Results 1 to 3 of 3
    Cassette question
    Hi i've replaced my 36-11 with a 36-12 cassette. What was listed on what I purchased with the bike originally was 36-12 however it was actually a 36-11. I should have checked before I bought the replacement 36-12.
    So now that the new cassette is different, does that mean I need to adjust the shifters and derailleurs? Or should it run fine?
    I've only had a quick carpark run and I think it shifts ok but I want to be sure cause I don't want unnecessary wear on my new cassette or poor performance when on the trail. Any help would be appreciated, cheers.
    Reputation: qbert2000's Avatar
    spacing between cogs is the same so no issue there. you may have to adjust the distance from the 12 tooth if the derailler is too close but i doubt it.
    Quote Originally Posted by qbert2000 View Post
    Cool thanks for that. That's exactly what I wanted to know. If the spacing between cogs is the same then it should shift the same. I was concerned that the spacing might be different and that i'd be causing excessive wear on the new cassette.
    Cheers
  1. cassette question
    By b-kul in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2013, 08:26 AM
  2. Cassette question?
    By bassn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-03-2012, 07:41 AM
  3. Cassette 34T - 36T Question.
    By Cynical19 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-30-2011, 07:20 PM
  4. Cassette question
    By Gus68 in forum Beginner's Corner
    Last Post: 09-25-2011, 01:28 PM
  5. Cassette question
    By Brandon5132 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-04-2011, 06:48 PM
