Results 1 to 9 of 9
    Reputation: Pauldotcom's Avatar
    Aug 2010
    Front Deralliur Help!! KHS XCT 535
    I bought one and it doesnt fit because of the design...
    Anyone have a suggestion on which one to buy>> Thanks
    Reputation: Aresab's Avatar
    A 34.9 clamp top swing, top pull derailler works fine. Such as the Deore m530:
    http://wheelworld.com/product/shiman...lleur-6831.htm
    Reputation: GTR2ebike's Avatar
    May 2010
    Quote Originally Posted by RSabarese
    that is the stock equipment on a 09 so you know it will work and at 9 dollars you really can't beat it.
    Aug 2010
    I bought one of these and the chain hits the lower part of it when in the lowest gear on the cog!!
    This is frustrating. Anyone know the EXACT front derailler on the 535?? I don't see how this one can work.
    Are you sure you went low enough on the frame? It does not hit on mine while pedaling, but does back-pedaling. Technically, you should not be cross-chaining (new word :>) ) meaning small ring in front and back or the reverse, large and large, it bends the chain too much. I've adjusted mine to millimeters from the big ring.
    Aug 2010
    Yes it is VERY low.. Just like you, I've adjusted it millimeters from the big ring. Yeah I know your not supposed to ride like that, but I am just trying to tune this thing to a T before I get it out. I might shave a little metal off the front of the cage; I don't think it will hurt it..
    Jan 2009
    i have the same frame and had a buncha problems withe the front d. first i bought a deore xt, which was a pain to set up. i later switched to a 35.0 top pull low clamp sram x9. which works just fine. no problems at all
    Aug 2010
    So it does not rub at all? I Could you send me a link to the EXACT one you bought (just so I have no problems). Thanks a bunch.
    Paul
    Jan 2009
    http://www.jensonusa.com/store/produ...erailleur.aspx
    choose the one that says "Top-Pull 35.0mm Low Clamp"
