Results 1 to 7 of 7
    Sep 2013
    Changing rear shock
    Hi
    I am about to change the rear shock on my endorphin and the company I am buying it through mentioned that on the 2013 models they changed the mountings mid way through the year. How do I know which version I have? Is this to do with the 3D rockers?
    thanks
    Has to be the rockers. Looks like you have the older flat rockers.
    Reputation: JHart94949's Avatar
    Dec 2012
    Changing rear shock
    What shock are you going with?
    Sep 2013
    Going to switch the Cane creek inline when it released. What do the new 3D rockers look like? Are they the ones that wrap around the seat tube
    Quote Originally Posted by trickywhu View Post
    Yes. The upper shock bolt is much shorter, and the upper shock eyelet hardware is the same length as the bottom hardware you have now. You can order 3D rocker upgrade kits if you want to go that route.
    Sep 2013
    What benefits do the new rockers offer?
    They provide a stronger interface where the shock bolts up.
  1. Replies: 1
    Last Post: 04-10-2014, 08:32 PM
  2. Changing rear shock please advise.
    By chef7734 in forum Clydesdales/Tall Riders
    Last Post: 12-23-2012, 02:03 AM
  3. Replies: 14
    Last Post: 06-11-2012, 02:03 PM
  4. Changing Rear Shock (slightly longer = huge problem?)
    By asw74 in forum Beginner's Corner
    Last Post: 11-06-2011, 08:38 PM
  5. changing eye-to-eye on a rear shock
    By fudja in forum Shocks and Suspension
    Last Post: 06-16-2011, 07:51 AM
