Results 1 to 10 of 10
    gmx
    gmx is offline
    Nov 2006
    2 x 10 chainguide for delirium
    I have my d as 1 x10 right now but want to try 2 x10. Most of the new guides i've seen don't work with etype derailleurs. Any recommends on some of the older chain guides or is there a new guide that will work that i haven't seen?
    Reputation: thedeathstar's Avatar
    Mar 2012
    MRP 2x guide. Correct me if I'm wrong, but I see no reason it shouldn't work.
    Reputation: cerebroside's Avatar
    The only guide I know of that works is the Blackspire Stinger E-Type, I ran it for a while before going 1x.
    gmx
    gmx is offline
    Nov 2006
    Thanks for the replies.
    It doesn't look like there is a backing plate to mount the derailluer to on the mrp.
    The blackspire is definately the best option price wise. Any issues with it while you were running 2 rings?
    No issues with the Stinger that I found. I went 1x on my Delirium because thinking about chainline when you're going fast downhill is a pain.
    That and the front shifter prevented ideal Reverb remote mounting. I have to push (a lot) more on the ups and top out on the downs, but the compromise was worth it for me.
    Pity you didn't post this a bit sooner, I was down in Van last weekend and could have given you some of the gear (for a doz or equivalent ).
    gmx
    gmx is offline
    Nov 2006
    ... and if we just ...
    Quote Originally Posted by cerebroside View Post
    Yeah bummer. I like the 1x10 for the same reasons but spent last week in the kootenays and got fed up with the pushing
    Jan 2009
    col and me both run these on our chilli and endo, we both running 2x10 setups. with etye front mechs,
    Blackspire DER Guide Chainguide 2013 | Buy Online | ChainReactionCycles.com
    Quote Originally Posted by delirian View Post
    Got a pic? That's the same guide I'm running for my 1x10. Not sure how you would make it work with a front mech.
    Edit: Figured out the difference. The Delirium only has one frame mounting hole for the E-type FD, so it needs the BB/ISCG mounting bracket. The newer Knolly frames appear to have two mount points, so you don't need the bracket and can use whatever 2x guide you want (i.e. Blackspire Twinty, MRP 2x).
    Jan 2009
    yes they 2013's are direct fit etype,,,
    theres lots of pics here,
    rockguardz frame protector
    and more here,,,
    chill pod phin
    Nice bikes! Especially the Podium. Looks like you're running the Twinty.
  1. WBP + Delirium
    By RideEverything in forum Knolly
    Last Post: 05-18-2013, 05:41 PM
  2. no more Delirium?
    By Lastug in forum Knolly
    Last Post: 09-11-2012, 11:52 AM
  3. DB Air on a Delirium
    By juan pablo in forum Knolly
    Last Post: 05-29-2012, 09:43 PM
  4. Delirium SL
    By pfarrell in forum Knolly
    Last Post: 02-19-2011, 02:53 PM
  5. Fox 40 FIT RC2 on new Delirium
    By Rubberneck Goose in forum Knolly
    Last Post: 01-30-2011, 08:12 PM
