Results 1 to 6 of 6
    NOOB
    Nov 2012
    2005 jamis Dakar fork question....
    I curently have a2005 jamis Dakar with the factory minute fork at 130mm of travel.... I'm looking to upgrade but don't know what I should get.... I found a sektor solo air with 130mm of travel and also the other model with150mm of travel but will that be to much?..... Please help me I'm a noob and any advice is good advice....
    Reputation: Aresab's Avatar
    Which 2005 Dakar do you have, the Dakar, Dakar Sport, Dakar Comp, Dakar XLT, ...? Confusing, eh?
    Many sektors have tapered steerers today which most likely won't work with some of the Dakar's, but can be made to work with others. Those with a Zero Stack headset can be fitted with an external cup lower bearing by cane Creek which allows the larger steerer. If your model already has external bearing cups top and bottom, you need a fork with a straight 1 1/8 steerer as tapered will not fit. The Sektor Soloair has all-travel spacers to change travel from 150mm to 130mm. However, if you are looking for a Rockshox, the Recon Gold is similar to the Sektor, has the same all-travel spacers but goes from 100mm to 120mm in travel and may be a good match depending on the Dakar you have.
    NOOB
    Nov 2012
    Sorry I should have included that....it's a xlt 3.0 and the two sektors I am looking at are 1 1/8 steerer tube with a 9mm qr.. I know my basic stuff but I'm wondering if the 150mm wil rake it out to much. I don't want to snap the head tube...
    I use a 140MM 20mm Recon 351 (Sektor replaced it) on my XLT 2.0, love the way it handles. I had a 145mm Manitou Nixon last year as well, no issue with the head tube. Since the bike came with a 130mm, you should be fine at 140mm, 150mm is a jump in Geo and steering may get a bit slower.
    NOOB
    Nov 2012
    So I take it 150mm is out of the question?
    I like mine better with the 140mm, but the Sektor can go 130 - 150 so you can always lower it with a spacer (assuming that is the one you buy).
  1. Dakar AMT question/please help jamis tech guys
    By chapman505 in forum Jamis
    Last Post: 11-07-2013, 05:27 PM
  2. 2005 Jamis Dakar XLT
    By drewlee13 in forum 27.5
    Last Post: 02-16-2012, 05:52 PM
  3. $40 Jamis Dakar
    By nailtrail in forum General Discussion
    Last Post: 08-28-2011, 09:31 PM
  4. Jamis Dakar XCT 1.0 '09
    By jcufari in forum All Mountain
    Last Post: 04-11-2011, 05:41 PM
  5. !Need Help Buying 2005 Jamis Dakar XLT!
    By intricated in forum Beginner's Corner
    Last Post: 04-09-2011, 03:25 PM
