Results 1 to 13 of 13
Thread: KHS Lucky 7
    Three sheets to the wind
    Reputation: Bawitdaba's Avatar
    KHS Lucky 7
    Has anyone seen the new Lucky 7 FR rig from KHS ? We've been looking for a new ride for my son, this may be the one, retails at $2,500.00..... It's lookin' like a winner...
    Frame
    6061, 8.5 travel with 4 bar Horst bearing linkage & ISCG mount
    Rear Shock FOX DHX 5.0, Pro Pedal, rebound adjust & bottom-out resistance
    Fork FOX 40RC2, 203mm, external adjust: rebound, preload and low/high speed adjust, Internal Adjust Travel adjust and bottom-out damper.
    Headset Cane Creek Pig, 1-1/8" Threadless
    Rims Sun Ringle Single Track, Welded
    Hubs Front: Formula Disc, Sealed Bearing, 20mm thru-axle
    Rear: Cassette 12mm x 150mm
    Tires John Tomac Nevegal 26x2.5 F/2.35 R, kevlar bead
    Spokes 14G Stainless, Black, 32
    Front Derailleur N/A
    Rear Derailleur Shimano Saint
    Shifters SRAM X.7 Trigger
    Chain KMC Z9000
    Crankset Truvativ Holzfeller OCT Open Core, 170mm x 40T
    Bottom Bracket Truvativ Howitzer outboard bearing splined
    Cassette SRAM PG950 11-26, 9 Speed
    Pedals Alloy platform w/replaceable pins
    Seatpost Truvativ XR
    Saddle WTB Rocket V Comp
    Handlebar Truvativ Holzfeller, 31.8mm, Triple Butted
    Stem Truvativ Holzfeller, 60mm
    Grips PowerTools dual density
    Brake Levers Hayes Stroker Trail
    Brakes Hayes Stroker Trail, 8 " rotors
    Color Flat Black
    Frame Size S, M
    Reputation: batts65's Avatar
    Nov 2006
    Those specs you put up are for the DH100, here are the specs for the Lucky, I agree though that it is a good deal. You may want to also consider the Jamis Bam 1, It is comparible all the way through the specs except maybe a slight edge on the rear shock, DHX 4.0 as opposed to the Vanilla R on the Lucky.
    http://www.jamisbikes.com/usa/bikes/...akarbam1.html#
    Frame
    New Design AL6061, 4-bar Horst bearing linkage, 7.3" travel
    Rear Shock FOX Van R, rebound adjust
    Fork Marzocchi 66RCV, 180mm, rebound & compression adjust
    Rims WTB Dual Duty FR, Doublewall
    Hubs Front: Formula Disc, Sealed Bearing, 20mm through axle
    Tires John Tomac Nevegal 26x2.5, Kevlar bead
    Spokes 14G black, 32
    Front Derailleur Shimano Deore
    Rear Derailleur Sram X-7
    Shifters SRAM X-7 Trigger
    Chain KMC Z9000
    Crankset Truvativ Hussefelt w/guard, 36/24t, 175mm
    Cassette Shimano HG50, 11-34 9-Speed
    Pedals Alloy platform w/crmo axles & replaceable pins
    Saddle WTB Pure V Comp
    Handlebar Truvativ Hussefelt, 31.8
    Stem Truvativ Hussefelt, 50mm
    Grips WTB WeirWolf dual density
    Brakes Hayes Stroker Trail, 8" rotors
    Color Red
    Frame Size S, M, L
    we sale them and i have seen one .......super badass !!!!
    Reputation: RacinJason's Avatar
    They have one at Anaheim Hills Bicycles. I was sitting on it today.
    It is really nice.
    Big difference between the khs and the jamis is the khs has Horst-link rear suspension, much better than the Jamis.
    Anyone know the weight on the Lucky 7?
    How does it climb?
    Mar 2005
    I have had a lucky 7 since December. It weighs 40 pounds for a size large. It pedals well for a 40 pounds bike. The full length seat tube means you can actually pedal it up a hill! The wheelbase is also long at 47.25" but that provides great high speed stability. The frame is far more capable than the rear shock. The shim stack in the Vanilla R is set up in a very strange manner. (If you want more info message me). A DHX, Roco, Vivid, etc makes the bike feel 1000% better! I have a DHX5 on mine now.
    glassphisheye
    Reputation: glassphisheye's Avatar
    Feb 2006
    This frame is the same as the Azonic B-52 that I have. The b-52 has a roco world cup but the frame is identical. This bike kicks a$$; descends and climbs like a true freeride/all mountain should. I'm sick of companies selling all mountain bikes that can't handle a rough XC trail, WTF. Bottom line this bike rules.
    web design and development in El Paso
    www.websitescenes.com | http://www.roughriderfreeride.com
    Reputation: ermastupid's Avatar
    there's any one have the geometry n sizing of khs lucky 7...
    i search with google but not found..
    Reputation: Ray Lee's Avatar
    Click the geo picture bottom left
    http://www.khsbicycles.com/01_lucky7_09.htm
    Quote Originally Posted by ermastupid
    Quote Originally Posted by Ray Lee
    thanks ray lee...
    I need to find a KHS dealer, I am toying with the idea of buying my own bike for the resorts instead of risking that they will have a rental for me (6'2 215lbs)
    Seems like a great bike for the price
    Ray
    thanks ray lee...
    Reputation: Petrolbomb1018's Avatar
    Why wouldn't they spec a onepointfive standard?
