Results 1 to 3 of 3
    Chilcotin CCDBa CS Settings
    I've got my Chilcotin set up with my CCDBa CS, but I'm curious to know what people are running for base settings, as CC doesn't have one up on their site yet. Based on the discussions in an earlier thread, I've used the stock CCDBa Chilcotin settings from CC and turned the LSC and LSR down by 3 and 5 clicks respectively as a starting point.
    What approach have those of you with the CS taken to this?
    Also, is the CS switch an "on or off" type of switch or does it apply the climbing modifications based on the switches position, meaning you can position the switch wherever in its range that you want?
    Reputation: knollybikes.com's Avatar
    This is probably a good starting point. Perhaps reduce HSR and HSC 2 - 3 clicks from the "normal" setting - 3 to 5 might be a bit much, but regardless, you can experiment
    The switch controls a valve, so technically it's not "on or off", but variable depending upon its position. But, it does have detents at each "on" or "off" position.
    Noel Buckley
    www.knollybikes.com
    Instead of PMs, please contact me here.
    Quote Originally Posted by knollybikes.com View Post
    Good to know, thanks.
    By the way, my Chili has a Monarch RT3 and I am interested to upgrade to the CCDB Air CS. PM me if you have one you don't need
  1. ccdba cs for the endo
    By delirian in forum Knolly
    Last Post: 08-01-2013, 10:28 AM
  2. Chilcotin - CCDB Coil - Settings.
    By cfrench in forum Knolly
    Last Post: 07-08-2013, 02:32 PM
  3. CCDBA for TNT Spot?
    By TJR in forum Turner
    Last Post: 03-16-2013, 10:15 AM
  4. bandit29 ccdba
    By KCHT in forum Transition Bikes
    Last Post: 03-13-2013, 07:05 AM
  5. CCDBa or Float CTD?
    By ryan_daugherty in forum All Mountain
    Last Post: 08-06-2012, 11:01 PM
