Results 1 to 5 of 5
    Chilcotin Upper Shock Bolt
    Snapped the bolt, sheared just where the thread ends. Lucky that everything held together and only discovered back at the car park when I noticed the bolt hand backed out.
    I was wondering if this has been a common issue?
    I bent mine pretty bad. Opted to buy the new linkage with the shorter bolt. I think a few other guys on here have broken or bent them pretty bad. Check the thread about the new 3d rockers that's on here.
    Reputation: qbert2000's Avatar
    That is why knolly went 3d rocker. They actually use a very high quality bolt bit it is long and only 6mm. 3d is the way to go and the way it should have been originally imho
    Knomer
    Reputation: Dusty Bottoms's Avatar
    Please email me with pix of the bolt, and the serial number of the frame, and we will get you sorted with any replacement parts you need.
    kevin AT knollybikes DOT calm
    Quote Originally Posted by loamranger View Post
    Director of Sales: Knolly Bikes
    Quote Originally Posted by Dusty Bottoms View Post
    Ok thanks Kevin. Your CS is great.
  1. 2010 Enduro Upper Shock reducer/bolt play
    By PRCVT in forum Specialized
    Last Post: 05-27-2017, 11:18 AM
  2. Replies: 3
    Last Post: 07-08-2013, 04:55 AM
  3. 2012 Stumpy FSR Upper Shock bolt? Loctite?
    By stumpynerd in forum Specialized
    Last Post: 06-14-2013, 06:04 AM
  4. Trance X broken upper shock mount bolt
    By 661lee in forum Giant
    Last Post: 03-15-2012, 04:14 PM
  5. Stuck upper shock bolt
    By twangcat in forum Turner
    Last Post: 03-03-2012, 05:50 PM
