Results 1 to 3 of 3
    Nov 2014
    endo shock bushing size?
    will the bushings that are currently used on my DB inline fit for the avy'd fox ctd that's on the way?
    Cane creek used different sized bushings than the standard used by everyone else. Buggered if I know why
    Braaap
    Reputation: DirtMerchantBicycles's Avatar
    May 2014
    The Inline uses "standard" 1/2" eyelets, all other current CC shocks use 14.7mm eyelets. Buggered indeed.
    I wouldn't suggest pressing out the DU bushing and reusing them. Get new ones, they are dirt cheap. However, I suspect you're actually asking about the reducer hardware. In which case, you can reuse/swap it if the Fox has the old metal DU bushings (not the new poly bushings).
    Dirt Merchant Bicycles
    Providing unrivaled support and unbeatable pricing on all cycling goods to riders near and far.
  1. Shock bushing size - Measured on Spartan AL 2015
    By petercarm in forum Devinci
    Last Post: 11-01-2015, 01:53 PM
  2. 2010 Altitude RSL shock bushing size?
    By magicmike1 in forum Rocky Mountain
    Last Post: 04-04-2015, 12:48 PM
  3. Mission 27.5 rear shock bushing size
    By Strife21 in forum Diamondback
    Last Post: 11-12-2014, 11:07 AM
  4. Rear Shock mounting bushing size help
    By Camera Man Kevlar in forum All Mountain
    Last Post: 06-11-2014, 12:57 PM
  5. Replies: 7
    Last Post: 06-25-2011, 06:57 PM
