Results 1 to 7 of 7
    Endo CCDBA and Water Bottle Cage
    Anyone know if you can still fit a water bottle in the '12/'13 Endo with a CCDBA? On my medium, there isn't much room even with the CTD. I don't want to lug around a pack for local rides if I can avoid it.
    Jan 2009
    if you dont want to carry a pack, i think you can get bar mounted bottle cages,,,
    as you say there isnt much room down there, so with the ccdba im not sure it would fit,
    Perpetual Hack
    Reputation: mykel's Avatar
    Just received my large endo frame with ccdba-cs
    Was wondering if there was any consensus reached as to a bottle cage that may fit.
    Hatched in 1964
    A Dirtbag since 1969
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    Aug 2005
    I don't know if this helps, but I'm trying to figure this out on the large chilcotin right now. The ccbda cs hits the water bottle in the cage and pushes it out slightly. I think I need to come up with a custom mount for the cage in order to fit. My wife ran the cages(tri?) under her seat for while- she lost a lot of bottles, so I don't want to resort to this option again. Let me know if you have an easy solution.
    May 2010
    I've got a x-large warden that a double barrel cs and now a RS debonair . Each shock hit the bottle ; or the switches did rather . I rigged a system that holds my bottle on the downtube ... Only solution unless you get an inline shock.
    Perpetual Hack
    One thought I did have, is to find a cage that is close, then elongate the mounting holes to give a bit more clearance...
    ..or make up a mounting plate, that bolts to the frame and the cage bolts to it....
    Hatched in 1964
    A Knomer since 2007
    Knolly Podium
    Knolly Delirium
    Knolly Endorphin
    I put a Speialized Zee cage on my L Chili and a bottle fits without any contact on my CCDBA. That said, I may put a small washer between the cage and frame as the brake line on the one side tweaks the cage slightly.
    "Lightweight , durable , inexpensive
    Pick 2."
  1. Jet 9 RDO Water Bottle Cage
    By tneker in forum Niner Bikes
    Last Post: 06-05-2013, 04:15 AM
  2. Water bottle and cage or camelback?
    By stygz1 in forum Trek
    Last Post: 08-02-2012, 10:27 PM
  3. 575 water bottle cage
    By jeffw-13 in forum Yeti
    Last Post: 04-30-2012, 04:06 AM
  4. How to add a water bottle cage?
    By SIKOSYC in forum General Discussion
    Last Post: 07-06-2011, 01:44 PM
  5. Water Bottle Cage Bolt Won't Come Out...
    By Kaparzo in forum General Discussion
    Last Post: 05-12-2011, 01:16 PM
