Results 1 to 75 of 75
    Reputation: bigcrs's Avatar
    Building a Warden at 30lb or less
    But the catch is, it HAS to be full coil, run a dropper and run real-world tires (800g'ish).
    What do you all think, is it possible? What would the component make up look like?
    I'm not sure how easy that would be to have all your requirements. For comparison, my Chili is full coil (Avy'd 55 up front, Avy'd Van RC w/ti spring in the rear) Thomson dropper, and Big Betty up front and Chunky Monkey out back (both 2.4, tubeless). It's also 1x10 with RF SixC cranks, King/Flow wheels, Crampon Ultimate pedals, etc. About the only thing I could do to lighten it up more is a carbon bar, and XTR cassette.
    And with all that, it's 33.8 lbs or so.
    Your Chilli's build would pretty much resemble the Warden build I'd imagine.
    Do you know the Chilli's frame weight? The little bit of info I can find on the Warden's weight is 6.75lbs w/CTD, I'm guessing it's a medium frame.
    Eh, mine's a large and I think it's was 8.00 or so with a DB Air? I'm not 100% certain, someone else might have that number handy.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by bigcrs View Post
    carbon rims, 190 hubs, SLR saddle, RF next SL cranks, kcnc 38 cassette, etc...
    here's a retailer that sells much of this type of stuff: Fairwheel Bikes, Cycling Boutique
    Heck, by my estimation you could get it down close to 26.5lbs...
    Dec 2009
    if you want to spend $10k
    Pivoteer
    Reputation: tiSS'er's Avatar
    I think you could do it with uber light cranks, saddle, rims, hubs, etc, but as mentioned, it will be pricey. My Endo with carbon cranks, Hope M4s, average wheels, Thomson dropper, and Revelation fork comes in at 28.75lb I believe the demo Warden that was at Knollfest with XO1 1x11, PIKE and CCDBA was about 29lbs.
    Employed by Pivot Cycles - www.pivotcycles.com
    You could do it, but there would be compromises and it would not match up well with the coil suspension.
    Reputation: wilks's Avatar
    Why hell bent on coil ? A pike and ccdba would be a killer combo I'm sure.
    [QUOTE=wilks;10878311]Why hell bent on coil ? A pike and ccdba would be a killer combo I'm sure.
    I'm sure it would be killer, but I know what like, and it's not air. I do have fond memories of the Doroado though....
    Bang for your buck, out of the box coil will always out perform air, especially with rear shocks.
    Reputation: socalMX's Avatar
    Maybe Ti coiled shock rear with Pike/34 front. Next SL crankset & Derby carbon wheels.
    I think the new Marz Ti coiled shock looks promising & is said to be the lightest coil shock on the market, im not sure on sizing & release date but it sure looks sweet... At that weight, you must make compromise.
    I can't remember the exact weights (again, sorry), but my Avy'd Van RC with a Ti spring was only about 40g or so heavier than a CCDB Air I think. I measured these nearly a year ago, so I just cant' remember the numbers.
    Nice shock for sure, love how user tunable it is. Unfortunately doesn't look like it'll be offered in the Warden size
    Is the Warden the same as the rest, 2.25" x 7.875"?
    Quote Originally Posted by rscecil007 View Post
    Yep Just check the shock options
    That's a cool site, did you see how lite that Extralite Hyper rear hub is, 168g's! But for $600 fat ones, I'm not that crazy. (Yet)
    Yep, but one can still make a damn light bike that is reasonably strong, I was specing it out with envy stem and bar, next SL or xx1 cranks, command post blacklite, tall mountain type carbon rims, etc.
    You can go WAY lighter with carbon saddles that have no padding, stupid light 130gx700mm handlebars, super minimalist brakes, etc.
    In the end, it's all about money, most people want a real light bike, but they don't want to spend the money that it takes to get there. To build those 28lb AM bikes with 6" of travel with solid builds takes some serious cash, any way you do it. Even at 30lbs it's pretty damn expensive. I dropped XX1 cranks into my ride, ditched the front D and shifter, switched to a smaller lighter cassette and went with a lightweight saddle. My bike has an air shock and all of this only gets it down to around 29.5lbs. Could I go way lighter without sacrificing strength? Sure. It's going to start costing a LOT of money real fast though. That's what it takes.
    Pivoteer
    Outside of the XFusion Vengeance, are there any other legitimate 650B coil forks?
    Quote Originally Posted by tiSS'er View Post
    Exactly what I was just researching, it seems Xfusion is the only one around. And at 2494g's /5.5lbs sub 30lbs is gunna be tough.
