Delirium Builds!
62K views 203 replies 72 participants last post by  mayha
#1 ·
Seems like it is about time for a dedicated thread for 2010+ Delirium builds. Post your photos/info here if you've got one.
#183 ·
Great build socalMX - fairly light but still robust. You are going to have a blast with it. Curious to hear about the Monarch PLUS.
I haven't updated my Delirium in a while - sits at 33.5lbs. I am adding some new components in the near future that drop some weight:thumbsup:
#2 · (Edited)
Here we go...
Frame: 2010 Med Raw Delirium
Shock: 2010 CCDB w/RCS Ti Spring (400#)
Fork: 2010 Lyric 170 DH 1.5"
Wheels: I9 Hubs laced to Syncros DS28 Rims
Tires: F/Maxxis Ardent, R/Maxxis Advantage
Brakes: Formula "the Ones" F/180, R/180
Shifters: SRAM X9 triggers
Pedals: Twenty6 Ti Platforms
Cranks: Truvativ Hammerschnitzel AM
Chain: SRAM PC971
Cassette: SRAM 990
Rear Derailleur: SRAM XO Short-Cage
Front Derailleur: NA
Chainguide: NA
Seatpost: Thomson Masterpiece
Seatpost Collar: DKG
Stem: Twenty6 F1.5
Handlebars: Chromag Fubars
Headset: Chris King 1.5
Grips: Sunline lock-on
Seat: Chromag Lynx Ti
Build weight: ~36.5lbs
#7 ·
Great looking builds so far!
As for me I finally got it the way I want it. Might still do some other pedals but need more $!
Frame: 2010 Med Raw Delirium POLISHED...by me
Shock: 2010 Fox DHX Air
Fork: 2011 Fox 36 Talas 160 RLC Kashima Tapered
Wheels: Hope Pro 2's with EX500's, double butted spokes
Tires: F+R Maxxis Minion 2.5 EXO 60
Brakes: Formula "the Ones" F/203, R/203
Shifters: SRAM X0 triggers
Pedals: MG1's
Cranks: Race Face SIXC
Chain: KMC X9 SL
Cassette: XTR
Rear Derailleur: SRAM X9 med-Cage
Front Derailleur: SLX
Chainguide: MRP LRP
Seatpost: Thomson Elite 410mm
Seatpost Collar: Chromag
Stem: Chromag Ranger
Handlebars: Chromag Fubars OSX Chrome
Headset: Cane Creek xx tapered
Grips: Knolly Lizard Skins
Seat: Selle Italia XC
#9 ·
Here's mine
Bicycle tire Bicycle wheel Tire Bicycle frame Wheel
Medium Ano Black frame,
CCDB,
2011 Fox Vans 180mm,
Formula the ones with goodridge hoses,
Saint cranks, rear mech and shifter,
Azonic 38t ring,
XT cassette,
E13 LG1+ chainguide,
Straitline pedals,
Element reducer head set,
Straitline spilt steerer stem,
Gravity DH carbon bars,
Lizard skins grips,
Thomson post,
SDG Saddle,
Chromag clamp,
Hope pro 2 hubs,
Sun Ringle EQ 29 rims,
Maxxis Highrollors 2.5,
#98 ·
My baby after a winter of dieting..
Wheel Tire Bicycle tire Bicycle frame Bicycle wheel
Wheel Tire Bicycle wheel rim Bicycle tire Bicycle wheel
Medium Delirium, Push Monarch RT-AM, 12mm through axle
Lyrik Solo air 1.5 fork
Cane Creek 110 1.5 headset
Thomson x4 stem
SMAC handebar
Avid Elixir CRs (8" front, 7" rear)
Lizardskins Charger grips
SDG Aliso Ti saddle
Thomson elite seapost
Azonic seat clamp
HammerSchmidt FR 165mm
SMAC pedals
Sram pg-990 cassette
Sram x9 rear deraileur
Sram x0 shifters
Hadley rear hub
Hope front hub
Mavic 819 rims
WTB Weirwolf front tire, Wolverine rear
35 and change lbs. this is AM mode. I still have the Totem (converted to coil) and the Vivid for the big mountain days. saving the pennies for a beefier wheelset and 2 ply tires.
#111 ·
CZ - sounds like you are running the same Totem setup as me. Floodgate mod etc. You really like running the compression all the way open? I was happy with my previous settings - 1 preload spacer which gave me 30% sag and I would typically run 8-10 clicks of LSC then 11/2 turns of HSC to control BO on the biggest hits. I cant say I spent too much time playing around with the settings and this is what felt okay.
After riding my Jedi with a Boxxer I really struggled to enjoy the softer plusher Totem. So I went on a mission this past month and I have really spent time to get my Totem dialled. First thing I did was pop another preload spacer in but this didnt really help give me that Boxxer feel. So I found a section of trail that I have really been enjoying lately. Fast, narrow and the right amount of chunk to let me be comfortable and feel the bike out. After multiple runs I have ended up with 2 preload spacers giving me 25% sag, 12 clicks of LSC and almost 2 turns of HSC. This was also a result of reading thread lately about the tendancy to run too little compression.
