Results 1 to 10 of 10
    Mar 2013
    Anyone polished their Raw frame?
    Hi
    - Just wondered about this couple days ago, because it should be easy but the rawness will go away obviously
    Anyone experimented with this?
    I have a Chilcotin and think it could look great.
    Reputation: themistoklisv's Avatar
    Mar 2011
    I did it with a sonax compound for chrome & aluminum, it came out nice without destroying the decals, this is the final outcome
    yeah its a once a year job. i've done it with mine, pictures later, I used Mothers Mag & Aluminium Polish, all you do is apply the polish, rub it up and down 3 or 4 times then put the frame under the hose with washing up liquid for doing the dishes...this removes the residue and surplus polish. the result is as above.
    basically it just removes the oxidisation layer (white stuff that builds up). the best part is how the welds go shiny it looks really nice. the frame wont polish to a chrome effect as the frame comes brushed not polished from the factory.
    I recommend it, as pointed out in the previous post, it has no effect on the decals. the decals are under a coating so stay preserved.
    Mar 2013
    Wow, I was hoping for a picture - Gotta say it makes a difference, it's good lookin'! Thanks to both of you.
    I did not know that there is a coating finish on the raw frame? Just think that the decals are super thin for great durability, from scratching or crashing. The frame should be raw, without coating?
    But I will try out something with my polish set.
    Mar 2011
    There is coating on the decals only, not nessesary to use any tools, only hand polishing and do try the compound you will be using on a small area first, to check that it won't be bad for the frame ;-)
    Quote Originally Posted by Pavle View Post
    theres a coating over the decal not the frame, you cant lift the ink with mothers alu and mag polish...I was very careful and did test patches that were left over night etc
    eventually I just run it all over the frame and decals included once I knew it was safe
    Jan 2017
    Digging the old thread. Are there any bad effects of this polishing? Is it totally safe for frame and decals as well? I'm thinking of doing that for my Warden "raw" frame, but want to make sure before I start.
    Question 2: was anybody using any clear protection on frame such as 3M tape or something similar?
    Dec 2008
    The only polishing I do is where my heels rub on the chainstays. I actually love all the 'beauty marks' on my bike. They each have a story to tell and don't detract from the look of the bike at all. The Raw frame is so easy to keep looking nice. Just hose or wipe it down once in a while and you are done. Don't see the point of using tape on the raw frame since there is no paint to protect. Most hits big enough to scratch the frame would probably go through the tape as well.
    I dont think there is a coating on the decals. I asked knolly if they could be removed and they say they are bonded. My decals (and frame) are pitted from sweat. Very obvious on the decals.
    Sep 2017
    Just a heads up. I work with raw aluminum for a living. Aluminum starts to oxidize in around an hour, and you can't see it. Clean aluminum, even left outdoors for years (in our desert climate) will retain its raw look, however the gloss will fade some. The white, almost crystal looking form of oxide, comes when it's left exposed to moisture and is the equivalent to rust on steel. Raw aluminum here in the desert doesn't need much protection, however if I lived in a wet climate and wanted to preserve that industrial looking finish over a polished finish, I'd clean the bike after every ride, then hang it in front of a heat dish (not too close tho) to make sure it dries fast and thorough, and apply a clear coat of some kind as kind often as you change your fork seals.
  1. Chrome or polished alum frame?
    By txhillcountry in forum 29er Bikes
    Last Post: 05-16-2013, 11:53 AM
  2. Anyone polished a 6.6 frame?
    By deesta in forum Intense
    Last Post: 11-07-2012, 11:46 AM
  3. Polished 05 Flux frame looks tired - what to do?
    By ashleygreen14 in forum Turner
    Last Post: 09-20-2012, 01:55 PM
  4. Anyone got a polished alloy frame?
    By Uphill=sad in forum Pivot Cycles
    Last Post: 06-27-2012, 09:18 PM
  5. Ceramic coating a polished aluminum frame possible?
    By AC/BC in forum Frame Building
    Last Post: 05-31-2012, 03:45 PM
Members who have read this thread: 4