    That's pretty f'n scary, just to drop 3-4lbs means one has to drop 2-3k on top of 3-4k. Suddenly 33lbs sounds just right....
    Pivoteer
    I think with the standard XO1, dropper, PIKE and CCDBA build, you would be sitting right about 29lbs. I know you are looking for coil, but certainly something to consider. I have yet to hear any major complaints about the PIKE, and the CCDBA seems to be the pinnacle in an air shock.
    My Chili is about 35lbs full coil with dropper and it can be a handful on longer "epic chunky" rides we do in the winter. The Endo is a bit light for these duties (not due to the frame, but rather due to my build), and as such I am looking at a 29lb Warden to fill the gap. Another option high on my list is to drop a different fork and shock on the Endo and go 1x11.
    Anyone interested in buying a sweet Endo at a great price?
    grams pounds
    Frame 4100 9.03
    Fork 2452 5.40
    Headset 61 0.13
    Stem Envy Carbon 110 0.24
    Spacers ? 0.00
    Handlebar Envy Carbon 180 0.40
    Grips Lizard Skins 30 0.07
    LH Shifter None 0.00
    RH Shifter XT Pod 130 0.29
    Front Derailleur None 0.00
    Rear Deraillleur XT 208 0.46
    Bottom Bracket 0.00
    Crankset RF Next SL 560 1.23
    Pedals XTR? Trail? 370 0.81
    Chain Ultegra, whatever 230 0.51
    Cassette KCNC 11-38 196 0.43
    Seatpost Blacklite 550 1.21
    Seatpost QR Simple 20 0.04
    Saddle SLR? 130 0.29
    F Wheel Carbon rims, 2 sets of spokes, alloy nipples, 190 rear hub, 110 front 1477 3.25
    R Wheel 0 0.00
    F QR/Axle 0 0.00
    R QR/Axle 0 0.00
    F Tire 800 1.76
    R Tire 800 1.76
    F Tube None (sealant/strip) 100 0.22
    R Tube None (sealant/strip) 100 0.22
    F Brake Shimano XTR+203mm XT Splined Rotor 421 0.93
    R Brake XTR+160mm rotor 400 0.88
    Cable Housing+misc 200 0.44
    Total 13625g 30.01lbs
    Reputation: F.N.G's Avatar
    Good gawd there sure is a lot of work being put into this thread. Cannot go coil on a limited budget and want lightweight...
    Reputation: Calhoun's Avatar
    Nov 2008
    Stretch it out to a large and I'll take it.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    Reputation: vikb's Avatar
    I'd like to get the Warden down to 30lbs or less in a practical non-Platinum-VISA build. OTOH - I'm not going be unhappy if I am a bit heavier than expected.
    I'm okay with air suspension so that will help. Since I'm going to be waiting for the frame a while I'm just tackling a few parts at a time and trying to find the sweet spot in the price-weight-functionality curve before things get silly expensive.
    Safe riding,
    Vik
    www.vikapproved.com
    grams pounds
    Frame 4100 9.03
    Fork 2452 5.40
    Headset 61 0.13
    Spacers ? 0.00
    Bottom Bracket 0.00
    R Wheel 0 0.00
    F QR/Axle 0 0.00
    R QR/Axle 0 0.00
    F Tire 800 1.76
    R Tire 800 1.76
    Looking at the build a couple of notes. First off I think you are being very optimistic with the wheel weights. Haven Carbons are 1450 grams in 26. Chinese carbon will not give you the durability that you want unless you are using at least 435 gram rims minimum. Second, the Shimano rotors are heavy. About 80 grams heavier than Formulas for the 203's. You can save the weight from the wheels with the rotor swap.
    Quote Originally Posted by vikb View Post
    I would focus on rotational weight, that is where it is felt the most. Next SL cranks and a good carbon wheelset and all good. The rest of the weight savings is nice but not a great deal.
    30 pounds, 31 pounds, 32 pounds, 33 pounds.
    Does it really matter?
    Quote Originally Posted by arkon11 View Post
    between 30 & 31,no. between 31 & 32,no. between 32 & 33, no. between 30 & 33, hell ya
    breezy shade
    For what the bike is intended, hell yes it matters. Within reason...
    Reputation: KRob's Avatar
    Yeah mine was 8.01lbs too. I think the warden is supposed to be pound lighter with ctd so that helps. Still going to be tough getting to 30 with coil/coil.
    Jayem has a theoretical build down lower that's close. Not sure which coil shock he's using and there doesn't seem to be a bb.
    Isaiah 58:14
    www.stuckinthespokes.com
    Quote Originally Posted by KRob View Post
    8.01lbs with a CCDBA?
