Results 1 to 10 of 10
    Delirium Main pivot bearing removal.
    Hello,
    After getting sick of the creaking, I decided to strip down my Delirium and give her a little love. I was able to remove all of the other linkage bearings (using a Transition's bearing tools), but I'm at a loss on how to remove the main pivot bearings.
    If anyone else has done it, please chime in. Thanks
    Reputation: Big B's Avatar
    Nice graphics!
    '04 Knolly VTach | '15 Knolly Podium | '16 Knolly Delirium
    Reputation: Buzz's Avatar
    Ive done it on my wife's endo. I tapped them out from the backside using a socket extension. There was enough of a lip that I could catch it with the blunt edge. Just work your way around slowly and tap gently and they should pop out!
    On an additional note, you can source bearings from Enduro rather than the Knolly ones. Save yourself a bundle in the process. Those main pivot bearings are double row caged ball bearings, so tough to clean and re-assemble. I managed to clean them up nicely, but they were still too rough when I pressed them back in.
    The Enduro bearings are ~$16/ea. The Knolly specc'ed ones are anywhere from $40-$90/ea depending on where you get them (if you can get them). I think the Deli needs 4 (or is it 6?) of them, so it adds up quickly!
    Reputation: Dude!'s Avatar
    Bearing puller is ur best option. I bought one a few years ago as well as bearing installer, should have done it years ago. No worries of frame screw ups and with the correct tools it is super easy to perform. One downside all your buddies will bug you for it or ask you to do it.
    LWK
    LWK is offline
    my 2010 Endo is creaking a bit so am taking things apart to see whats up. Any tricks to get the axle/sleeve out of the these same BB pivot? I got the left side bolt off easy enough but the sleeve just spins in place... thx!
    Quote Originally Posted by LWK View Post
    Squirt a little telfon lube on both sides of the sleeve and then let it sit for a while. Then re-install the bolt about half-way or get a longer bolt and tap the bolt with a plastic/rubber mallet.
    Basically, the bearing corrodes a bit to the sleeve. When I re-install the sleeve, I apply a very, thin layer of grease to avoid this.
    Reputation: bionicman's Avatar
    I used a harbor freight bearing puller on my Chilcotin
    Bionicman, do you by any chance know what puller you've used?
    Bearing Pullers, Flywheel Pullers and Puller Tools
    I was looking through those, but I'm at a loss on which one to purchase?
    Quote Originally Posted by arkon11 View Post
    # 95987 that's the ticket
    - 20% off HF coupons to be had everywhere..
    Reputation: qbert2000's Avatar
    you want the blind bearing puller
    Blind Hole Bearing Puller - Needle Bearing Puller
    or one like this. i found one for about $60 before. i just searched quickly to find this. i'm sure there are better prices out there. decent kit. life saver sometimes
    New Slide Hammer Blind Bearing Bushing Remover Removal Seperator Puller Set Kit | eBay
  1. Flatline Main Pivot Bearing
    By ChunkyMonkey in forum Rocky Mountain
    Last Post: 06-12-2013, 10:42 PM
  2. 575 main pivot bearing removal?
    By VaughnA in forum Yeti
    Last Post: 01-21-2013, 11:39 AM
  3. 575 Main Pivot Removal
    By GS_Ken in forum Yeti
    Last Post: 08-02-2012, 11:05 AM
  4. Main pivot bearing source?
    By experiment70 in forum Trek
    Last Post: 04-19-2012, 05:51 AM
  5. Replies: 4
    Last Post: 07-01-2011, 09:17 PM
