Avy'd Marzocchi 55
Craig, at Avalanche Racing Products, is trying to make an Avalanche Advantage Fork Kit for the Marzocchi 55. To do this he needs 10 or more Marz 55s to analyze (i.e. take measurements of). Without an adequate sampling (10+ forks) the fork kit for the 55 won't happen.
I volunteered my 2010 Marzocchi 55 Micro Air Ti Fork to the cause. (That makes 3 or 4.)
Note: I don't know if Craig will reimburse shipping, but he will probably hook you up if he doesn't. Personally, I didn't ask; as my fork needs an oil change and I doubt he, in good conscience, would put the old, black goop back in.
Avalanche Downhill Racing, Inc.
12 Davidson Road
Colchester, CT 06415-1600
USA
Phone 860-537-4306 Fax 860-537-8260
"sounds like you need to find a better mechanic..." -- Calhoun
Someone, please create a similar thread in the "Shocks and Suspension" forum. I have never posted in that forum so I think it would be a bit inappropriate of me to start out with a new thread that is a plea.
Just noticed that Craig is in the Knolly forum. I guess my "fork-oil surprise" won't be much of a surprise after all.
I would volunteer my 2012 rc3 ti but its in Phoenix and I won't be back down there for another 3-4 weeks. If it can wait, i'll send it then.
That should work, but I would ask Craig when you have it in your possession. Thanks!
Huh?
I guess there must be more interest now. Ever since I got my 55 for my Chili I just cant get it to feel good. I even called Marz and tried more oil, more air, still doesn't feel as good as my old Fox 36 Talas.
When i called Craig to inquire about a cart, there was not enough interest for him to pursue it.
Unfortunately I don't have a spare fork that would substitute so I can't send mine in.
Just called Craig and I'll be sending in my 55 as well.
¡Geaux Tigers! - ¡Visca el Barça!
Thanks.
He really only needs your fork for a day or less (actually hours) to take some measurements. Since you live in the New England area, you could probably arrange it so your fork was only gone for short period (counting mailing). You might want to call Craig and see what you can arrange.
Every fork helps! (I feel I should add a "yeah team" after that sentence. Not sure how I volunteered myself to be head cheerleader for this. I really must not want to do my own work. )
What years are you looking for? I have a friends 55 sitting in my garage. It was a lemon since day one. I think it must be an 08 or '09.
We need all years and models, we do not have any this old yet.
I'll send my 2011 Micro Ti in next week after Christmas.
Yo, send me an Avy'd Lyrik to test, and change my seals, you can borrow my 2012 55 for measurement. .
Nice KOM, sorry about your penis.
^^^^^ This +1...... (Although mine is just an old 2009, my 2011 is on a slow boat to the UK Sold.)
"If it didn't hurt when you screw up, it wouldn't be half as exciting when you dont." cdburch
If you can part with your 2009 for a week or so then send it in. As Craig said, he needs as many model years (and multiple examples of each model year) as he can get.
2011 RC3 Ti Evo will be on its way Jan 2nd.
Probably a performance gain for an older fork but my 2012 55 Ti Evo is perfect, so why fix something that isn't broke?
Not to mention what happens to any warranty with aftermarket tweaking.
Cool see you guys sending in your forks. Craig is such a great guy and it is great to see the Knolly crew stepping up to help Craig out (and hopefully yourselves )
I spoke to Craig the other day, and he mentioned he has been knocking out all kinds of work for Chilcotins, SWEET!
"Three balls at once...who knew?" - Cotton McKnight
Have you had an opportunity to ride one of Craig's cartridges? I thought the Lyrik DH was the best damper on the market, better than the Fox RC2, and better than the 55 RC3 Ti.
After the cartridge upgrade, nothing I have been on even comes close to the performance of a custom tuned damper.
...Not to mention what happens to any warranty with aftermarket tweaking.
Not exactly sure what you mean, so I will answer both possibilities:
-- Craig needs the forks to measure. It will be the equivalent to doing a fork tear-down for annual maintenance. It won't void a warranty or cause damage.
-- With some forks you have to enlarge the bottom whole (e.g. Lyrik I think) for the Avy cartridge, so you couldn't replace the original components if a warranty repair was required. In this situation, a manufacturer could play nasty and void your warranty even though the failure was caused by their components and not Avalanche's fault. Other forks don't require any type of mod (e.g. Marz 66) and the original parts could be substituted before returning for warranty.
If you cannot state plainly what you're not getting, you have nothing to fix. I suspect the guys who see huge differences are heavier.
Just checked shipping and it's not going to be as much as I thought ($16) so I'll get it boxed up and sent next week.
Translation: Ignorance is bliss!
There's nothing wrong with this way of thinking. It's a lot cheaper and requires less time. Imagine how much better your life would have been if you had discovered this nugget of wisdom before purchasing a Knolly!
Fair enough if parts can be swapped easily to retain the warranty.
I know I've owned Fox & Rockshox forks that I never got the performance I was after , but other friends forks worked good from day one. Mass production quality control can be a little off.
The 55 Ti Evo for me has been good from day one( except for the removal of the plastic spring wrapper) my thinking was the 55 had a better strike rate?
- You may not post replies
- You may not edit your posts
Forum Rules