    Ccdba's are heavy - my chilcotin was just over 8lbs with ccdba too.
    Quote Originally Posted by wilks View Post
    If memory serves they are 530g give or take with hardware in our size.
    I really don't think so. I mean, Enduro has a lot of gravity in amongst the stages and having a correctly tuned coil on both ends will not only perform better going down it'll perform just as good as a air shock/fork with a pedal platform going up. With the only penalty being 2-3lbs of weight, but that penalty only equals to better reliability.
    In all reality, I'd be pretty stoked to have a 33lb full coil steed stepping up to drop in on enduro stage. It would have to stop at 33lbs though.
    Wow, that means that the Chilcotin is pretty darn lite as well, in the high 6lb to low 7lb range without a shock!
    Pivoteer
    7.5lbs claimed, medium with CTD. I suspect it could be less as my Chili was 8.5lbs with CCDB coil which is about 1.5lbs heavier than a CTD. The raw frames are a tad bit lighter.
    I think it's safe to say that a large Warden frame would roughly weigh 7lbs without shock....
    So just for shits and giggles -
    Frame - 7lbs / 3175g's
    Shock , Avy Woddie - 1lb / 453
    Ti spring 400lb (from Ti springs.com) - .804lbs /356g's
    Fork, Xfusion Vengeance - 5.5lbs / 2494g's
    Dropper post, Vencum Moeloc 200mm - 1.23lb / 560g's
    Maxxis 3C Maxx Terra x 2 - 3.62lb / 1642g's
    Total - 19.15lbs / 8680g's
    When I have a little more time I'll dig up more boring numbers
    My mistake. It was 8 lbs 9 oz with ccdba, rear axle. iscg tabs, and head set cups, if I'm reading this scale correctly.
    <a href="http://www.flickr.com/photos/19516547@N04/8543299553/" title="IMG_0193 by kentsaundra, on Flickr"><img src="http://farm9.staticflickr.com/8102/8543299553_ec8bb26a8e_c.jpg" width="800" height="600" alt="IMG_0193"></a>
    And here's a picture of the demo I rode in Sedona (I think) with air front and rear, Pike, etc, that Dusty said weighed 29 lbs. It didn't feel any heavier than that.
    <a href="http://www.flickr.com/photos/19516547@N04/11291740504/" title="SAM_0719 by kentsaundra, on Flickr"><img src="http://farm6.staticflickr.com/5513/11291740504_01e2fbae36_c.jpg" width="800" height="600" alt="SAM_0719"></a>
    Isaiah 58:14
    A nice round 30 lbs sounds great on internet forums but it doesn't mean anything on the trail. I'm not usually THAT guy who says things like this, but it's very much true. I had 30 lbs in my mind as a goal when I built my Chili (came in at 30.4), it's now at about 31.5 and will be 32ish next year. There's nothing wrong with hoping for a certain wait but it should never affect your component choices.
    Pick that parts that make sense for your intended use and budget. The weight will be what it will be. Choosing parts for weight rather than performance will NEVER make your bike more fun to ride, nor faster.
    8lb 9 oz sounds right. Mine was a raw medium and was weighed without headset, through axle or seat post collar but with ccdba. For the people used to metric weights there are16 oz in a pound.
    Reputation: bubba13's Avatar
    Raw/large Chilcotin with axle/bolt on parts and DBair was 8 pounds 2 ounces out of the box.
    Portland Off Road Navagators
    Quote Originally Posted by bubba13 View Post
    Out of the box Small Painted Chilco. Rp23.
    Not sure why, unless you are less than 10% body fat composition, you would be concerned about three pounds of bike weight. Getting rid of that three pounds on a bike will be $$$$$. Getting rid of three pounds from the rider and their gear would be much less costly.
    I hear that argument a lot and agree. However, I have two bikes that are 4lbs apart and on longer rides I have more left in the tank if I take the lighter bike. I could definitely use 15 less pounds of body weight too
    Reputation: G-AIR's Avatar
    This bike weighs in at 29.23 pounds on my scale. A couple easy places to lose weight would be:
    Carbon instead of aluminum bars
    Lighter grips - Those OURY grips are chunky
    Lighter tires - These are the Maxxis TR 2.3 tires. I believe both tires weigh well over 800 gr. My 26" Maxxis TR weighed 880 and 770 for a HR2 and DHR respectively. I really like these new Maxxis tires, but if weight savings is a priority you could probably save about 50 gr per tire and still have a capably tire.
    Lighter rear shock - the AVA CTD might be a possible choice.
