Results 1 to 10 of 10
Thread: Bearings
    Bearings
    hi i own a jamos parker 08 and recently i diassembled the whole frame so i could clean and relube everything, when i diassembled the frame i noticed that one of the bearings kind of broke (one of the sides that is like a plastic that protects the inside was broken and ir fell off) where can i find a new one? or what can i do to fix this one?
    Bearing cartridges are standard and fairly easy to find....just look at the bearing number on the side of the old one and order up a matching one from any of these places:
    http://www.jensonusa.com/store/produ...e+Bearing.aspx
    http://bikeusa.com/bike-usa-catalog-...ory=150&type=t
    http://www.bikepartsplace.com/cycles...ngs-fasteners/
    TLO
    TLO is offline
    Ride more ***** less
    Sounds like the dust seal popped out, just put it back in.
    Lovin the hardtail
    Reputation: mullen119's Avatar
    Which bearing is it?
    I think its called the seatstay link... Thanks for the input, but can i find these covers or seals in a hardware store? the main problem is that im not from the US so ordering them would take waaaaay too long, and id like to ride the bike asap... thanks
    the seat stay bearings are size 608rs Google it and im sure you can find a place that will ship to you.
    ok perfect thanks for all the input, ill go as soon as i can to a skate store and look for some new ones. One last question, how do i get the bearings out and the new ones in? simple pressure? or is there more to it?
    Quote Originally Posted by resclusa View Post
    These guys can order it for you
    Part number 12-2277 if it is the seat stay pivot
    or you can use this link http://www.jamisbikes.com/usa/tech/i..._techsheet.pdf
    and tell me the item# not the part #, this tech sheet is the 09 not the 08 and I'll give you the right part # for 08
    VENEZUELA
    BICIMACIA, C.A.
    TRINIDAD CALLES PARIS Y MADRID
    LAS MERCEDES CARACAS VENEZUELA
    QTA MOTAMACIA GU
    Tel 212 9932025
    Fax 212 9932560
    oche@dist-vmax.com
    "Never shall innocent blood be shed. Yet the blood of the wicked shall flow like a river. The three shall spread their blackened wings and be the vengeful striking hammer of god."
  1. Bontrager RE-1 Pedal Bearings? Any Pedal bearings?
    By davez26 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-19-2011, 09:35 AM
  2. VXB Bearings on 5.5?
    By hollywood99 in forum Intense
    Last Post: 07-23-2010, 06:12 AM
  3. Replies: 7
    Last Post: 01-02-2010, 06:22 PM
  4. hub bearings
    By brokefork in forum Wheels and Tires
    Last Post: 08-20-2007, 08:23 AM
  5. Blur: bearings or bearings and axles?
    By jrm in forum Santa Cruz
    Last Post: 08-19-2005, 06:00 AM