I started out with 1 turn of HSC and played with the LSC from 6 clicks then to 12 to get a really good comparason. Then I played with 10 and on to 12 etc. At the end I did another run with 6 and jumped to 12 to be sure of what I was feeling. Lastley I played with HSC. When I started long travel riding I thought the objective was for plushness but I always ended up adding compression. What I found running this recent test was when I lowered my compression settings the bike felt plush but through the chunk I had less control. The front would be diving alot like a pogo and through corners I was much less precise. When I added LSC the bike seemed to settle/calm down and my cornering was much tighter. I dont fell like I am working so hard to control the bike, another bonus seems to be that I can get the bike off the ground easier when I need to double a section. My next step is to remove 1 spacer but I am still testing.
Just interested to hear your reasoning for running your Totem so open. I must also added I have just dropped my tire pressure by 2 Psi and this also made a massive difference, 26Psi front and 28Psi rear. Running the suspension firmer and tires softer seems to be the ticket for me.
#154 ·
Knolly has bearings, but you can also get bearings from RWC. No one in our group (5 Delirium riders) has bent a hanger yet.
As folks have said, the Delirium is an amazing bike. I can't ever see selling my Delirium. I love this bike so much I had it re-painted 6 months ago. This has been my primary bike since I got it. I ride with other Delirium riders, Santa Cruz, Turner, etc. Most of the time, the Delirium riders are near the front on climbs, but we are always at the front on the descents:thumbsup:
It seriously is great bike that will make you smile!
Bubba13's comments are a perfect summary of the Delirium!
#180 ·
Here is probably one of the last builds for a dying thread! This is a whimpified build on Craigs old frame! :thumbsup:
Frame: Delirium (Large)
Shock: 2013 RS Monarch Plus RC3, have the Ti-coil Dueler for lift days!
Fork: 2012 RS Lyrik RC2DH 170
Headset: Cane Creek
Handlebar: Easton Havoc carbon
Stem: Easton Havoc 50mm
Grips: ODI Rogue
Shifter: XT
Brakes: XT IceTech
Seat:WTB Silverado Thinline
Seatpost: KS 125mm
Rotors: IceTech 203mm F 180mm R
R Der: XT
Cassette: SRAM PG990 (11-34)
Chain: SRAM 991
Crank: XO carbon 170mm
Chainring: MRP Bling Ring direct mount, 36t
Chain Guide:MRP G2
Wheels: 2013 Mavic Crossmax SX
Tires: Hans Dampf
Pedals: Straitline Amp
Weight ~32.5lbs...(hey, its my do all!)
#3 · (Edited)
Okay, I'll add mine.
Frame: 2010 XL Raw Delirium
Shock: Fox RC4 550# coil
Fork: RS 2010 Totem DH coil 1.5" and Marz 2009 66 ATA 1.5" w/ new lowers (thank you Crankworx!)
Wheels: AM set: Mavic Crossmax SX; DH set: Mavic 721, Hope 340 hubs
Tires: F/Maxxis Minion DHF 3c 2.5, R/Maxxis Minion DHF 60a 2.5 (both AM and DH set)
Brakes: Hayes Aces 200mm F/R
Shifters: SRAM R X0 / F X9 triggers
Pedals: Kona WahWahs paint stripped to raw to match!
Cranks: RF Atlas FR 170mm cranks
Chain: SRAM PC971 (have a PC991 Cross step on standby)
Cassette: SRAM 980
Front Derailleur: Shimano XT E-Type
Chainguide: Blackspire Stinger E
Stem: RF D2 50mm 1.5"
Handlebars: Chromag Fubars OSX Black Chrome
Headset: Cane Creek XXII 1.5
Grips: ODI Rogue
Seat: Chromag Trail Master
Build Weight: ? (maybe 38-39#)
Bicycle tire Tire Wheel Bicycle wheel Bicycle wheel rim
#4 ·
Frame: 2010 L Blue Delirium
Shock: Fox RC4 450# coil
Fork: RS 2010 Lyric DH 160 - 115mm Coil U-turn
Wheelset: Mavic Crossmax SX
Tires: 2.4 UST Rubber Queen
Brakes: Formula the One
Shifter: Sram X.9
Pedals: Welgo Mag-1
Cranks: Truvativ Stylo OCT
Chain: KMC X9SL
Cassette: SRAM 990
Rear Derailleur: SRAM X.9 Short cage
Front Derailleur: Front Derailleurs are for road bikes.
