Results 1 to 2 of 2
    Jamis Exile v. Jamis Durango 3.0
    Hi - I'm trying to decide between two used Jamis - an '04 Exile and an '06 (or '05?) Durango 3.0. They are both $400. It seems many of the specs (see specs below) are the same or similar, major difference is that the Exile has a steel frame v. the Durango's aluminum frame. I'm looking for advice/recommendations on which one would be the superior bike. Thanks! Nancy
    EXILE:
    Frame & Fork
    Frame Construction TIG-welded
    Frame Tubing Material Reynolds 520
    Fork Brand & Model Answer Manitou Axel Elite, 80mm travel
    Fork Material Aluminum/magnesium, single crown
    Components
    Component Group Mountain Mix
    Brakeset Avid Mechanical Disc brakes, Avid FR-1 levers
    Shift Levers Shimano Deore RapidFire SL
    Front Derailleur Shimano Deore, top-pull/clamp-on 28.6mm
    Rear Derailleur Shimano Deore SGS
    Crankset TruVativ Firex, 22/32/44 teeth
    Pedals Atfter Market that i bought at bike shop
    Bottom Bracket TruVativ DH ISIS, 113mm spindle
    BB Shell Width 68mm English
    Rear Cogs 9-speed, 11 - 32 teeth
    Chain Shimano CN-HG50, 1/2 x 3/32"
    Seatpost Aluminum micro-adjust, 27.2mm diameter
    Saddle selle Itallia nitrox
    Handlebar Answer Taperlite
    Handlebar Extensions Not included
    Handlebar Stem Ritchey Logic Comp
    Headset 1 1/8" threadless Dia-Compe STS
    Wheels
    Hubs Shimano Deore
    Rims Alex TD-17, 32-hole
    Tires wtb weirwolf 2.5
    Spoke Brand WTB stainless steel, 15ga. (1.8mm) straight gauge
    DURANGO:
    Shimano Deore front/rear derailluer and shifters
    Truvativ Fire x crank set
    Truvativ GXP bottom bracket
    Shimano M324 clipless pedals
    Hayes Sole Hydraulic Disc brakes
    Manitou Platinum Axel front fork.
    WTB wheelset
    A Enigma wrapped in Bacon
    Reputation: HOOKEM's Avatar
    FWIW, I would go with the steel any day before the alu. And, just personal preference from experience, I rented an Exile from Cactus Bikes in Phoenix AZ while I was out there on Vacation in 05. Since then I have been dreaming of upgrading my current ride ( a 95 GT aggressor also steel) to a Jamis Exile.....and just recently pulled the trigger on a used frame for $150. probably overpaid, but It's what I wanted, and they seem to be few and far in between. Completely subjective and biased toward the Exile, but anyway I Hope this helps.
    Good luck with your decidin'......
