Results 1 to 6 of 6
Thread: Jamis D clip?
    KVW
    KVW is offline
    Law abiding citizen
    Reputation: KVW's Avatar
    New question here. Jamis D clip?
    Perhaps this isn't a Jamis specific question but I have notice Jamis continues to use these certain kind of cable clips on their bikes that last few years. I don't even know if they're really called a "D Clip", I'm just guessing because the common ones are called a C clip.
    Basically what I need is this here:
    I keep losing them to my stupid bike rack.
    Anyone know where I can get em?
    "Single track is for pansies!
    I blast down a mountain once, and in my wake, lies a new single track for the rest of you."-sm
    I can send some to you, PM me your address. They are for ease of assembly at the factory and should be replaced with zip ties.
    "Never shall innocent blood be shed. Yet the blood of the wicked shall flow like a river. The three shall spread their blackened wings and be the vengeful striking hammer of god."
    KVW
    KVW is offline
    Law abiding citizen
    PM sent - Thank you!
    Dec 2009
    You'll be happier in the long run if you use a zip tie. The D-clip allows the housing to rub on the aluminum underneath the clip. If you use a zip tie, you'll only rub on the nylon of the zip tie underneath the houseing. If you continue to use the z-clip, eventually, you'll wear through the finish and into the metal. Your call but, worth considering.
    Clips are on their way
    KVW
    KVW is offline
    Law abiding citizen
    Thank you! Nother example of great Jamis CS.
    Justin, thanks for the warning, I'll keep that in mind. It's probably even worse since my dropper seatpost creates a lot of cable movement since the cable gets pulled up with the seat when i raise it.