    Thats easily a pound!
    Its going to be fun to check out these Warden builds.
    DB Air weights (543g): Chilcotin + Cane Creek Double Barrel Air
    That's with the old longer top hardware, so figure a bit less with the short hardware for 3d rockers. A CTD is nearly a 1/2 pound lighter, so as Tim said, an Avy'd CTD might be a good option.
    Pivoteer
    Really curious to see how the Avy CTD works out. Could be a game changer for the weight conscious.
    Throw in some carbon rims and you could have a 28lb Warden with dropper that rips. Seems like the near perfect "one" bike....hmmmmm....
    What rims are you thinking about?
    Enve's? They would be awesome, but the $900/rim or whatever is pretty hard to justify.
    Pivoteer
    Quote Originally Posted by G-AIR View Post
    Derby Rims are getting great reviews
    Technical Specs
    NOX Composites look incredible, probably as close to Enve I have seen at half the price
    AM-275 | Nox Composites
    warden could be 26-27lb
    my endo is built well tough and weighs 28lb on the button...a warden could be built to weigh less w/o carbon wheels
    heres my build
    M endo with bos kirk (340g)
    Fox 36 floats (2140g)!!!!
    c king headset
    race face next bars
    syntace megaforce stem
    race face strafe grips
    formula rx brakes 200mm rotors
    xo crank with nsb single ring
    hope bb
    Thompson dropper
    hope seatclamp
    kmc sl chain
    x9 mech and trigger
    xt cassettte
    Chromag lynx saddle
    superstar mag pedals ti axles
    wtb i23 rims
    competition spokes
    dt 240 hubs
    spesh butcher and purgatory control
    dh tubes
    theres a few places to save weight here....saddle...e13 kom rims...lighter tubes (or tubeless)....race face next cranks...sapim cx-ray spokes...lighter grips....xx cassette...x0 mech...
    Technical Specs
    What's all this 29" AND 650b nonsense? ONLY JOKING PEOPLE, CALM YOURSELVES.
    But seriously, those look pretty good from the just the specs. I guess there aren't many carbon options for the 26'ers anymore beside Enve and Easton?
    Reputation: airwreck's Avatar
    I would read this before considering a Vengeance for the fork To the Point - Wheel Diameter VS Fork Offset - Pinkbike
    They aren't publishing the offset for the Vengeance, I believe it is the same offset/lowers as the 26" version. Probably not much different than running a Fox 36.
    Technical Specs
    A wheel builder buddy of mine recommend the Nox composites wheels as well. They look good.
    The Derby wheels are wider and like you said getting good reviews. They also have them on Winter Special for $299 right now.
    Isaiah 58:14
    Loving the Derbys on my Rune, the width is a game changer for me! The build with Hope Pro2s and super comps was rite at 1000. I have some friends that paid 2400 for carbon wheels and are now showing ENVE! A 26" version will be released early 2014 for you die hards...
    I am also running a Float 36 with the 27.5s and no issues.
    Look what the Canfield Brothers have just released for those of us are 9t Microdrive, 191g 10sp 9-36 cassette Micro Drive & Guide - Page 8
    Quote Originally Posted by cfrench View Post
    heres my build
    c king headset
    race face next bars
    hope bb
    Thompson dropper
    hope seatclamp
    kmc sl chain
    x9 mech and trigger
    xt cassettte
    Chromag lynx saddle
    wtb i23 rims
    competition spokes
    dt 240 hubs
    dh tubes
    I am having a hard time seeing this build at 28 lbs
    Reputation: rubybigdog's Avatar
    For what its worth I received an email from Ray (Derby Rims) stating that he plans on having the 40mm x 26" rim available in March. I am definitely keen to try a set out!
    Pivoteer
    Quote Originally Posted by Salespunk View Post
    Mine is 28.75lbs with a dual ring setup, Hope M4 brakes (heavy) and a Revelation (3.8lbs). So a single ring setup with lighter brakes, I think it makes sense.
    Reputation: 006_007's Avatar
    Totally agree - I have my Chilcotin built to 29.999999Lbs (maybe just a tad less then that) with single ring, Fox 36, and a dropper post.
    Rolling resistance can also be a major factor on longer rides that isn't captured in weight comparisons.
    Safe riding,
    Vik
    www.vikapproved.com
    All this stuff can really make one's head hurt… so many variables. Who woulda thunk mountain biking could be so scientific! It is fascinating though.
    I have learned that rolling weight is the most important weight to reduce. And in your post, rolling weight can be resistance too. I try to put the lighter wheel on the rear for that reason. Does it work? WFT knows, I am slow regardless dammmit...
