Results 1 to 5 of 5
    Where to get a smart fork serviced?
    I have a 1999 K2 3000 with a smart fork. The fork doesn't work properly anymore and my local store won't touch it. Any ideas/links to a place that repairs these forks?
    -E
    Eric,
    You could try contacting hippie-tech suspension. They'll service older forks and shocks, and might be able to help you out.
    http://www.hippiesuspension.com/hipp...ion/index.html
    Quote Originally Posted by wileymel
    Eric,
    Thanks for the info
    -Eric
    Check the K2 archive for a manual. It tells you how to adjust, lube, and change the main spring in the fork. You'll need to send in the damping cartridge for service if needed.
    Smart Fork manual PDF
    Quote Originally Posted by cruiserman
    Thanks for the info
    -E
