Results 1 to 6 of 6
    Can someone tell me what the leverage ratio is on an 01 Dakar frame?
    I have an 01 Jamis Dakar Expert frame and I'm just wonding if I need to upgrade to a new frame or upgrade the shock and keep it.
    Former Bike Wrench
    Pretty sure those were similar to later Dakar XC frames...3.5 inches of suspension with a 1.5 inch stroke shock...nice low 2.33:1 ratio.
    If the frame is in good condition otherwise...I'd throw a nice stable platform shock on it and ride, ride, ride!
    Pretty sure it'd run a 6.5 x 1.5 shock
    Thanx for the info. I think I'll do that...
    since I already bought a new front fork and the frame is still in good condition. A new rear shock should give it some new life. Any suggetions on where to shop or what to buy for a 200+ rider?
    Former Bike Wrench
    Well, you could go air, but look for something with a good volume. I'm currently running an X-Fusion 02 PVA on my Jamis XLT and absolutely love it...way better than a Fox Float R (I weigh 230lbs BTW). But they're hard to find right now in the US.
    Another suggestion would be a Cane Creek Cloud Nine...Cane Creek shocks are pretty nice, and they have an exchange program where you can get $100 off a new shock by exchanging your old shock.
    http://www.canecreek.com/fileadmin/c..._2007apr19.pdf
    The last potential option would be to have the stock shock (a Fox Vanilla R as I recall) factory tuned by Push Industries. They will completely rebuild it and add platform dampening to it.
    http://www.pushindustries.com/servic...0Coil%20Shocks
    Good luck and let me know what you end up doing!
    Reputation: oldskoolbiker's Avatar
    Jun 2005
    There are plenty of shock deals out there. Here is one from Santa Cruz for example.
    http://www.santacruzbicycles.com/cat...ac5256161acf14
    One thing, I recently upgradedd my rear shock, and I had to order a seperate mounting kit for the Rock Shox I put on there. That was an additional $35 expense. If you stick with Fox Shocks you should be able to re-use the monting pieces already on the bike.
    As far a mounting, I think its a 24.0 on one end and 22.2 on the other and 6mm mounting bolts.
    Good info. I've got an 06 Dakar and it too is the 6.5 x 1.5 version with 22mm and 24mm w/ 6 mm bolts. I was thinking of going to the CC9 myself but want something for the road or hardpack and the ability to reach down, flip a lever and be ready for the suspension to do it's thing too. RP23 is nice but PUSH wants way too much and buying a used shock from someone doesn't interest me. So I save my lunch money and wait. Good luck and keep us posted.
