Results 1 to 2 of 2
    Jan 2009
    ccdba cs for the endo
    so after seeing the recent vid of the endo being put through it's paces, it's got me thinking,
    whats peoples thoughts on the ccdb air cs as a shock choice for the endo,,,
    thanks in advance.
    ian.
    Quote Originally Posted by delirian View Post
    thanks in advance.
    ian.
    coil is always going to work better with knollys rising rate suspension. but if you want to save weight, the ccdb air will do a good job. the climb switch gives a platform that will improve the knollys climbing ability on tech climbs only. in September the ccdb coil with cs will get released and will be a better performer on knollys than the air.
    when the climb switch is in the off position, these shocks are just the same as last year's version.
    bos have better damping than cane creek.
  1. CCDBA for TNT Spot?
    By TJR in forum Turner
    Last Post: 03-16-2013, 10:15 AM
  2. bandit29 ccdba
    By KCHT in forum Transition Bikes
    Last Post: 03-13-2013, 07:05 AM
  3. Anyone tried the new CCDBA air can on the Nomad?
    By expatrider in forum Santa Cruz
    Last Post: 02-13-2013, 06:37 PM
  4. CCDBa or Float CTD?
    By ryan_daugherty in forum All Mountain
    Last Post: 08-06-2012, 11:01 PM
  5. CCDBA on a Nickel?
    By Mountain Cycle Shawn in forum Santa Cruz
    Last Post: 07-13-2012, 03:47 PM
