Results 1 to 7 of 7
    Reputation: Pauldotcom's Avatar
    Aug 2010
    KHS XCT535 Shock Change Question
    Hi
    Just got a Fox RP3 shock to replace my Rock Shox. The bushing are different in size. Any suggestion on where to get new bushings to make this thing work? Thanks
    “People fear death even more than pain. It's strange that they fear death. Life hurts a lot more than death." JM
    Lbs
    Assuming you dont have the proper means of measuring for the proper bushings and the right tools. You are better off using your LBS. Will save frustrations.
    Reputation: Aresab's Avatar
    You can call Fox directly, that's what I did. My 2008 frame uses the sizes below which were confirmed by Bob's bicycles (where i bought the frame).
    I believe the number is 1-800-FOX-SHOX..
    Upper mount width – 22.2 mm
    Lower mount width – 36 mm
    Aug 2010
    I have a micrometer so yes I do have the proper measuring tools. Those are the exact numbers I got RSab, so I will call FOX on Monday. Thanks for the headsup...My frame is also a 2008
    Did you succeed in replacing the shock ?
    Aug 2010
    Yes!
    Reputation: boxedrn's Avatar
    Oct 2010
    @Paul thanks for your help and tips!!
    KHS XCT535 Shock Change Question-imageuploadedbytapatalk1364372015.530602.jpg
  1. 05' Coiler rear shock change question
    By ropey in forum Kona
    Last Post: 02-21-2007, 06:21 AM
  2. Rear Shock Question: Change Float To Which Coil???
    By danyiluska in forum Shocks and Suspension
    Last Post: 01-29-2007, 11:30 AM
  3. Question on a shock change...
    By bstrawter in forum Specialized
    Last Post: 05-31-2006, 07:10 PM
  4. Shock change question for La Bruja ?
    By TIGMAN in forum Ventana
    Last Post: 07-23-2005, 07:00 AM
