Results 1 to 8 of 8
    CCDB air high flow sleeve
    I can remember reading a discussion somewhere about the high flow sleeve for the CCDB air and its benefits with pictures of two slot and six slot sleeves, but i am now unable to find it. Anybody know about this? I recently had a two slot sleeve fitted which has improved the performance. What is the diffence between the two and six slot sleeves (apart from 4 slots ) ?
    Reputation: honns's Avatar
    I believe you are thinking of this post:
    Delirium DB Air settings
    Only differences I can see are the size of the slots. I am sure there are pros/cons to each but what those are I am not sure.
    Thanks honns.
    Do you think it might be worth fitting the XV can? They say it reduces ramp up and gives a more linear feel closer to a coil.
    Quote Originally Posted by loamranger View Post
    The 2 slot version caused me to un-hate that shock immediately.
    Nice KOM, sorry about your penis.
    Quote Originally Posted by Mrwhlr View Post
    Ditto.
    What about the XV can though?
    Ditto.
    I'm pretty set in my opinion that nothing can cure an air shock's 'airness', just a muted, disconnected, feel they all have to a degree. CCDB coil is my primary shock, air kept as back up. After inner can fix, not fiddling around w/ it any further.
    I'm going back to my coil (BOS Stoy) eventually, I have to have it retuned for the Chilcotin and that's proving to be protracted since the new UK distributor is still not up and running yet.
  1. CCDB Air with High Flow Air Can Mod.
    By canuck_tacoma in forum Shocks and Suspension
    Last Post: 03-04-2014, 08:39 PM
  2. Need advice on wheel build.. Flow vs flow ex
    By yeti575inCA in forum Wheels and Tires
    Last Post: 03-14-2013, 08:31 AM
  3. Tamarancho flow trail poachers. The flow trail is closed!
    By Davey Simon in forum California - Norcal
    Last Post: 02-22-2013, 12:03 AM
  4. Replies: 7
    Last Post: 08-13-2012, 05:54 PM
  5. Stans Flow built wheel vs Hope2/Flow
    By Jisch in forum 29er Bikes
    Last Post: 04-09-2011, 08:37 AM
