Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: KHS xct 555
    Reputation: xs650joe's Avatar
    KHS xct 555
    Just bought my first KHS. A 2008 xct555. Totally stock for now. Only had a chance to ride it a few times but so far I'm loving it.
    GreeneDog
    Reputation: airtym's Avatar
    Totally into that bike right now. How much did it cost you?
    2011 Diamond Back Mission
    2007 Specialized P1 Cromo
    approx $600
    where did you get it so CHEAP? My friend is looking to get one.
    Reputation: GTR2ebike's Avatar
    May 2010
    Most likely used since that bike is a 08 model
    NedwannaB
    Reputation: JMac47's Avatar
    Ditto that
    Quote Originally Posted by xs650joe
    Pretty much same here.
    Who did he tell you that?....
    Reputation: brunomu's Avatar
    hi, i just buy a khs xct 525 frame and plan to build whit good parts, i want to use this bike as my second bike, please owners of xct speak of the performence of this bike climbing,decending and for what type of riding you use the xct, also whats the max fork lenght that you can use in this bike, i don´t know to much from khs so any information will be usefull, thanks (i post some pics when i have the bike ready)
    NedwannaB
    All around trail bike
    Quote Originally Posted by brunomu
    Climbs and descends great with FSR linkage. I believe the fork travel is best @ 140,150mm max. You should check on what length would void warranty first before purchasing/installing.
    Quote Originally Posted by JMac47
    thanks man, just a couple of questions how much travel fork are you using on your xct?, i buy the xct 525 im looking at the rear shock and i see that is no lock up only rebound adjust( is the x fusion), i think you have the 555 (it comes whit rock shox) do you use the lock up in hard climbs? and what kind of riding you use the xct? thanks.
    NedwannaB
    No lockout
    Mine came with the Rock Shox 2.1. Going to possibly upgrade to 3 or 4 Monarch series or a Fox if one is dialed for this type fsr susp frame.
    I am running a 130mm (+5") Float as that is what I had. More XC feel with it but pretty much that's my riding. Have a 650B front wheel to put on that will raise/slacken things abit. Not planning to go to a bigger travel fork unless I come across a good deal, as this is my secondary bike.
    Reputation: Pauldotcom's Avatar
    Aug 2010
    I would chime in but my finished build is sitting in me basement because there is about 4 feet of snow outside that wont melt!
    New pic with a few changes made to my 555 recently. Syncros Mental Alloy Pedals, Raceface EvolveDH riser bars and Kore 65mm stem. Also got tired of using the camelbak on every ride so I added a water bottle rack with a couple of zip ties. Works real good.
    Omnipotent
    Quote Originally Posted by Flboy
    *BUMP*
    Yes I would like to know as well; I'm eyeing a 2009 KHS XCT-525, but I haven't heard much about them, nor seen any in depth reviews...
    I NEED to get a bike soon, but the prices people are bidding for USED (see no warranty usually), older bikes is insane(!)... What is going on here?!
    Aug 2010
    My review.
    The XCT525
    Very light, nimble, and quick. Please note that mine is different because it is a custom build.
    That being said the frame is a good, light weight start. If I had to start over again with my build I wouldn't change the frame for the world.
    I do not experiance any pedal bob whatsoever on uphills. Downhills are amazing. I've read alot of bad reviews about the rear rock shox. I put on a Fox fork in front. To be honest, I like the rear shock just as much as I like the front. The rear shock is perfect for me - a weekend warrior that rides 3-4x a week and doesn't hit 6 ft jumps.
    I get complements all of the time on the look of the bike. For the money, I think the KHS525 is a steal. I bought my frame for $299 brand new!
    As you can see, I have nothing but good things to say. I have yet to experiance any negatives. I did change a couple things out on my build to fix certain rider preferences, but that's it.
    Good luck with your quest to find a new bike; but do NOT overlook the KHS>
    “People fear death even more than pain. It's strange that they fear death. Life hurts a lot more than death." JM
    NedwannaB
    What travel fork?
    Works real good.
    140?
    Aug 2010
    My fork is a 140mm
    I have a XCT535 frame with 555 components. With upgrades though, new fiber bars and seatpost, 1x9 drivetrain with shimano XTR derailer and shifter, stroker ace brakes, rides great. Looking for a new shock thought I have the rockshox monarch 3.1 and i dont like it because it doesnt have a lockout, and suggestions on a good shock?
    Aug 2010
    How about a pic?
    I cant post pics just yet as a new member have to post 10 threads first. Ill get back to you guys, I'll also try to post pics on my profile.
    Omnipotent
    ^^^ I'm seeing 12 posts; ahem... :-p
    NedwannaB
    Upgrade update
    Quote Originally Posted by TitaniumV12 View Post
    Should still count as a new post!
    Te mortuo heres tibi sim?
    Those of you that have swapped in other rear shocks, can any of you tell me the eye to eye length, and stroke?
    EDIT: more digging shows me it appears to be a 7.5 x 2 for the shock. Anyone able to confirm?
    The shock is 7.5 X 2.0. Depending on the model, you may be able to reuse your mounting hardware. For example, the RS Bar uses the same 12mm as the Manitou shocks and the older X-Fusion O2 series. The RS Monarch uses the same 1/2" as all Fox, the RS Vivid, newer X-Fusion O2, and I believe most Marzocchi.
    Aug 2010
    Has anyone put a FOX 23 on the back of a XCT yet? Pics?
    we've been together +2years... we go up slow; then we shred all way down...
    Attached Thumbnails Attached Thumbnails KHS xct 555-310578_1755989598142_1791044299_1124802_938453_n.jpg
Hot Deals
Contests
Latest Mountain Bike Articles
