Results 1 to 33 of 33
    Chilcotin Chain Drop
    Hi all,
    Since I built my Chilcotin up I've had a problem with the chain dropping when shifting from the 3rd or 2nd smallest cog to the smallest cog on the sprocket.
    I'm attaching some pictures to illustrate the situation:
    Chilcotin Chain Drop-img_20130922_144437.jpgChilcotin Chain Drop-img_20130922_144512.jpgChilcotin Chain Drop-img_20130922_144524.jpgChilcotin Chain Drop-img_20130922_144731.jpg
    2 bike shops and 3 bike mechanics later the situation persists.
    Because the only new part on the drivetrain was only the chain I was thinking that perhaps the RD and the sprocket were the problem since they looked pretty worn out (got about 1,300 miles on them). So today I got a new sprocket and a new RD + shifter, put them on and... same thing. The chain would randomly drop when shifting.
    My setup is:
    Shimano XTR M970 crank, Hope BB w/ 1 spacer on drive side, Race Face single chainring 34T, MRP G3 chainguide, SLX sprocket 11-34T, Saint M820 RD, XT chain, Hope rear hub.
    Any help would be appreciated. I'm totally clueless on this.
    Reputation: honns's Avatar
    I assume you've adjusted the stop screw on the derailleur so it cannot swing past the last cog?
    Reputation: rdhfreethought's Avatar
    I recently had this problem. The Stop Screw on the derailleur, as mentioned above, was backing out. It was a Saint 10sp with clutch similar to yours. I ended up putting blue locktite on the screw, and that stopped the problem. It took me a few weeks to diagnose the problem, since I did not think those screws were able to do that. Maybe it is the clutch putting a much larger spring rate on the RD than other derailleur types. At least your paint is still in good condition...mine, not so much.
    PS: Killer Orange Chilly, by the way! I love that color!
    Regional Race Manager, Knolly Bikes
    Washington, Oregon, Montana, Idaho, Wyoming
    Yebo Numzaan
    Reputation: Muttonchops's Avatar
    Quote Originally Posted by honns View Post
    Picture #2 looks like its off to me. Screw in the 'high' limit screw.
    I support EMBA
    Quote Originally Posted by Muttonchops View Post
    And find a new mechanic. This is basic stuff for a bike mechanic.
    Jan 2009
    as the others have said,,, make sure the limit screws are correctly set,,,
    check mech hanger isnt bent,,,,,
    check cable tension,,,,,,
    Thanks for all the replies.
    Yes we did adjustments to the H limiter screw until it was real tight but after a couple of tests in the parking lot chain still dropped from time to time especially when doing multi-release shifts from 3rd to 1st.
    Tried a new mech hanger. Same thing. Also checked cable tension.
    Tried with and without the mode converter. Same thing.
    Will try the blue loctite as suggested by rdhfreethought.
    Still baffled but again, thanks for all the suggestions.
    Reputation: bionicman's Avatar
    Quote Originally Posted by B Gillespie View Post
    +2..
    Reputation: Bullit_cn's Avatar
    Quote Originally Posted by bionicman View Post
    +2..
    +3...
    H limiting screw not properly set,
    I dont think that screw will loosen itself that fast in a parking lot testing.
    When trails gets tougher, Just stand up and deliver.
    Check for proper chain length too,
    Reputation: KRob's Avatar
    Mine has done this two or three times despite the limit screw being set correctly (my paint did not survive either). The only thing that has stopped it is to adjust the limit screw in too much which makes it so it's very difficult ( in fact it won't most of the time) for the chain to even drop down onto the smallest cog. Not ideal but better than having the chain drop off. Any help/suggestions would be appreciated.
    Isaiah 58:14
    www.stuckinthespokes.com
    Are this happening on Saint RD only or with the other brand too?
    I'm using 10speed X.9 and never encounter this...
    Sounds not a limiting screw problem then???
    Same thing happened to me with an 10 speed XT w/ single chainring up front. Never tried SRAM tho.
    KRob, I once adjusted the limit screw so chain couldn't drop to smallest cog when I was on the trail cause chain kept dropping.
    Reputation: Big B's Avatar
    Could it be that the angle on the chainline is too severe? Maybe the chainring needs a spacer or two to move the chain line into the center of the cassette?
    "My car of choice is a 12 year old civic that runs on the tears of my life choices." - redditor
    wow
    it happend to me with long x9 and with my new xt meduim cage....
    thoght it was the hanger problem....
    but it happend only when i attack in high speed rock gardans style trails...
    and yess no more anodized black....
    Reputation: Sleevem1's Avatar
    This is interesting, I'm runnin the same Saint RD as ranwar and I have never dropped a chain yet on my my xt 2 x 10 setup. I just checked my limit screws and the high limit screw is almost in the exact same position as yours. What shifters are you using? I'm using the saint shifter for the rd.
    I'm using a Saint shifter.
    Just out of curiosity, what rear hub are you using?
    mayby it happned more to a one plate x10....
    and we should Invest more time finding the middle of a chain line
    im going to put the new raceface nerrow wide chainring so I'll start from scratch in an attempt to balance the system....
