Results 1 to 6 of 6
    Jul 2015
    New question here. JAMIS PARKER using tapered fork
    Can i use Cane Creek 40-Series EC44-40 Bottom Assembly to let my bike using a tapered fork? What upper assembly do i need?
    Hey aeroplane602,
    Do you know which model year Parker you have?
    -JAMIS BIKES
    Dec 2015
    I also have the same question in mind. I have a Jamis Parker II (not sure what year, possibly 2008 or 2009) and was hoping to run a tampered fork with this headset. Anyone know if this is possible. Thanks in advance
    Aug 2014
    From the specs both the Jamis Parker and the Jamis Parker 2 use zero stack headsets. That means that the headtube is 44mm. You can use the above mentioned Cane Creak lower cup to run a tapered fork. There is no need to change the upper cup.
    Niner Jet 9 Carbon
    Redline Conquest
    Breezer Thunder One
    Moto Boris
    GT Tequesta
    GT La Bomba
    Charge Grater
    Nashbar Carbon Road
    Dec 2015
    Wow, Thanks for the speedy reply you helped me out a lot. When I was Trying to figure this out I went to Cane Creeks website for their fit guide and the Parker wasn't listed as a possible model choice. So I wasn't sure. Thanks again
    Aug 2014
    Yea I imagine that the bikes does not come up in the search because that lower cup is not the standard cup for that model. It is a conversion cup to allow a tapered fork to be used.
    Niner Jet 9 Carbon
    Redline Conquest
    Breezer Thunder One
    Moto Boris
    GT Tequesta
    GT La Bomba
    Charge Grater
    Nashbar Carbon Road
  1. Jamis Parker
    By L4NE4 in forum Jamis
    Last Post: 12-02-2015, 04:05 PM
  2. Jamis B1 44ZS Headset Tapered Fork?
    By Waterat Pat in forum 27.5
    Last Post: 01-11-2013, 06:44 AM
  3. Broken Jamis Parker III
    By icalebkim in forum Jamis
    Last Post: 05-01-2012, 03:41 AM
  4. Jamis Parker 3 1x9 to 2x9
    By icalebkim in forum Beginner's Corner
    Last Post: 03-08-2012, 08:07 AM
  5. 08 Jamis Parker
    By Brakebreaker101 in forum All Mountain
    Last Post: 02-19-2012, 08:24 PM
