gears weigh too much
ProFlex 4000 rear shock
I've got a 98 K2 ProFlex 4000 that is missing the rear shock.
Does anyone know what size shock it takes?
Eye-to-eye and stroke?
Any body have one they could measure for me?
Thanx
shock specs
Thanx
It takes a very odd and hard to find size. It measures 210mm I2I x 2" stroke. You'll also need upper and lower bushings that fit the frame. If you can't find one, PM me, I have a Fox Float air shock what will fit your frame. It also has Talas feature. I have one on my bike and it blows the stock coil shock away, very plush...
-bustin punks
not sure if this helps - I'm pretty sure this is the stock shock...
- You may not post replies
- You may not edit your posts
Forum Rules