    Might be M820 - related issue. Have the same derailleur too and it works perfectly with 10sp XTR- cassettes, as well as XT`s. But same problem with SRAM XX1 and SLX- cassettes, shifting is shi*ty from 3rd smallest to 2nd smallest to smallest. Ok when shifting from smallest upwards. No chain dropping, only smooth operation is missing. In my case same happens with Saint and XTR shifters and it`s not either wheel related, XX1 does the same trick with any rear wheel Ive.
    Been too lazy really to find out problem, maybe I have to...
    True in my case. Shifting from 3->2->1 is rough but not other way around. Haven't tried with XTR or XT cassette tho.
    Reputation: mayha's Avatar
    Mar 2012
    This happened to me as well. I fixed it but it was so long ago that I'm not completely positive what I did exactly. I have X9 10sp set up and I believe it was a combination of the limit screws and set screw. Many folks are also having issues with setting up their 10sp drivetrains. I'm a pretty proficient home mechanic and never had issues with 9 speeds. Wish I had better beta for you.
    Quote Originally Posted by ranwar View Post
    I have a Hope Pro 2 evo hub on flow rim. Runnin a XT M771 cassette
    Reputation: jimberjack's Avatar
    I would check on the b-tension screw. If the derailleur is not the right distance from the cassette, you will get weird shifting anomalies.
    post pictures to show rear mech position in the top and bottom gear on the cassette, position will tell us if the chain is the right length.
    if its the right length then might be the chain line...due to front mech being fitted wrong...compare chain line with other bikes so see if you have an unusual angle.
    else your shift limiter on you rear mech is faulty....assuming your Freehub body isn't squint which would be quite unusual. next and final step would be to check the rear mech hanger / frame is straight.
    I doubt any of your so called mechanics can actually spell their job title.
    hope thats work
    some picts
    any thoghts will do.....
    Have you also checked the teeth on your cassette to make sure they are perpendicular? What about the chainline? If three "mechanics" are unable to figure it out, then there is a reasonable chance it is something unusual like that.
    Quote Originally Posted by jimberjack View Post
    I've wondered if this is part of the cause when mine does this. I've posted about this before and no one seems to have an answer, but the b-tension screw on my X9 10 speed will never bring the top pulley closer than 18-20mm from the big cog. It just seems to move it forward and back.
    Pretty sure my chain length is right. Which length will cause it to jump off the small cog? Too long or too short?
    I'll check my chainline but when it's in the middle cogs it looks pretty straight when on the 36t in front.
    I still suspect a derailleur hanger/alignment issue with mine. It has never shifted correctly on the last three cogs. It always skips the second to smallest when high limit screw is set correctly... and hangs up on the second to last when adjusted in too much to prevent the chain from dropping off.
    Isaiah 58:14
    Quote Originally Posted by BryanS. View Post
    3 mechanics plus everybody else that's posted here w/ the same problem. where's somebody from Knolly for this 6 day old thread?
    breezy shade
    Quote Originally Posted by loolilon View Post
    some picts
    pics 1 and 5 make me think the chain could even do with being a bit slacker, maybe put a link or two back in, so the rear mech sweeps back a little bit further. generally the chainline is fine, so everything is set up right.
    if your going off the end the problem is about the derailleur. either its not sitting straight (hanger/frame squint) or the limiting mechanism is goosed. could maybe try a Sram X9 with clutch, that's what ive got and its faultless, never dropped a chain once in the rough, and im running single ring with no front mech and no narrow/wide chainring either. could sell the blackspire chainguide to fund it as it wouldn't be needed / just be adding weight.
    Does this happen in the bike stand, or only when pedaling under load (meaning when your are riding it)? Can you recreate the scenario in the stand?
    Personally, I haven't had this problem....ever. I always use X7/X9 compenents, and just follow the instructions that come with the derailleur. There are only so many things that can go wrong. It's a fairly basic system.
    Cassette loose?
    Chain line off? (though this should make it hard to shift, no drop the train)
    Cog teeth bent?
    Derailluer bent?
    High gear stop screw set properly?
    Hanger bent?
    Derailluer adjusted to the correct standoff distance from low gear cogs (~6mm)?
    What else would there be to check?
    From looking at those pictures, I think that the stop needs to be moved a bunch back in. I usually sight down the gear through the pulley gears and make sure its straight in line at the stop. From the 2nd and 6th pictures, it looks to me as if the derailleur is pulling the chain past the last cog. If I have shifting problems i back off a quarter turn until it goes away.
    Take a pic from the side of the bike in your largest gear, so we can see if your B tension adjustment.
    many thanks for the advice!!!
    ive rode with long cage x9\with x7 it was the same
    this is a brand new xt.....
    again thats happend (to me) only during aggressive rock gardens while riding them fast
  1. Chain Drop Issues
    By EBbiker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-14-2013, 06:53 AM
  2. Chain Drop on RIP 9?!
    By sonoranbiker in forum Niner Bikes
    Last Post: 10-03-2012, 06:53 AM
  3. Chain drop drop off and misalignment a norm?
    By boardrider02 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-03-2012, 01:20 PM
  4. Chain drop on a 1x9
    By otisinLA in forum 29er Bikes
    Last Post: 12-02-2011, 03:34 PM
  5. Chilcotin chain guide?
    By G-AIR in forum Knolly
    Last Post: 08-05-2011, 09:05 AM
