Results 1 to 10 of 10
    Pivoteer
    Reputation: tiSS'er's Avatar
    Chilcotin and Endorphin: A 6 month review (x-post from AM)
    KNOLLY Chilcotin and Endorphin: A 6 month review
    X-Post from the AM forum for your reading pleasure.
    Employed by Pivot Cycles - www.pivotcycles.com
    Reputation: Calhoun's Avatar
    Nov 2008
    The only question left unanswered is which color is faster. You said that Endo is a purpose built trail slayer, but how much of that is built into that yellow? Would the Chili be faster if it was yellow?
    "Mi amor Nuevo Miťrcoles!"
    -cabra cadabra
    Nice write up, thats helped alot in differentiating the Endo from my Chili. Thanks.
    Reputation: bionicman's Avatar
    Nice review ;-)
    TSC
    TSC is offline
    Buehliever
    Reputation: TSC's Avatar
    Excellent job. Well written; and you let the pictures tell a story that most wouldn't believe. I still can't fathom riding up that stuff.
    "sounds like you need to find a better mechanic..." -- Calhoun
    Pivoteer
    Quote Originally Posted by Calhoun View Post
    It depends on the situation. If you are posing, yellow is much faster. If you are riding, raw is lighter and faster. I'll let you draw your own conclusions.
    Great review. The pictures illustrate the points you made very well.
    The question I have is which bike would you use if half of the ride was in South Mountain like terrain and another half was a lot less technical. Talking about 25-30 miles with 6-8K climbing total.
    Jan 2009
    tisser.
    a quick question for you.
    im in the process of building up a endo, im aiming for a lightish build. what do you think of the fox ctd shock, is it any good or is it not worth using, should i swap it out for somthing else. what shock would you recomend as a replacement. if it helps i will be running a bos deville fork, 160mm taperd, thanks in advance mate, ian.
    Pivoteer
    Quote Originally Posted by bike_la View Post
    The Chili is just so fun in the technical stuff. If I HAD to have only 1 bike, it would be the Chili, built lighter. Right now it is 33lbs which is not an issue at all. However, if I were to be riding it for more epic rides, I could easily drop 3lbs from the bike. The Chili rides and pedals very well. I would be hesitant to over build an Endorphin as it would take away from what makes it so special, being light, taught, and super playful.
    EDIT:
    This is really a tough question. I guess it depends on what your riding priority is. The Endo will handle South Mountain, just not as fast or smooth. If you live for the climb, the fast and flowy sections, then Endo might be the right choice for you. If you live for chunk like we do, the Chili can't be beat.
    Pivoteer
    Quote Originally Posted by delirian View Post
    tisser.
    I have no issues at all with the CDT. I run it in descend mode all the time. Other than experimenting, I have never run the shock in the trail mode. I'm not sure I would change the shock out for another option. The Fox is so reliable, the dampening works, and the rebound on the CDT works better for me than the previous RP23 I was on. There is absolutely no wallow, yet ramp up is nice and smooth without even a hint of spiking. This is a pretty confident statement considering I am running the pinnacle of shocks on my Chili.
    Not to mention the new Fox hardware is the best out there IMO with the DU bushings.
  1. Santa Cruz Superlight 29 One Month Review
    By JasonHH in forum 29er Bikes
    Last Post: 01-28-2015, 05:32 AM
  2. KNOLLY Chilcotin and Endorphin: A 6 month review
    By tiSS'er in forum All Mountain
    Last Post: 01-25-2015, 10:47 PM
  3. Satori, 2-month review, and a new look
    By Blatant in forum 29er Bikes
    Last Post: 01-18-2013, 11:18 PM
  4. Canfield Crampons 6 month review = they are solid
    By YoPawn in forum Downhill - Freeride
    Last Post: 09-28-2012, 02:48 PM
  5. Haro Beasley SS 6 month Review
    By Angus in forum 27.5
    Last Post: 02-15-2011, 07:05 PM
