Results 1 to 6 of 6
    noticable play in my 2010 650B suspension, problem?
    There is noticable vertical play in my rear suspension when I grab the back wheel and move up and down. side to side seems to be okay. Is this a problem? I had the bearings and hardware replaced once already due to a broken pivot bolt. I can't tell if the play is at the upper pivot points or the shock mount. Anyone else have this problem?
    Just wanted to let people know I got a P.M. from Jamis Tech rep. the same afternoon I posted the question with the fix for this, talk about great service!!
    Thanks again
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Re: noticable play in my 2010 650B suspension, problem?
    Wanna share the solution? Maybe someone else might find the info useful
    No moss...
    Here is the message I sent to Steveeldr
    It sound like you have some play in your seat stay pivot. Here is a link to the pdf of the suspension http://www.jamisbikes.com/usa/tech/i..._techsheet.pdf If you add an additional spacer number 12 Spacer – 12x6xT1.5, Stainless. This should eliminate the play you are feeling in the shock
    "Never shall innocent blood be shed. Yet the blood of the wicked shall flow like a river. The three shall spread their blackened wings and be the vengeful striking hammer of god."
    The White Jeff W
    No moss...
    Sorry it took me so long to post, I'm gladBycyclePHD responded. I put an extra spacer on the upper pivot on the non-drive side. The directions didn't specify which side to put the extra spacer, at first I tried to put 2 (1 on each side) but they would not fit. I've been out for several rides since and still no play.
  1. GXP w/ X9 bottom bracket play problem
    By masonmoa in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-08-2014, 07:57 PM
  2. Is a one tenth of an inch less trail noticable?
    By 29erchico in forum Frame Building
    Last Post: 03-08-2012, 10:50 AM
  3. Play in suspension pivot
    By Mr_Melin in forum Bike and Frame discussion
    Last Post: 11-02-2011, 12:48 PM
  4. Banshee Rune Suspension Play?
    By darkslide18 in forum Banshee Bikes
    Last Post: 10-30-2011, 11:53 PM
  5. Pivot Mach 5 rear suspension play
    By magixuser in forum Pivot Cycles
    Last Post: 06-28-2011, 09:07 PM
