Results 1 to 2 of 2
Thread: Warrior se
    Warrior se
    Hey every one, I just picked up a IH warrior se. It needs a little work but I love it. I was wondering if any of you all knows where I can get the eylet bushing for the swing arm side shock mount. it looks like the eylet bushing/top hat shaped bushings inner hole is pretty worn its oval shaped creating a good bit of play in the suspension
    It also looks like the guy I got it from blew the front forks, can I rebuild the stock j3. Or what is a good fork to upgrade to for these bikes.
    Here ia a pic of it:
    Jun 2010
    go to a shop
    I looked online for bushings for my warrior pro about 6 months ago. Ended up taking it to a few LBS. One told me I was screwed and to make it a rigid frame. The other searched and found some. Otherwise, I would have had new bushings made at a machine shop. If the front fork was stock replace it. Mine had a Manitou something or another on it. Replaced it with a Fox Vanilla, and it was like buying a new bike. If you're in NC, Bikes East in Matthews is the LBS that found the bushings.
