Results 1 to 7 of 7
    Reputation: cyber_hawke's Avatar
    will a clydsdale break a Jamis?
    Quick question....am thinking about buying a XAM (the cheaper one). Will it take a 260lb clydsdale or will it blow a gasket in the rear suspension? Boooooommmmmmm!
    At 260, I'm thinking you could break any bike if you tried. How do you plan on riding it? Drops? Jumps?
    That will change over time.
    Initially I am sure that I will be very conservative...as I get stronger and more confident (and prolly a lot lighter) I expect I will become a little more adventurous and will try those jumps, etc.
    For now, it is crank, crank, crank up the hills and enjoy a quick, but safe run back down....
    Nov 2006
    Every bike is going to break eventually, it's just yours will break a bit sooner. I would probably go with coil suspension over air. I know there a bit more pricey and heavy but maybe the Diablo 1.0 just to be safe.
    Probably get a better answer from one of the guys that work for Jamis.
    Feb 2007
    I'm 250lbs and ride an '05 Dakar Sport. I've had it for about 3 months and ride XC mostly. It has the Fox Float in the rear and it seems to hold up just fine, but I'm not a dare devil, yet.
    Bike Geek
    Reputation: Rower_CPU's Avatar
    My experience at 6'4", 225# (originally 255#). I'm on an '04 Dakar Sport and have broken the following:
    - drive-side chainstay (apparently a common issue with the '04s)
    - a linkage bolt blew-up/fell out
    - cracked headtube
    This was all in the last 9 months after 2 years of XC riding, nothing too crazy in terms of jumps/drops. The XAM looks a lot beefier and should hold up, but the question for us clydes seems to be "when" not "if" a bike will break.
    Jamis has come through with warranty replacements for me, so I have to give them props (although the frame they sent out after the headtube break is a Dakar Comp with the weird crossbrace between the seatstays that limits you with larger tires ).
    Former Bike Wrench
    I ride a 2005 XLT (which the XAM is replacing) and weigh 230lbs. I do all mountain riding including small <3 foot drops and some jumping to transition. No problems at all so far, know there was some swingarm problems in 2004 and early 2005 but I also know Jamis has covered those with no problems. I would think that a XAM, with its DHX rear shock, would be plenty adequate for you.
