Results 1 to 17 of 17
    icalebkim
    Guest
    Guess what... Crack in Parker.
    So... I was reading this thread. Broken Jamis Parker two and getting all quirky. Finally I couldn't stand it, and I went to check on my bike. Nothing.
    I turned it upside down and gave it a close inspection...
    I'm disappointed. I'm not even 110 pounds, and I don't ride hard (2-3 ft drop max). I don't put lateral stress on my bike, nor do I ride backwards and then brake hard.
    What do you reckon? Do you think I should get a new triangle, or just use that bike for XC?
    Or just ride it till the metal fails, gives way, and I can purchase a new triangle?
    Anyway (sorry for all these questions) where would I be able to purchase a new triangle? Am I eligible for warranty (2nd user, all the way in Australia)?
    And is it a crack, or at least just a superficial weld fail?
    Dangnamit...
    Did you get it used or can you have Jamis warranty?
    The newer version of the Parker is definitely beefed up compared to the Gen1. I'm a shade over 200lbs and done some mean things to mine. It's still kickin' just fine.
    Reputation: mullen119's Avatar
    You made me look at mine( that I just built up for my wife). Mine is cracked on the drive side as well. I hope my XAM hold up better the this.
    icalebkim
    Guest
    Whoops, sorry :\
    At least its not your bike
    Anyway, would you recommend me not to ride the bike, and is it a crack anyway?
    And I did buy it 2nd hand, but I can probably get him to fix it (hopefully).
    I wouldnt ride it. It may hold up fine, but if it doesnt, it will most likely cause a pretty nasty wreck. Not worth the risk IMO. I have contacted Jenson and will hopefully have mine replaced in a weeks. Im still waiting to hear if they will cover it or not.
    When I broke a rear tri...it knocked my rear wheel outta true and dinged up my RD.
    What year is yours? I ride mine hard and no issues yet, although I should check it hard for cracks.
    icalebkim
    Guest
    I think that the parker had a really dodgy rear triangle - they could at least had a brace to strengthen it.
    I've got a 2008 III. 1st year issues - I'm p*ssed.
    I agree that the Gen1 Parker has dodgy rear tri. I think they fixed it on Gen-2.
    mines a 2009
    Has anyone had luck with replacement on bikes bought second hand? I bought mine brand new but technically used for almost nothing but have concerns about warrenty stuff. The bike is registered to me but I dont have a recipt for it.
    do you think you could clean up that spot a bit and post up another photo. I am having a hard time seeing if its a crack or dirt in a crevasse. (im not doubting its cracked though, everyone cracks them)
    icalebkim
    Guest
    I'll try.
    Just a thought, since I'm a light rider, do you think that there are any glues (like the ones that Ritchey used to glue their frames together) to create a fix? I mean like super strong pro-industrial strength sorts. Just wondering.
    But what the most infuriating thing is that Jamis doesn't reply to my emails I sent.
    :edit:
    Jamis replied.
    icalebkim
    Guest
    Mullen 119 - "I have a 09 Parker 2 what gave me a chainstay crack scare. once I found out that it was getting replaced, I sanded the paint off the area where the I thought the crack was and found out it wasnt a crack, but just an imperfection in the weld that caused a crack in the paint. Knowing this gives me more confidence in Jamis as long as it did come from 08'".
    I hope my enamel's just cracked as well. (crosses fingers)
    honestly, it looks like an imperfection in the paint with alittle dirt making it more obvious. get a toothbrush and clean out the spot well to be certain.
    I got my new chainstay today. Props to Jenson for getting it out to me so fast. Im a little disappointed that is black though.
  1. paint crack or frame crack?
    By fujibikeben in forum Frame Building
    Last Post: 10-16-2011, 07:53 PM
  2. Frame crack or paint crack?
    By Rad Rider 415 in forum Niner Bikes
    Last Post: 05-06-2011, 07:20 AM
  3. Replies: 7
    Last Post: 05-26-2010, 02:17 PM
  4. So within one year another crack!!! & same type of crack
    By arielDB in forum Bike and Frame discussion
    Last Post: 05-09-2010, 02:20 PM
