Results 1 to 7 of 7
    Bleeder at large
    Reputation: fatroadie's Avatar
    Dakota Elite rear spacing
    I have a 2009 Dakota Elite that I picked up a few months ago. I've noticed that I have to really ratchet down the QR on the rear wheel to keep it from sliding out. I'm a fairly strong guy, and I have to tighten it almost as hard as I can to keep the rear wheel straight.
    Has anyone else experienced this? As I tighten the rear qr, I can see the rear seatstays/chainstays flex in to fit tight to the hub. It's almost like I could put a washer in there...
    Oct 2007
    This does not sound right. Could it be your hub? The first thing I would do is measure the spacing between the dropouts without a wheel. It ought to be 135mm or very close.
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Getaway Cycle Center
    Nov 2007
    Check the Axle Lock Nuts
    you should have a 1/4 inch wide locking nut that fits a 17mm wrench on the axle, you should have one on both sides.
    that spacing sounds very wide especially for the fact that the seatstay is a carbon monostay.
    good luck
    Bleeder at large
    Quote Originally Posted by ljsmith
    Finally got around to measuring the dropouts, and they are at 139mm. I didn't have a good way to accurately measure the hub. I could put the hub in a truing stand and then measure the gap between the stand forks, but I don't have a truing stand available. Maybe I'll call Jamis and see what they think.
    Nov 2007
    Dropout measurements
    2007 dakota comp frame
    2009 dakota elite frame
    Both on my wall and measured 135mm
    Bleeder at large
    thanks, I've turned this into Jamis, twice now, with no response. I guess I won't be racing this weekend, how ironic since my team is sponsored by Jamis. :-\
    Bleeder at large
    Jamis finally got the frame warrantied. They were pretty quick once we got the paperwork turned in.
