Results 1 to 28 of 28
    Reputation: azorr's Avatar
    Does anyone ride a Dakar AMT?
    I just ordered a 2012 Dakar AMT on Jenson, with the current 10% discount the price was too good to pass up. I don't see much info or talk about this bike, anyone else on here ride one?
    Jamis Dakar AMT Mountain Bike 2012 > Complete Bikes > Mountain Bikes | Jenson USA Online Bike Shop
    Nobody? Well at least I have something unique. I will post up the unboxing and ride reports when it shows up.
    I'm looking at the new 650B version of that
    I bought the same AMT a few weeks ago. Still building it and haven't ridden yet.
    Good luck finding any ride reports on this bike. I couldn't find a single one. Seems like the mystery bike no one wants to talk about. weird!
    I bought and installed the works angleset so mine sits at 67 degrees from the 68 stock.
    Did you buy a complete bike or just a frame? Let me know how you like the angleset. I plan to run it as is, except sell the Hayes brakes and buy some Shimano SLX or XT (just personal preference). Also going to swap my current crankset in that has a 22t small right instead of 24t and a bashguard instead of the big ring.
    Quote Originally Posted by Dictatorsaurus View Post
    Bought complete bike. Sold Shimano shifters, derailleurs and brakes and went with SRAM and hope. Works Angleset was tricky to install but I got the hang of it. I'm glad I did it since I've heard 68 on that bike is steep if plan to hammer the thing on the downhills which I would like to.
    Sounds like it will be a sweet bike! You should post some pictures!
    Unboxing
    It finally arrived. I decided to leave the brakes and drivetrain and everything as it came for now, may swap some things out in the future but for now its great. I haven't had a real ride yet but spent some time last night assembling and adjusting everything.
    My little man helping me get it put together.
    Pardon the messy workbench
    Looking forward to hearing about fitment and ride report.
    I am planning to head out early tomorrow morning, so I should have a report tomorrow.
    I put in a test ride this morning and really loved the bike! The trail was mostly XC type riding with a few short steep climbs and some really rocky sections. My previous bikes were all hardtails except one old Specialized Epic so the suspension was incredibly plush compared to what I am used to. The geometry was great for what I want, a "do it all" (I know, no such thing but its close) type bike that pedals well, can still handle rocks and descending as well and is beefy enough to be solid under a 6'3" 230lb rider. The component spec on the bike was spot on, drivetrain was good, tires were pretty good, brakes were good, I even liked the seat and I thought it was going to be too small and need replaced. There is one thing on the bike that I hate... the grips. I have not found any lock on grips that I like and these are no exception, they all seem to be too fat and too hard because of the inner sleeve. But that is an easy fix and I am very happy with this bike.
    I'm assuming you went with an XL 21" frame? Did you feel the cockpit was short due to the short top tube length?
    Try ESI form grips. Most comfortable grips out there you won't be disappointed!
    Yes, I bought the 21". I did not feel the cockpit was short, but the stem is longer than my old one. When I was putting it together I thought to myself that would be the first thing I changed but I doubt I will since it felt good as is.
    Here's my 19" AMT. Notice the Works Components angleset which drops the HT angle to 67 degrees.
    Have only ridden it around the parking lot. The super wide Answer 780mm bars and short 70mm stem gives it a very stable controlled feel.
    Looks very nice! I may have to consider getting one of those Angleset sometime in the future. I got another ride in on mine yesterday, had the chance to hit some really rocky parts and it was super smooth! I think I need just a little more air in my rear shock but other than that still happy with mine.
    Slacker angle helps in super steep sections and makes better use of the long front travel.
    What pressure do you run front and rear suspension?
    I was at 95psi front and 250 rear on my last ride. Bumped the rear up to 260 for my next ride.
    Have you had a chance to take your bike for a real ride yet?
    The weather has been pretty cold and lots of snow so haven't ridden it yet. I'm hoping to ride it when the snow clears.
    With the reverb post the bike weighes 32lb.
    I got the bike for a different purpose than you got it for. I have lighter faster xc bikes so I set up mine as aggressive bike to hit jumps and learn some tricks/skills.
    The short 23" top tube might actually work out well for that purpose as it puts me in an upright position.
    Reputation: Dugggg's Avatar
    Jun 2014
    I bought my 15" model from Jenson two months ago, and love it for just tooling around on trails. Because I'm just 5'5" I wanted a 26er and nicer ones are getting harder to find these days.
    I am not an aggressive rider, but the other day I was doing a slow, twisty, rocky descent and I missed a turn and suddenly found myself barreling straight down! On previous bikes I would have probably wiped out, but this thing handled it beautifully.
    Right on Dugggg! I have really enjoyed mine so far.
    Quote Originally Posted by Dugggg View Post
    Jun 2014
    Quote Originally Posted by azorr View Post
    Thanks azorr!
    I do have one question, about the Maxles. The rear one screwed in all the way, but fully screwing in the front Maxle causes the brake rotor to rub against the caliper. I tried repositioning the caliper, but it was as far out as it can go. The fix was to back out the Maxle about one turn and then close the QR. But this seems to make the wheel a bit wobbly.
    Did you have to do this too?
    No, mine is just right with it tightened all the way. I would drop Jenson a line right away (assuming that's where you bought it), I did have a different problem with my front brake and they took care of it right away.
    Jun 2014
    I just emailed Jenson as you suggested. However, looking at the problem more closely, I am wondering if my front hub is missing a large spacer on the rotor side. There is one on the QR side, but just a big hole on the rotor side where a spacer might fit.
    Could you do me a huge favor? Take your front wheel off and post a close-up pic of your rotor?
    Re: Does anyone ride a Dakar AMT?
    Yes, sounds like you are missing the end cap for the wheel. There should be one on both sides.
    Jun 2014
    Thanks so much. That is exactly the problem. I suspect I lost the cap during the unboxing process---the wheel had a plastic shipping protector and the cap probably came off with the protector when I removed it.
    I will wait til I hear back from Jenson, but is Sun Ringle SRD Pairo End Cap Kit Hubs (100101503) at CambriaBike.com the part I need?
    Did you get your wheel sorted out, looks like that link you posted is the right thing if you get the right version.
    Sent from my Nexus 4 using Tapatalk
    Jun 2014
    Yep, just got the pair yesterday. The blingy anodized red version that matches the adjuster at the bottom of the fork! I found them a tad cheaper at Universal Cycles, since their shipping for single items is just $3.
    Jenson was next to useless. They acknowledged other customers losing the end cap the same way, but were unable to offer a replacement.
    Thanks again for your help. The wheel is MUCH more stable when it isn't being centered only by the brake caliper!
  1. Jamis Dakar AMT
    By Dictatorsaurus in forum All Mountain
    Last Post: 11-19-2013, 10:17 AM
  2. Building A Dakar.... which one is it?
    By corivus in forum Jamis
    Last Post: 06-05-2013, 06:42 AM
  3. Dakar XCT
    By heypal99 in forum Jamis
    Last Post: 07-17-2012, 08:56 AM
  4. Reign VS Dakar XAM
    By m11b in forum All Mountain
    Last Post: 08-30-2011, 02:40 PM
  5. From Dakar to VT
    By DiRt DeViL in forum Giant
    Last Post: 03-21-2004, 08:44 AM
