Results 1 to 11 of 11
    db air out from the knolly box
    just received my chilcotin!!!
    is the db air arrived tuned from knolly out from the box?
    i know that it's a lot of digging what's the optimum setup?
    Cane Creek DBAIR Suspension Base Tunes
    That is the laziest answer for the laziest search! I'd tell you more, but I don't have that shock.
    Welcome to the club
    yessss
    I guess you're absolutely right!
    There are no shortcuts
    But still ...one tip.. something...help..
    well ill start form the sag.....
    Reputation: Calhoun's Avatar
    Nov 2008
    Quote Originally Posted by loolilon View Post
    yessss
    you can get buried in this thread:
    Chilcotin: The inevitable DB-air setup thread
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    yessss
    1. get out adjuster tool.
    2. turn knobs and note settings out of box.
    3. compare to the site i linked you to above.
    4. decide which you want to run, if they don't match
    5. set sag.
    6. ride/bracket.
    I think it's a very good shock. Took alittle time to tune it. I haven't got it that different than the set up advised on the cane creek website.
    I think I might need the high volume sleeve though like some others have got. I can't use all my travel. I've got maybe 15mm of unused shock shaft.
    Can anyone comment on this?
    Reputation: knollybikes.com's Avatar
    Quote Originally Posted by tom34 View Post
    Hi Tom34:
    Please see my comments here regarding CCDB-Air upgrades:
    You do not need the larger air can, but you should look to have the inner air sleeve replaced under warranty. You can contact Cane Creek to find out who is the closest authorized service centre to you.
    Cheers!
    Noel Buckley
    www.knollybikes.com
    Instead of PMs, please contact me here.
    Quote Originally Posted by knollybikes.com View Post
    Hi Tom34:
    Cheers!
    Wow cool thanks for that Noel! I'd also like to say thanks for making the best bike out there I love the chill!
    I'm very happy with the CCDB air shock but when I got on my friend's delirium with CCDB coil I was blown away by how much better it was. I just felt like it was tracking the terrain going down that much better. Having said this i'll ask cane creek for the inner sleeve like you said and see how that goes. Cheers!
    For what it's worth, Dusty and Noel have commented that the shock is designed with 2.25" of travel, but the shaft length is 2.5". Their comments are #'s 271 and 275, and can be found here: Chilcotin: The inevitable DB-air setup thread.
    do you need to change the inner sleeve for a brand new chill that arivved to me yesterday?
    Reputation: wilks's Avatar
    Probably not
