Results 1 to 13 of 13
    gmx
    gmx is offline
    Nov 2006
    Delirium 1x10 or?
    I'm currently riding on a 1x9 delirium but need to replace the r derailleur. I like the look of the 1x9 and never really had a problem climbing except for some really steep or extended stuff that left me punched for the descent. My options are to go 1 x10 w/ a 36t cassette and a 32/34 up front or to switch to a f derailleur.
    My concerns with the 1x10 is will the extra 2 teeth be enough and as I usually ride to the trail head, will I be hurting for more power on flat paved sections. And with the f derailleur it is are the chain retention systems available able to secure the chain as good as the straightline I have on there now?
    I mostly pedal up but ride the park quite often in the summer. Anyone switch back to a f- derailleur from a 1x10. Or have any experience with the dual retention systems?
    Reputation: Dude!'s Avatar
    Quote Originally Posted by gmx View Post
    Skip to the chase and go SRAM 1x11. It will cost some coin. Take a look at SRAM website - they have a few videos. NSMB did a nice review. It seems like the future. It should allow frame designers more creative freedom.
    A couple of bonuses - no chain drop, less tension, an extra gear for big climbs.
    MRP - makes a bashguard only for protection. This will drop a bit of weight all the way around.
    gmx
    gmx is offline
    Nov 2006
    Quote Originally Posted by Dude! View Post
    That looks awesome. The 10 -42 cassette seems like a sweet spot....BUT its way out of my way out of my price range. $425 for the cassette - yikes!
    Reputation: bubba13's Avatar
    I switched from 1x9 32-34 to 1x10 32 front 36 rear and it made just enough difference on the Delirium to be worth it. I am able to do most of our climbs if I am feeling strong that day. No chain slap with the short cage Zee plus (clutch) and MRP 1x.
    I do have to say I like the 2x10 on the Chilcotin though. 11-36 out back with 26/36 rings up front cover anything I want to ride. With the MRP LRP and a mid cage XT plus derailleur (with the clutch), the chain slap is minimal.
    Setting up the Chilcotin with a front derailleur is easier and has much better cable routing than the Delirium. Doubt I will ever put a front D back on the Delirium.
    Portland Off Road Navagators
    Reputation: Bullit_cn's Avatar
    Time will tell
    My intended setup fro my upcoming Chilco would be a 34 front and 11-36 rear,
    I will find out soon if the 34f/36r is manageable or a good compromise for climbing
    I like to try the simplicity of a single ring up front too
    When trails gets tougher, Just stand up and deliver.
    MC MasterShake
    Reputation: woodyak's Avatar
    Quote Originally Posted by Bullit_cn View Post
    I've been pushing that combo for a few years now. I had it on my Delirium before the Chilly. If anything it's made me a stronger rider. Considering going with a 36t upfront next.
    gmx
    gmx is offline
    Nov 2006
    Quote Originally Posted by bubba13 View Post
    I was thinking of the same 1 x 10 set up. You doubt you would put a front D back on the delirium because of the cable routing issue or just prefer the 1x10?
    Cable routing under the bottom bracket with a slot guide did not work out so well. I also prefer the 1x10 on the Delirium. When the climbing around here gets really steep and loose/slick, I just hop off and walk with this bike.
    Reputation: Buzz's Avatar
    I have honestly never considered anything but 1 x 10 on my Delirium. I run a 31T front and 11-36 cassette and can get up most things I need to. I will add that most of the climbs on the Delirium are fire roads, but I do find it able to climb some moderately tech/steep stuff as well.
    gmx
    gmx is offline
    Nov 2006
    Quote Originally Posted by Buzz View Post
    Cheers.I can usually get up the most things w/ 1 x9 but usually feel punched at the end of a harder climb. I'm hoping the 2 extra teeth will bring the punch down to a slap.
    3x9, big ring is bash ring.
    Nice KOM, sorry about your penis.
    Reputation: socalMX's Avatar
    Wow, with the 31t front, do you feel yourself struggling to gain/maintain speed on flatter trail sections? My upcoming setup will be 36t x 11-36 rear to start with. Thinking I might end up with a 34 front soon. I ride a lot of fast single track at times and need speeed...
    Quote Originally Posted by socalMX View Post
    There are very few 'flatter' sections up here on the Shore, which is where I ride my Delirium the most. Whistler would be the second most common place to ride it. I chose the gearing specifically so my old, slow, arse could get up the fire road and still have enough energy left to enjoy the downs!
    If I was going to be pedalling singletrack more, it is possible the gearing wouldnt be right, but it works well for where I use it!
    Cheers
    Buzz
Hot Deals
Contests
Latest Mountain Bike Articles