Chainguide: MRP Mini G2
Seatpost: KS i900
Seatpost Collar: no name
Stem: Thomson 70mm
Handlebars: Truvativ Hollzfeller Worl cup
Grips: Lizard Skin
Seat: WTB Vigo
Build Weight: ? About 35
Tire Bicycle part Rim Crankset Bicycle
Bicycle part Bicycle wheel rim Bicycle drivetrain part Bicycle tire Crankset
Tire Wheel Bicycle fork Bicycle part Bicycle wheel rim
Tire Wheel Bicycle wheel rim Bicycle wheel Bicycle accessory
Bicycle accessory Bicycle part Line Bicycle Bicycle frame
#6 · (Edited)
  • Frame - 2010 Knolly Delirium large CCDB 500lb spring black ano
  • Fork - Rockshox Lyric DH coil 170mm Xfirm spring, 1.5 steer
  • Headset - Cane Creek XXII
  • Stem - Felt 70mm
  • Bars - Race Face Atlas FR
  • Brakes - Hope Tech M4, 203/185
  • Grips - Ergon GX-1
  • Saddle - Specialized rival
  • Post - Crank Brothers Joplin 4 lever
  • Clamp - Crank Brothers Split QR Seat Collar
  • Shifter - X9
  • Derailleur - X0 med
  • Cranks - Truvativ HammerSchmidt AM Crankset
  • Chain - SRAM PC991 9spd Cross-Step PC-II
  • Cassette - Sram PG990 11-34
  • Pedals - Time Atac Z's
  • Rims - DT EX500 (5.1's)
  • Spokes - Dt Swiss comp, black
  • Hubs - Chris King, rear HD funbolts, front 20mm
  • Tires - Continental, Trail King/Rubber Queen
#10 ·
my baby..
Tire Wheel Bicycle tire Bicycle frame Bicycle wheel rim
Bicycle tire Tire Wheel Bicycle wheel rim Bicycle frame
Bicycle tire Tire Bicycle wheel Wheel Bicycle wheel rim
Medium Delirium, Vivid coil, 12mm through axle
Totem Solo air 1.5 fork
Thomson x4 stem
Easton Monkeylite DH
Lizardskins Peaty grips
SDG Bel Air RL saddle
Azonic seat clamp
SMAC Innovation pedals
Sram x0 shifters
Hadley rear hub
Hope front hub
Syncros DS 28 rims
Specialized Clutch control tires
#11 ·
Just got mine
Med 2010 Delirium black ano w/ RC4 and 12mm thruaxle rear
Marzocchi 66 RC3
Cane Creek XXcII headset
Hope Mono M4 brakes w/ floating rotors (8"f,7"r)
Deity Dirty 30 bar (cut to 28")
SRAM XO trigger shifters
Shimano SLX fd
SRAM XO rd
ODI Ruffian lock-on grips
Thomson X4 50mm stem
Thomson Elite seatpost
Selle Italia Flite ti saddle
Salsa seatpost clamp
E13 DRS chainguide
Gravity Light crankset
Twenty6 rallye ti pedals
Hadley / Sun MTX33 36 spoke wheelset
DH tubes
Maxxis Minion DHF/DHR 2.35 tires
As built, it's a hefty 38.8 lbs (frame itself was 10.8 lbs with steel spring).
I have a set of Industry 9 Enduro wheels and a ti spring on order to lighten things up a bit for local trails.
#12 ·
Hey Ride Everything,
When you pulled your shock out you re-installed it upside down. Flip that baby over!
P.S. I love all of this bike porn. I got a chance to take a 2010 blue delirium with vivid/ Float 170/ xt brakes/ slx cranks and some other trick bits out for a spin today on Fromme in North Vancouver. Soooo much fun! If I didn't already have a Podium and was lined up for a endorphin I would get one asap.
#13 ·
... because it doesn't fit with your aesthetics of how the bike should look?
Remember I'm a tall person with a big bike (XL) so I can put that shock in there any way I please.
#14 ·
It lowers the centre of gravity the other way round, not by much, but that's the reason everyone else runs it that way
loving the raaaawww
#15 ·
Oh, and I thought it was because the smaller frames couldn't accommodate the piggyback in the upwards position because the shock would come in contact with the frame.
As for lowering the centre of gravity by, possibly, a few grams - ...
*edit*
-- the rest of my comments have been deleted because I felt that they were far too sarcastic --
#16 ·
4 useless posts....keep them builds coming
Frame: 2010 Med Blue Delirium
Shock: 2010 Vivid/Nukeproof Ti Spring (350#)
Wheels: 2011 DT Swiss EX1750
Tires: F/Maxxis Ardent, R/Maxxis Ardent
Brakes: Shimano XT F/200, R/180
Shifters: SRAM X9
Pedals: NC-17 Sudpin III
Cranks: Shimano SLX
Chain: SRAM PC971
Cassette: Shimano XT
Rear Derailleur: SRAM X-9 Short-Cage
Chainguide: E13 SRS+
Stem: Thomson 45mm 1.5"
Handlebars: Chromag OSX
Grips: Odi lock-on
Seat: SDG Ti-Fly
35.2 lbs
