Results 1 to 2 of 2
    New question here. Lithium 3.0 tire size?
    Hello,
    Have a Lithium 3.0 with Mutanoraptor 2.14's and will be needing new rear tire. There is about 5/16" between chainstay and tire on each side now. Anyone know what the max tire size is for the rear??
    Thanks!!
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    You can comfortably fit a 2.35 tire (58mm for Kenda's) back there but if you need mud clearance, stick with something around the 2.25 range (57mm or less).
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
