provided better mid-stroke support, but a bit harsh, not overly bad though.
I feel the Fox CTD shock has a strong affect on the bike characteristic. I would like a little more mid-stroke. I like pumping my bike on the trail - it keeps me loose and helps in corners, etc. It one of the attributes of the Knolly bikes that I really enjoy. Pumping the Fox CTD blows through too much travel.
At this point, no reason to discuss the shock anymore. I sold it and I bought a PUSH Monarch RT3. They have a few left - talk to Nick mention me (Jamie), as I explained what I am looking for.
I have great luck with PUSH Monarchs. The PUSH Monarch on my Delirium is awesome ( I will discuss this more when describing the Endorphin). I had trouble with the RP23 on the Blur TRC (ie no mis-stroke support), swapped it out for DSP coil (better), and finally had a PUSH Monarch PLUS - which was hands down the best and I highly recommend. However, the Blur TRC geometry didn't fit me. The new Endorphin geometry is awesome (again will discuss more after a few more rides).
Thanks for the update Jamie. Disappointing that the Fox CTD didn't work better. Let us know how the Pushed RC3 works.
Which fork are you running on your Endorphin?
"If it didn't hurt when you screw up, it wouldn't be half as exciting when you dont." cdburch
I've been having the same issues with the new Endo using the Fox CTD. When I first got the frame, Knolly was recommending 110psi for my weight, and I quickly bottomed out on a 2ft drop. I put in the volume spacer, and pumped up the shock to maybe 115, but could still pump the bike all the way through the travel on flat ground.
I noticed Knolly has increased the recommended pressure, but in order to get the bike to feel right, I am running a little higher than that still. I always ride on D, with the trail setting at 1 to get the dampers as open as possible. This seems to be working, but I agree that there isn't much mid-stroke support. Took it off a 4-5ft drop without a hard bottom-out though, and it feels about right when I'm riding even though static sag is less than 25%.
Interesting comments here. I'm running 120psi in the CTD shock which is giving me 30% sag rolling along on the saddle at climbing height, on flat street. I weigh 145-150 lbs ready to ride. I have yet to get full travel on the trail riding somewhat aggressively over rocky terrain and I have hit a few small drops, 2'ers at speed while flowing along. I would actually like it to be easier to pump into turns to get it lower and loaded -- Since I've added a couple extra clicks of rebound it's firmed up the compression some taking away from this. I've been running it in D-2. BTW I was told that the 1-2-3 setting has no effect on the dampening when the shock is in D.
Good to know that I am not the only one. Thanks for the follow-up. From my understanding, the numbers only modify the compression in the Trail setting. I could be wrong.
2013 Fox float 36 RC2 at 160mm. I am waiting for pieces to reduce the travel to 150mm.
It actually doesn't feel bad at the 160mm, but I prefer to keep it in the recommended travel range.
international reports seem to suggest that CTD is rubbish with T working best...
Ugh, I just picked up an new Endo and its always great to hear that the spec'd shock is crap and is going to need to be changed What are the general thoughts about a CCDB or CCDBA on this frame?
not my opinion, read the press...but if you don't like to fettle then maybe it's good? depends what youwant? i run a bos deville on my current bike that blows fox out of the water...
I think its going to take some time for these thoughts to develop. I turned a couple clicks of rebound and it changed the shock quite a bit. There are different sized volume reducers to play with too. Giving up on it after a ride, or not riding it at all may be too hasty a decision.
The Deville looks like a nice fork. Is there US service or distribution for Bos? Can the Deville be reduced to 150 if necessary?
I debated for some time to even post this. After the initial post and folks saw that I was selling the shock (intelligent group on this forum), I was getting some pings about my next move.
If you run the shock with more air pressure and less sag, it works well. However, this troubles me, because Noel on many occasions states - set the sag first and get this right before moving on. Therefore, if I have to compensate for the sag for the shock behavior, I feel that I am off to a bad start.This is why I avoided the DB air, too many people stating the need to run a lot more sag to get the correct shock performance.
For me, I had similar issues with the Blur TRC - not a direct comparison. I now know what feels good to me and what doesn't. I don't waste time as I have X number of days to ride, because of work, family, etc.
I was probably a bist hasty. I had my reasons. PUSH is not making any new Monarch shocks, once they sell their inventory that is it. I figured it was best to sell a new shock for a slight loss and get a custom shock that is going to increase my enjoyment on the bike. If PUSH had an endless supply, I would have waited a bit longer.
Just checked the shock settings and went for another ride. My riding weight is about 140, and I've got 130psi in the shock, which is a little above the recommended pressure. This gives me only 20% sag, but any bouncing on the pedals quickly puts me into the travel. This setup seems to be working well for me.
Interesting how many frames are coming out with screwed up shock tunes. Doesn't really make a difference if it is Fox, RS, or Cane Creek. Sounds like the manufacturers spend tons of time working with the suspension engineers to get the shocks just right, then they go to production and are delivered something totally different. I highly doubt Noel & Dusty gave the thumbs up to the shock that is being shipped with the new frames. I know Dave Turner has had issues with Rock Shox with the Burner 650B shocks, the one I rode at Ibike was horrible, turns out it was the wrong tune supplied by Rock Shox. Fox has spent so much on the CTD crap which is basically the same technology as the RP3 right? Three positions, one firm, one in the middle, and one fairly wide open for descending. Those that were at Interbike saw all the trail signage installed by Fox everywhere for what position your shock should be in for the upcoming section of trail, it was kinda stupid funny. All for renamed technology from 5 years ago.
I think there is a bit of difference and I want to make this clear. A custom tune shock versus stock shock is going to be different and should be a lot better. If I wanted a better shock from the start, I could have opted for DB air. I didn't want the DB air because of some of its issues. I wanted to try the Fox CTD knowing in the back of my mind there was the PUSH option. In addition, when talking to PUSH you need explain to them exactly what you are looking for in the shock.
A stock shock is a stock shock for some people with a certain riding style, weight, etc - this is going to work well. I may be too heavy for the optimal shock setting.
The same can be said for the Fox 34 CTD versus Fox 36 float. I prefer the heavier more tunable fork. However, I think most people and I know a number of my riding friends are better suited toward Fox's CTD fork and shock - keep it simple. Even now I hop on my friends bike and turn a few knobs and they are like wow. By no means am I an expert and I can confuse myself , but I have tinkered enough to know what I like and don't like.
I don't want folks freaking out that the CTD on the Endorphin is horrible and not to get the bike. Could I have lived with the Fox CTD - yes! Because of I rode an RP23 on a different bike, it hard to say whether the CTD is better, worse or the same.
It is just once you have ridden some very good products, you seek to obtain a similar performance. I have been riding a custom shock on my Delirium for a long-time and I want the same performance on the Endorphin. Since I know there is a better product within my reach that will give me the ride quality that I desire I am going for it. Those also looking for a little better performance from lightweight air shock - there is an option.
This can be said for almost every bike part.
I agree with you, the PUSH Monarch is amazing, too bad they arent making them anymore. The whole thing behind air shocks is that they are tuneable for all weights of riders by adjusting pressure, albeit wont be perfect if you are on either end of the spectrum. They should change CTD to KISS "keep it simple stupid"
kiss "keep it simple stupid"
haha
How much do those PUSHED Monarchs cost?
- You may not post replies
- You may not edit your posts
Forum Rules