    Quote Originally Posted by F.N.G View Post
    Weight and rolling resistance aren't necessarily correlated.
    Safe riding,
    Vik
    www.vikapproved.com
    Quote Originally Posted by socalMX View Post
    +1 - I've resisted the temptation to build a spreadsheet and track stuff. I'm just making sensible choices at each component and I'll be okay with the overall weight. I don't want to get too caught up in a specific weight target.
    My current bike is pretty heavy so there is zero chance I won't end up with a less burly rig to pedal around.
    Safe riding,
    Vik
    www.vikapproved.com
    For me its pretty simple as I would be doing a complete parts swap but adding Next SLs and a DBAir CS to the mix. Should put me at a happy +~29lbs.
  67. #67
    Didn't say they were. Just paid note to something interesting you brought up regarding the rolling resistance.
  68. #68
    Quote Originally Posted by rubybigdog View Post
    This was the main reason I wanted a 650b bike (nothing wrong with the wheelsize, I just cant cough up the money for a warden after spending 5k on my chili). This is great news. I will def be ordering mine as soon as they are released!
  69. #69
    yeah, some of its burly, but ive compensated with other parts that are about as light as you can go w/o sacrificing strength/performance....
    Bos The Kirk 340g
    Syntace Megaforce2 50mm 122g
    Race Face Next Carbon 3/4 Riser 725mm 175g
    KMC X11 SL 239g
    Superstar ULTRA Mag CNC Pedals (gold ti axles) 260g!
    DT Swiss 240 20mm 165g
    DT Swiss 240 142x12 235g
    Butcher Control 2.3 730g
    Purgatory Control 2.3 685g
  70. #70
    Sep 2015
    28 LBS
    Knolly Warden Large Frame
    Fork- Fox Float 36 27.5 160 RC2
    Brakes- Front and Rear Shimano Saint BR-M820’s
    Rotor- Shimano SM-RT86 180mm
    Cranks- Race Face Next SL 175mm
    SRAM XX! 11spd
    SRAM XX1 Shifter
    SRAM XX1 Rear Der
    SRAM XX1 Chain
    Rims- Nox Composites Kitsuma 27.5 AM with Customer Decals
    Rear Hub- Hope Pro 4 Evo 12x142
    Front Hub- Hope Pro 4 Evo 15mm
    Tires- Maxxis Minion DHR/F II 2.40
    Pedal- Chromag Black Scarab
    Headset- FSA Orbit
    Stem- Raceface Atals
    Shock- LEV Integra 31.6 x 435mm 150mm
    Saddle- Chromag Lynx DT Leather
    Seat Collar- Chromag
    Handlebar- Race Face Next
  71. #71
    Picture of it on a scale?
  72. #72
    Aug 2015
    Quote Originally Posted by Wadzy View Post
    28 LBS
    SRAM XX! 11spd
    SRAM XX1 Shifter
    SRAM XX1 Rear Der
    SRAM XX1 Chain
    Headset- FSA Orbit
    What rear shock are you using?
  73. #73
    Reputation: rdhfreethought's Avatar
    Its not that hard without a dropper. Mine is size Large and was 29lbs 11oz back in 2013, without much carbon besides bars and cranks and heavy wheelset, tires, CCDBA etc. I could have easily gotten less than 29#a few more carbon bits and weight conscious choices. Its back up to #33 lbs where it belows. 180mm and in slack position. burly aluminum cranks.
    Attached Thumbnails Attached Thumbnails Building a Warden at 30lb or less-chilcotin-29lb-build-012b.jpg
    Regional Race Manager, Knolly Bikes
    Washington, Oregon, Montana, Idaho, Wyoming
  74. #74
    Yeah but the 28lb one has heavy brakes,proper tires and a dropper. Scale has to be off or its 28lbs 32 ounces
  75. #75
    Nov 2014
    You've heard the saying "the mirror adds 5 pounds?". The internet subtracts 2 pounds.
  1. knolly WARDEN
    By RyeBokeh in forum Knolly
    Last Post: 09-06-2016, 04:40 PM
  2. 30lb 36er SS
    By todwil in forum Singlespeed
    Last Post: 11-19-2013, 09:26 PM
  3. Different perspective on Warden
    By F.N.G in forum Knolly
    Last Post: 10-08-2013, 11:27 AM
  4. Knolly Warden 650b
    By skidad in forum 27.5
    Last Post: 09-02-2013, 09:26 AM
  5. 5spot warden
    By freebiker in forum Turner
    Last Post: 12-15-2011, 02:03 AM
